Posts: 4023 Joined: Wed Jul 30, 2008 6:43 pm
Post
by Roberto Lopez » Mon Sep 14, 2009 1:30 pm
Rathinagiri, Sudip,
Thanks for pointing me the benefits of SqLite.
I have not available time right now to do it myself, but I have an idea
A nice thing could be from the same source code, have local and client/server access changing only something like a SET command to specify that.
So, could be easy to make some sort of intermediate layer to unify functions to access SQL (local via SqLite or remote via MySql or PostgreSql).
Roberto.
Posts: 5482 Joined: Tue Jul 29, 2008 6:30 pm
Post
by Rathinagiri » Mon Sep 14, 2009 1:46 pm
Exactly what I have thought of. You are always many steps ahead.
sudip
Posts: 1456 Joined: Sat Mar 07, 2009 11:52 am
Post
by sudip » Mon Sep 14, 2009 1:55 pm
Roberto Lopez wrote: Rathinagiri, Sudip,
Roberto.
Yes Master Roberto,
You always have an idea many times forward than rest of us
With best regards.
sudip
Post
by sudip » Mon Sep 14, 2009 1:57 pm
Hello Rathi,
rathinagiri wrote: IMHO the needs for SQLite:
1. Use of SQL queries.
2. Index would be done automatically every time.
3. Single file per database of numerous tables.
4. Mutli-user
5. Speed
6. Security (Password protection)
Thank you very much for your wish
Can you please tell me how can I password protect SQLite database?
Thanks in advance.
With best regards.
Post
by Roberto Lopez » Mon Sep 14, 2009 3:33 pm
Some years ago, I've created a small code layer called 'MiniSql'.
Perhaps, this code could be useful to you in some way.
I'm sure that I have a backup of it, but, I can't find it
So, if someone has it, please upload!
Roberto.
sudip
Post
by sudip » Mon Sep 14, 2009 5:26 pm
Hello Master Roberto,
Is the following code you are talking about?
* HMG - Harbour Win32 GUI library
* MiniSql (a Simple MySql Access Layer)
* Copyright 2002-2005 Roberto Lopez <harbourminigui@gmail.com>
* http://harbourminigui.googlepages.com/
Function SqlDoQuery( nHandle , cQuery )
Local nNumRows
Local nNumFields
Local nQueryResultHandle
Local aQuery := {}
Local aRow := {}
Local i
if __mvexist ('SqlTrace')
If SqlTrace == .T.
MsgInfo (cQuery)
EndIf
SqlQuery ( nHandle , cQuery ) ; SqlErrorCheck ( nHandle )
nQueryResultHandle := sqlStoreR( nHandle ) ; SqlErrorCheck ( nHandle )
nNumRows := sqlNRows( nQueryResultHandle ) ; SqlErrorCheck ( nHandle )
nNumFields := sqlNumFi( nQueryResultHandle ) ; SqlErrorCheck ( nHandle )
For i := 1 To nNumRows
aRow := sqlFetchR(nQueryResultHandle) ; SqlErrorCheck ( nHandle )
aadd ( aQuery , aRow )
Next i
Return aQuery
Function SqlDoCommand ( nHandle , cQuery )
Local ar
If SqlTrace == .T.
msginfo(cQuery)
EndIf
ar := SqlAffRows(nHandle) ; SqlErrorCheck ( nHandle )
Return ar
Procedure SqlErrorCheck ( nHandle )
Local SqlCurrentError
SqlCurrentError := SqlGetErr ( nHandle )
If .Not. Empty ( SqlCurrentError )
SqlQuery ( nHandle , 'UNLOCK TABLES')
SqlClose( nHandle )
MsgStop (SqlCurrentError ,"MiniSql")
EndIf
#ifndef __XHARBOUR__
#pragma BEGINDUMP
#define HB_OS_WIN_32_USED
#include "hbapi.h"
HB_FUNC_EXTERN( MYSQL_GET_SERVER_VERSION ); HB_FUNC( SQLVERSION ) { HB_FUNC_EXEC( MYSQL_GET_SERVER_VERSION ); }
HB_FUNC_EXTERN( MYSQL_REAL_CONNECT ); HB_FUNC( SQLCONNECT ) { HB_FUNC_EXEC( MYSQL_REAL_CONNECT ); }
