PDF Viewer DLL?
Re: PDF Viewer DLL?
Hi Bdp2000:
You were right, in your sample don't appear error screen.-
What i was looking is to print silently and i solved it this way:
EXECUTE FILE 'SumatraPDF.EXE' PARAMETERS '-print-to-default -plugin -exit-on-print ' + cHwnd + ' ' + 'SAMPLE.pdf'
The issue i got was because i put parameter "-plugin" as the first.- Put it in the middle works find.-
By the way, i test different printScale, and the best result was putting "none".- With this parameter (none) PDF document is printed exactly with the paper size (margins) it was created.- Take in count that if on your app will be printed different format of pages, printer must be set to "legal" size.- In other terms is the as if you choose on Adobe Reader the option Select paper size from document (pdf) size.
Just a contribution.-
With regards.
Eduardo
With regards.
Eduardo
Re: PDF Viewer DLL?
Several functions to support SumatraPDF and simple pdf viewer.
May be useful to someone.
- PdfView.zip
- (7.35 MiB) Downloaded 506 times
PDF Viewer DLL?
Excellent work, Krzysztof !
Very impressed by your quality.
Indeed to say: it was expected in your source codes.
Your events procedure is very good.
A good mastery in this area is fundamental to be a high quality work.
May I offer my little tip ? Or to give my opinion regarding GRID Files:
We would change ONDBLCLICK by ONCHANGE.
F12 other HotKeys, very useful.
Thank you very much for your sharing.
This is going to my favorites in my collection sources.
Re: PDF Viewer DLL?
Excellent and well done. Thanks forma share with al.
Thanls Kristof. With regards. Eduardo
Re: PDF Viewer DLL?
+1Pablo César wrote: ↑Wed Mar 22, 2017 9:38 pm Excellent work, Krzysztof !![]()
This is going to my favorites in my collection sources.![]()
Re: PDF Viewer DLL?
Wow!
Thanks Krzysztof for your very useful code.
Re: PDF Viewer DLL?
Excellent work. Many thanks Krzysztof.
Said from Algeria
Said from Algeria
jozef
Re: PDF Viewer DLL?
Very usefull. Thanks.
Re: PDF Viewer DLL?
Dzięki Krzysztofie!
There is a small bug:
Open any PDF file, then set focus to "SumatraPanel" (press Tab key or click on SumatraPanel), then press left Alt key. The program will freeze.
Edward.
Edward.
Re: PDF Viewer DLL?
Great job! Thank you Krzysztof!
My first run hangs up application, too.
But, after reset computer, it worked OK.
