PDF Viewer DLL?
Re: PDF Viewer DLL?
KDJ wrote: Mon Feb 13, 2017 10:24 pm SumatraPDF uses MuPDF library to rendering.
I found something on this subject:
https://www.codeproject.com/Articles/49 ... -Invoke-in
https://www.codeproject.com/Articles/57 ... er-Control
Thanks. I'll take a look at it.
PeteWG
Re: PDF Viewer DLL?
Post by PeteWG »
Roberto Lopez wrote: Mon Feb 13, 2017 10:28 pm The only possible issue is that the user could click outside Sumatra window, being overlapped by HMG app, but, This could be solved using: EXECUTE FILE ... WAIT
Hi Roberto
you can use -plugin switch which give the ability to make SumatraPDF a child window of a given window, f.e. a window of your application.
In this way you have absolute control!
please see here
https://github.com/sumatrapdfreader/sum ... -arguments
(scroll down to "Developer options")
I have done it for one of my minigui applications and works ok.
I'm pretty sure you will easily realize how to make it, ;-)
however, If you need any details, about the way I have implemented it, I 'd be happy to provide them.
P.S. yes, SumatraPDF it's a very good piece of opensource software!
best regards,
Pete
PDF Viewer DLL?
Yeah nice news !
Re: PDF Viewer DLL?
PeteWG wrote: Tue Feb 14, 2017 12:51 pm Hi Roberto
Thanks!
This morning I've was reading the document you point (Sumatra at GitHub) and (for some reason) I've missed '-plugin' option :)
As you said, this way, we are in full control of the users experience, without caring about PDF support available on their systems.
Thanks again!
Re: PDF Viewer DLL?
And... a step further...
Since I like that ny apps be self-contained (a single exe file) I'm thinking on embed Sumatra portable on my source code and create it (if it does not exists) in the destination machine (a crazy idea... I know :) ).
I guess that I should create an utility that reads the binary file (Sumatra exe) and creates the source code of a Harbour array, containing an element for each byte in the binary (maybe using HEX).
Since I'm trying to not reinvent the wheel (if not strictly needed) my question is: Does such utility exists?
TIA.
Re: PDF Viewer DLL?
Roberto Lopez wrote: Wed Feb 15, 2017 1:24 am And... a step further...
TIA.
Roberto,
1) embed your file as raw resource ( resource type ID are defined in i_controlmisc.ch ):
MyRawRes RT_RCDATA MyfileX.exe
2) load resource:
cData := HMG_LoadResourceRawFile ( "MyRawRes", RT_RCDATA )
3) save the resource:
hFile := FCreate("MyFile.exe")
Fwrite( hFile, cData )
FClose( hFile )
Re: PDF Viewer DLL?
by Roberto Lopez » Tue Feb 14, 2017 6:24 pm
Hola a todos
Yo ya tenía un tiempo que no participaba...
Esa "loca idea" yo también la tuve hace algún tiempo y después de probar y probar y probar,
logre hacerlo de esta forma. (NOTA: solo que el archivo pesaba 529 kb)
Espero que les sirva
Hello everyone
I already had a time that did not participate ...
Robert
That "crazy idea" I also had it some time ago and after trying and testing and trying,
Can do it this way. (NOTE: only the file weighed 529 kb)
I hope it works for you
MiArchivo.RC
MIARCH TXT miarchivo.exe
en mi programa...
FUNCTION CreaExe( )
LOCAL xData1
xData1 := HMG_LoadResourceRawFile( "MIARCH", "TXT" )
HB_MEMOWRIT( "miarchivo.exe", xData1 )
RETURN nil
Re: PDF Viewer DLL?
Attach small working sample when it will be ready, please :-)
PeteWG
Re: PDF Viewer DLL?
Post by PeteWG »
Roberto Lopez wrote: Wed Feb 15, 2017 1:24 am Since I'm trying to not reinvent the wheel (if not strictly needed) my question is: Does such utility exists?
TIA.
No need to reinvent "this wheel"!
I would never stop to say that "harbour has it all" (or almost all, anyway) :-)
Personally, I do use a #pragma trick to attach binaries (or anything) to the final executable.
f.e. in one application that makes use of "curl.exe" I did:
#include "fileio.ch"
   IF ! hb_vfExists( "curl.exe" )
      hb_MemoWrit( "curl.exe", CurlExe() )
      // give OS a little time to "see"  the newly created file
      hb_IdleSleep( 0.5 )
      // hide the file from user's sight to protect it from "accidents"
      hb_vfAttrSet( "curl.exe",  HB_FA_HIDDEN + HB_FA_READONLY + HB_FA_SYSTEM )
STATIC FUNCTION CurlExe()
#pragma __binarystreaminclude "CURL.EXE" | RETURN %s
NOTE: the binary that is going to be attached, must be available and visible during compile/link time, so I put it into project's /source folder.
NOTE 2: it's obvious that the attached file is piling up onto the final executable, and in the case of sumatraPDF (latest portable version is about ~6.5MiB), this attaching-technic will significantly affect the size of the executable with all the contingent consequences that such a growth may have during runtime.
best regards,
Pete
