TAB Control in HMG 3.4.3
BobFBurns
- DBs Used: DBF, ACCDB
I am running HMG 3.4.3 32bit under Windows 7 Professional 64bit OS. Is there any way to position the tabs in a TBA Control on the right hand vertical edge? I can position them on the left hand or top edge with no problems.
Many thanks for looking.
Bob
Bob
Re: TAB Control in HMG 3.4.3
Hi Bob,
Do you mean something like in HTML (tabindex = order) ?
See :
https://www.w3schools.com/tags/att_glo ... index.asp
I don't think we have this but we can use it. Claudio any idea if it is possible?
See :
Hello Bob,
Do you mean the Tab position similar as on the image below
- TAB with BUTTONS VERTICAL BOTTOM clauses
- tabdemo.png (25.75 KiB) Viewed 16836 times
Hmmm, also nice to have!
Hi Serge,
Thanks for your interest!
The above features are available in the basic TAB sample at Minigui Extended
Hi Grygory:
+100
Wow, i think that if we could implement your suggestion on HMG would be a great a powerfull control.-
Good job, excellent brain.-
With regards as allways
Eduardo
+100
Eduardo
Great job! Thanks Grigory.
Is there a simple way to mix HMG+ Minigui Extended or combine the two?
I think that all that exists in hmg exists in minigui extended and more. Unfortunately, minigui extended does not support unicode. The ideal is that one day we can join forces and work on a single branch of hmg
Yes, I too have found that Minigui Extended installation folder has many samples for most features of HMG. Thanks to Grigory for making it easier for newbies in HMG like me.
Anand
BobFBurns
Hi Grigory
Yes thank you, your image with Pages 1 - 4 on the right hand side of the Tab Control is exactly what I was looking for.
I have just posted another question related to a compiler issue in V3.4.3 which is preventing me from doing any more work at the moment.
Bob
Bob
