HMG 3.4.4
Re: HMG 3.4.4
Hi Youcef, may you tell us how this is doing, what happening ?
SO version, any antivirus blocking it ?
tonton2
Re: HMG 3.4.4
Post by tonton2 »
my version is windows 10
anti virus is kapersky total security
When I run the Hmg 3.44 setup file, nothing happens
merci a vous Pablo cesar
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
edk
Re: HMG 3.4.4
Post by edk »
Hi tonton2
My Win10 installs HMG3.4.4 without problems.
The Smart Screen will warn you, but you can force it to start.
344 smart screen.png (12.88 KiB) Viewed 204079 times
Maybe for a moment to turn off Kaspersky?
Re: HMG 3.4.4
Probably it is that Youcef. Thank Edward.
Please disable your antivirus during HMG installation and turn on again the antivirus. Please revert later.
tonton2
Re: HMG 3.4.4
Post by tonton2 »
I am going to try once more
merci beaucoup
Y.TABET
tonton2
Re: HMG 3.4.4
Post by tonton2 »
it's the same
But I do not understand why it does not even start
I downloaded the file here
Y.TABET
edk
Re: HMG 3.4.4
Post by edk »
Try run as Administrator.
What check sums do you have on the downloaded file?
Should be like this:
MD5: 09b8f31f4746d2e129ee6e05425fdf99
CRC32 (SFV): 78B3F55A
SHA1: 09ffc43d6d5460fa46de4eafc57367d3ea23f23a
SHA256: 12f294a5fb518f2bff9d42243d4bf31086d245a96373e774e8d524d1125c6836
SHA512: f1f32b6367c4b20f53ba6ba3fdaf1234c1c9e71808b39a16fe3ce8ab0937086796eb8fc79236a9d5766934fe7963ca36a2f35391cfba5f526c6ec94dbbf2f722
Re: HMG 3.4.4
The HMG.3.4.4.Setup.exe file is it the same than other you tried and successfully installed ?
Probably you this file came with some errors during downloading... check if is the same size.
Make copy from the right installation or download again...
edk wrote: Fri Mar 31, 2017 1:09 pm Try run as Administrator.
Good idea too. Right click of mouse on the file and choose Run as administrator...
fouednoomen
Re: HMG 3.4.4
Post by fouednoomen »
it's running without any problem under windows 10 and kaspersky endpoint security 10
KDJ
Re: HMG 3.4.4
Post by KDJ »
Can you update Harbour x64 to latest version?
