German Umlaute (ÄÖÜäöüß)
sherlogg
Post by sherlogg »
Hello,
i don't know, if this is the right area of the forum for my problem.
I've tried to create a menu with German special characters named Umlaute (ÄÜÖäüöß), but i've got a strange output. I don't know how easy it is, to change something like OEM or ANSI.
I use SET CODEPAGE TO GERMAN and SET LANGUAGE TO GERMAN, but it don't work.
Just for clarification: i'm a Harbour starter
Cheers, Dieter
Re: German Umlaute (ÄÖÜäöüß)
set codepage to german is translated to:
#xtranslate SET CODEPAGE TO GERMAN => REQUEST HB_CODEPAGE_DEWIN ; hb_setcodepage("DEWIN")
so, it should be enough...
I've added to my app this and tested and umlaute's are displayed OK.
sherlogg
Post by sherlogg »
Hi Marek,
thanks for your help. I've got it by myself. I've used a editor with the WRONG charset. After using another editor, it workes fine!
ROBROS
Post by ROBROS »
mol wrote: Fri Feb 17, 2017 6:26 am set codepage to german is translated to:
Hi Marek, found your suggestion, works well, thank you.
Robert
