compiling with debug option
bluebird
Post by bluebird »
I want to learn to use the debugger, so I just tried to follow th HMG Doc file
When I tried compiling with the debugger option as per the Doc file by Mr. Soto
ex build /d myprogram.prg
I end up with an exe file called d.exe
What am I missing?
Thanks mentors
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: compiling with debug option
Post by dragancesu »
It's work very well, look screenshot
What's your HMG version? It start from 3.3.1 or later, I think
bluebird
Post by bluebird »
Thanks again.
What is Serbia weather like in mid summer?
bluebird
Post by bluebird »
Mr Dragabcescu
I my have responded incorrectly and failed to answere you question. All I see above in my reply is the weather question about your country
that I do intend to visit this summer :)
My version is 3.4.3
Is it possible that the build.bat cannot interpret the /d as an option, but thinks its a file name to be compiled, or is there a missing file on my system?
Can you suggest what I should look for?
dragancesu
You welcome
Problem about which you write to me and going, creating d.exe
How I managed I do not know, probably badly written command blended parameters, but does not manage to repeat
