HMG 3.4.3
Re: HMG 3.4.3
Hi Claudio,
Here happen again at end of night (22:50h). All this end of afternoon working normally upto now. As you can see 34 compilation was realized with IDE 1.2a (I reset the counter).
This happen after my last building and when I tried to close it by [x] button is a capture screen below:
If I answer for "No" exit, works properly and all caption, menu items and titles redraw again and clicked on window "Project Browser".
If a click on exit button of IDE, the MsgYesno for Exit, the Msg text is displayed but not when I click [x] button.
If I click "Yes" on exit IDE, it disapear all buttons, all menus and the project name and do not close it. Only by Task Manager to close it.
No messages errors. No log, neither.
Re: HMG 3.4.3
After three days of working with the same instance of newest IDE ANSI ver. I've needed to debug code. After second compilation, IDE crashed.
Date:2017.03.30 Time: 08:48:50
Error: HMG 3.4.4 Stable (32 bits)
Window: newbuild already defined. Program Terminated
Called from _DEFINEMODALWINDOW(4597)
Called from HMGMAKE(39528)
Called from BUILDPROJECTM(36907)
Called from RUNAPPLICATION(31697)
Called from (b)MAIN(966)
Called from EVENTS(1801)
Called from DOMESSAGELOOP(0)
Called from DOMETHOD(9003)
Called from HMGMAKE(39542)
Called from (b)NEWBUILD(39615)
Called from EVENTS(828)
Called from (b)MAIN(713)
Called from _OPEN(26326)
Called from EDITFILE(30306)
Called from (b)MAIN(1077)
Called from EVENTS(2015)
Called from (b)NEW(2178)
Called from (b)SHOWLOG(43070)
Called from SHOWLOG(43239)
Called from NEWBUILD(39637)
Called from (b)HMGMAKE(39528)
Called from _PROCESSINITPROCEDURE(5876)
Called from _ACTIVATEWINDOW(5691)
Called from (b)NEWBUILD(39621)
Called from (b)NEWBUILD(39627)
Called from (b)PROC_DEFINE_MAIN_MENU(1413)
Called from EVENTS(1756)
Called from (b)MAIN(623)
Called from MAIN(1253)
I'm sure I've pressed DEBUG icon only one time...
Re: HMG 3.4.3
Pablo, the errorlog was located in the folder I last compiledA subfolder of HMG.
Re: HMG 3.4.3
Thank you Serge.
Let's say a normal ErrorLog at current folder.
Re: HMG 3.4.3
Yes, indeed !
Re: HMG 3.4.3
HMG IDE crashes (nor responding) again with the following screen.
I think this problem is just like Pablo's problem.
Re: HMG 3.4.3
I'm still using hmg 3.4.3 for one application.
I got strange error - strange, because error message suggests problem with toolbar, but, I don't use toolbars in this application
Here is error message translated to English
Error BASE/1068 Incorrect argument: incorrect count of arguments
Called from OBSLBLEDU(1557)
Called from (b)MAIN(693)
Called from GETFORMHANDLE(3787)
Called from BT_WINHANDLE(61)
Called from BT_STATUSBARHANDLE(404)
Called from BT_STATUSBARHEIGHT(424)
Called from REPOSITIONTOOLBAR(421)
Called from EVENTS(1487)
Called from C_MSGSTOP(0)
Called from SHOWERROR(181)
Called from DEFERROR(129)
Called from (b)ERRORSYS(66)
Called from _ACTIVATEWINDOW(5702)
Called from FAKTURAVAT(1064)
Called from AKCJATESTPRZYCISKOW(2055)
Called from (b)ZDEFINIUJMENUGLOWNE(2815)
Called from _DOCONTROLEVENTPROCEDURE(6041)
Called from EVENTS(1786)
Called from MAIN(706)
It happened when I pressed ESC key ( Release window action is bounded to this key)
Re: HMG 3.4.3
Hi Marek,
You are using an old version and now its seems harder case to repoduce same error and more without the codes involved. :|
mol wrote: Mon May 08, 2017 7:00 pm I got strange error - strange, because error message suggests problem with toolbar, but, I don't use toolbars in this application
I was curious to see this question about REPOSITIONTOOLBAR. What it looks like that is not needed to have one in your project without pass thru this C function that Windows.prg calls at PAINT event. :?
My tip is you check first all error described in sequence from up to down. See line number braced in parenthesis and then check your code first.
GETFORMHANDLE seems came with wrong argument coming from MAIN and OBSLBLEDU functions.
Another tip: test again recompiling with the newest version. ;)
Re: HMG 3.4.3
I don't call getformhandle in path of this error
Re: HMG 3.4.3
You could not call this function, but internally yes is calling.
I can perhaps guess that maybe some form that has been deleted in some routine of yours or not. And this is not found ...
Have you tried with 3.4.4 ???
