Having trouble updating text box value.
I am in a window with a grid and some text boxes
to update the grid and text boxes i have a function as follows. The grid emptys but the text boxes do not refresh to zero.
there must be something I am missing to update the text boxes values.
if I put a message box at the bottom, the text boxes refresh
function prpr3()
FORM_GRID_IN2.GRID_2.itemcount := 0
FORM_GRID_IN2.Text_6.Value := 0
FORM_GRID_IN2.Text_7.Value := 0
FORM_GRID_IN2.Text_8.Value := 0
FORM_GRID_IN2.Text_9.Value := 0
FORM_GRID_IN2.Text_10.Value := 0
FORM_GRID_IN2.Text_12.Value := 0
FORM_GRID_IN2.Text_13.Value := 0
FORM_GRID_IN2.Text_14.Value := 0
FORM_GRID_IN2.Text_15.Value := 0
FORM_GRID_IN2.Text_16.Value := 0
FORM_GRID_IN2.Text_17.Value := 0
FORM_GRID_IN2.Text_18.Value := ''
FORM_GRID_IN2.Text_19.Value := 0
FORM_GRID_IN2.Text_20.Value := 0
FORM_GRID_IN2.Text_21.Value := 0
FORM_GRID_IN2.Text_22.Value := 0
FORM_GRID_IN2.Text_23.Value := 0
DO EVENTS // added and now works as Pablo suggested.
I updated this function for others to view. This works
Thanks Franco
Text Box Update
Text Box Update
All The Best,
Franco
Canada
Franco
Canada
Text Box Update
Do Events, en lugar de MsgBox ?
Re: Text Box Update
Thank you for quick response Pablo
is there a way to empty the grid before up date instead of visible .f.
I tried deleteallitems but does not update. If I use itemcount := 0. the grid disappears ... looks funny.
All The Best,
Franco
Canada
Franco
Canada
Text Box Update
Si utiliza los elementos de eliminación se vacía la matriz. Entonces necesitará agregar uno a uno.
Creo que hay una manera atravez de una función en C. No me acuerdo ahora.
Googled
If you use the deleteallitems will empty the array. Then you will nedd to additem one by one.
I think there a way in C function. I do not remember now.
Googled
Re: Text Box Update
Now working and all is well.
This forum and HMG is amazing.
Thanks again........ Franco
All The Best,
Franco
Canada
Franco
Canada
Text Box Update
Qué bueno que conseguiste !
Otra idea, seria: eliminando el control Grid e recriarlo nuevamente con la matriz ya elaborada.
Yes, really is.
