Hi Rajeev,
Thank you for you testing and reporting.
I think you have a special way to saying that's something wrong by using reverse psychology tactics ...
Has anyone ever said that to you before ?
Thanks to your and my persistence, I can say that I have been able to observe where my error is in this application.
Initially ViewError checks which program is associated with PRG files. I noted that's totally unnecessary, because at no time do I need to run the PRG editor in an associated way.
I was concerned that the user's favorite editor would always be registered. It was a mistake from my side, unless as long as user inform where editor is, be always available and for the most importance that it can accepts the parameter for positioning in the desired line, nothing more.
I will change that. I will turned up more flexible to accept any favorite editor. That's the way it must be.
So let me clarify a little more in your question, Rajeev:
* After installation, when I select Yes to reboot, it again goes to installation screen and then reboots.
I think it's normal because, when UAC intervention dialog be querying to user if can run with administrator right yes or not, the user can answer to NOT...
and if answered to YES the system must need to give some time for closing apps and then boot it the system. Do you considered as wrong this behaviour ? Please you comment.
* If i select Context as my default program editor the program keeps asking me parameter for line no , ie "-n" of npp.
In your previous messages, you have mentioned something like context... (lower case I guess) and I did not imagining you was referring to a your favorite editor.
(IMHO: "context" word it's dual meaning)
I have installed and now I know it. Very good one because has a Foxpro highlighter but I am still liking NPP.
For this question of line parameter needing in
Context editor you will need following info to ViewError's settings:
/g1:" (Without quotes)
See picture below:
- Screen167.png (42.79 KiB) Viewed 10908 times
For Notepad++, this parameterization for this same propose is:
- Screen168.png (71.49 KiB) Viewed 10908 times
http://docs.notepad-plus-plus.org/index ... e_switches
Earlier version did not ask about this parameter.
In this last version of ViewError its fundamental for proper work to exist this parameterization.
* The relevant Radio button for choosing program editor, appears "disabled" though clicking it enables it.
Here's where I noted that's no sense from my part to think for APP to be associated with PRG files. And the ViewError checked that PRGs are not assciated with your favorite editor the "Context". I could make ViewError to make question for associating but I think is not the ViewError propose... this concerns to your editor and your SO, not ViewError at all (not really).
* I tried using /REMOVE to uninstall, it did not work.
I think I will cut off this switch.
I still see that making applications/tools or any system, does not just looking good, thinking it's good enough...
what we really should take into account is the diverse opinions of the user and their difficulties with the program.
Programmer not always applies the good policy of:
"The program has to adapt to the user and not the user to the program..."
I think this is very good, it is healthy: Listen to what users need.
Thank you again Rajeev.
