HMG 3.4.4
Re: HMG 3.4.4
IDE of HMG344 is giving errors: (recursive error?)
Date:2017.04.03 Time: 10:46:26
Error: HMG 3.4.4 Stable (32 bits)
Window: newbuild already defined. Program Terminated
Called from _DEFINEMODALWINDOW(4597)
Called from HMGMAKE(39528)
Called from BUILDPROJECTM(36907)
Called from RUNAPPLICATION(31697)
Called from (b)MAIN(713)
Called from EVENTS(1801)
Called from DOMESSAGELOOP(0)
Called from DOMETHOD(9003)
Called from HMGMAKE(39542)
Called from (b)NEWBUILD(39615)
Called from EVENTS(828)
Called from MAIN(1253)
Re: HMG 3.4.4
Please test this version of IDE ( 1.2b )
hmg_IDE.1.2b.rar
(3.03 MiB) Downloaded 2691 times
Re: HMG 3.4.4
Gracias Claudio !
Please note this: viewtopic.php?f=10&t=5206&p=50666#p50666
Re: HMG 3.4.4
Thanks Claudio, I will let you know !
tonton2
Re: HMG 3.4.4
Post by tonton2 »
merci beaucoup Dr Claudio et heureux de vous lire et de savoir que vous êtes toujours avec nous
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
kcarmody
Re: HMG 3.4.4
Post by kcarmody »
Many thanks to Claudio and Rathi for this new version!
I just downloaded the new version. Everything I submitted over the past year is in this version and works great!
There is just one small exception. I submitted a batch file, makechm.bat, that compiles a .CHM file from HTML and other files. Like build.bat, it was designed to work in the root directory of HMG, and to be called by secondary batch files in other directories. These secondary batch files are also named makechm.bat. There are three of these secondary files in 3.4.4, in these directories:
  • SAMPLES\Basics\Help\Chm\
  • SAMPLES\HFCL\WordScribe\Shortcuts\
  • SAMPLES\HFCL\WordWriter\Shortcuts\
In 3.4.4, the main makechm.bat has been put into SAMPLES\Basics\Help\ . The secondary makechm.bat files cannot find the main makechm.bat there. The main makechm.bat should be copied or moved to the root directory of HMG.
Thanks again to Claudio and Rathi!
Re: HMG 3.4.4
Claudio, All went well with IDE ver 1.2b but after some compiles I cannot 'Open' for a compiling another project. Clicking on 'Open-icon' looks is possible but nothing happens (no way to click on a file / folder). I have to close the IDE and restart, Clicking on X to close gives empty msgbox , no text (sure to exit? YES/NO_) and my desktop screen is full of 'remaings' of the IDE...
Thanks for looking at it !
Re: HMG 3.4.4
Thank you Serge for reporting.
What I noted is always after 30 compilations at the same project, of course.
The other point noted is when alterante IDE to NPP (I do not know if happen with other editor) but what I mean it's by making focus in different windows.
When IDE crashes the only way out is by task manager close IDE process.
Re: HMG 3.4.4
kcarmody wrote: Thu Apr 06, 2017 5:01 pm Many thanks to Claudio and Rathi for this new version!
Thank you Kevin to advice us and for your brillant work released at this last HMG version.
Marin
Re: HMG 3.4.4
Post by Marin »
Hi friends,
I don't know, maybe this is not the right place for such kind of posts.
I have found a wrong hmgdoc description in the Row property - it states, that Col is returned instead of Row.
Maybe this might be corrected in the next edition of the doc's.
It is, of course, a 'copy-paste' mistake, and seems not to be so important but...
Kind regards,
Marin