HB_FUNC_EXTERN( MYSQL_CLOSE ); HB_FUNC( SQLCLOSE ) { HB_FUNC_EXEC( MYSQL_CLOSE ); }
HB_FUNC_EXTERN( MYSQL_COMMIT ); HB_FUNC( SQLCOMMIT ) { HB_FUNC_EXEC( MYSQL_COMMIT ); }
HB_FUNC_EXTERN( MYSQL_ROLLBACK ); HB_FUNC( SQLROLLBACK ) { HB_FUNC_EXEC( MYSQL_ROLLBACK ); }
HB_FUNC_EXTERN( MYSQL_SELECT_DB ); HB_FUNC( SQLSELECTD ) { HB_FUNC_EXEC( MYSQL_SELECT_DB ); }
HB_FUNC_EXTERN( MYSQL_QUERY ); HB_FUNC( SQLQUERY ) { HB_FUNC_EXEC( MYSQL_QUERY ); }
HB_FUNC_EXTERN( MYSQL_STORE_RESULT ); HB_FUNC( SQLSTORER ) { HB_FUNC_EXEC( MYSQL_STORE_RESULT ); }
HB_FUNC_EXTERN( MYSQL_USE_RESULT ); HB_FUNC( SQLUSERES ) { HB_FUNC_EXEC( MYSQL_USE_RESULT ); }
HB_FUNC_EXTERN( MYSQL_FREE_RESULT ); HB_FUNC( SQLFREER ) { HB_FUNC_EXEC( MYSQL_FREE_RESULT ); }
HB_FUNC_EXTERN( MYSQL_FETCH_ROW ); HB_FUNC( SQLFETCHR ) { HB_FUNC_EXEC( MYSQL_FETCH_ROW ); }
HB_FUNC_EXTERN( MYSQL_DATA_SEEK ); HB_FUNC( SQLDATAS ) { HB_FUNC_EXEC( MYSQL_DATA_SEEK ); }
HB_FUNC_EXTERN( MYSQL_NUM_ROWS ); HB_FUNC( SQLNROWS ) { HB_FUNC_EXEC( MYSQL_NUM_ROWS ); }
HB_FUNC_EXTERN( MYSQL_FETCH_FIELD ); HB_FUNC( SQLFETCHF ) { HB_FUNC_EXEC( MYSQL_FETCH_FIELD ); }
HB_FUNC_EXTERN( MYSQL_FIELD_SEEK ); HB_FUNC( SQLFSEEK ) { HB_FUNC_EXEC( MYSQL_FIELD_SEEK ); }
HB_FUNC_EXTERN( MYSQL_NUM_FIELDS ); HB_FUNC( SQLNUMFI ) { HB_FUNC_EXEC( MYSQL_NUM_FIELDS ); }
HB_FUNC_EXTERN( MYSQL_FIELD_COUNT ); HB_FUNC( SQLFICOU ) { HB_FUNC_EXEC( MYSQL_FIELD_COUNT ); }
HB_FUNC_EXTERN( MYSQL_LIST_FIELDS ); HB_FUNC( SQLLISTF ) { HB_FUNC_EXEC( MYSQL_LIST_FIELDS ); }
HB_FUNC_EXTERN( MYSQL_ERROR ); HB_FUNC( SQLGETERR ) { HB_FUNC_EXEC( MYSQL_ERROR ); }
HB_FUNC_EXTERN( MYSQL_LIST_DBS ); HB_FUNC( SQLLISTDB ) { HB_FUNC_EXEC( MYSQL_LIST_DBS ); }
HB_FUNC_EXTERN( MYSQL_LIST_TABLES ); HB_FUNC( SQLLISTTBL ) { HB_FUNC_EXEC( MYSQL_LIST_TABLES ); }
HB_FUNC_EXTERN( MYSQL_AFFECTED_ROWS ); HB_FUNC( SQLAFFROWS ) { HB_FUNC_EXEC( MYSQL_AFFECTED_ROWS ); }
HB_FUNC_EXTERN( MYSQL_GET_HOST_INFO ); HB_FUNC( SQLHOSTINFO ) { HB_FUNC_EXEC( MYSQL_GET_HOST_INFO ); }
HB_FUNC_EXTERN( MYSQL_GET_SERVER_INFO ); HB_FUNC( SQLSRVINFO ) { HB_FUNC_EXEC( MYSQL_GET_SERVER_INFO ); }
HB_FUNC_EXTERN( MYSQL_ESCAPE_STRING ); HB_FUNC( DATATOSQL ) { HB_FUNC_EXEC( MYSQL_ESCAPE_STRING ); }
HB_FUNC_EXTERN( MYSQL_ESCAPE_STRING_FROM_FILE ); HB_FUNC( FILETOSQLBINARY ) { HB_FUNC_EXEC( MYSQL_ESCAPE_STRING_FROM_FILE ); }
#pragma ENDDUMP
#endif
If it is the program you are talking about, I am also uploading the folder containing this file also.
I found it from Minigui\Samples\Advansed\Minisql folder. And I hope this can be easily compiled with HMG official with some minor changes.
With best regards.
sudip on Mon Sep 14, 2009 5:36 pm, edited 1 time in total.
Post
by Roberto Lopez » Mon Sep 14, 2009 5:34 pm
sudip wrote: Hello Master Roberto,
Yes it is.
You'll must find a '.ch' file, a sample and some little docs too.
Could be you so kind to upload all the files (if available) ?
Roberto.
sudip
Post
by sudip » Mon Sep 14, 2009 5:37 pm
Yes Master Roberto,
I am uploading it.
With best regards.
Post
by Rathinagiri » Mon Sep 14, 2009 6:11 pm
Oh! Nice. It is a treasure to dig in.
Post
by Roberto Lopez » Mon Sep 14, 2009 6:16 pm
sudip wrote: Yes Master Roberto,
I am uploading it.
MiniSql.zip
With best regards.
OOPS!!!
Sorry, I've not seen it
Roberto.
