Win_Msg - A kind of Notification message so easy and friendly Demo
The only problem in transparency when you click on other window the Notifier lose its transparency...
I added to:
If ValType(ERROR) = "U"
   aBcolor := If(nTransparency=255,{0,153,0},{0,51,0})
Else
   aBcolor := If(nTransparency=255,{204,0,0},{153,0,0})
Endif
and...
FONTBOLD If(nTransparency=255,.F.,.T.)
When Transparent, leaving bold and bold colors to better visualize ...
Impossible to use hb_ThreadStart, doesn't it Rathi ?
I read at PCToledo forum where an experimental test THREAD with HMG and he said is not possible in HMG...
Or am I doing something wrong ? :?
SOCORRO Claudio... :o
Re: Win_Msg - A kind of Notification message so easy and friendly Demo
Yes Rathi. Very useful. Krzysztof make a very good sample.
I think this is the way on..
KDJ
Post by KDJ »
Pablo
Very nice job. I like it!
Example how to do this in multi threading:
  Version.........: 1.1
  Created by......: Pablo César on February 9th, 2017
#define HB_THREAD_INHERIT_PUBLIC 1
Function Main()
  LOCAL pThread1
  LOCAL pThread2
  SET WINDOW MAIN OFF
  pThread1 := HB_ThreadStart(HB_THREAD_INHERIT_PUBLIC, @Notifier1(), "Printing file xxxxx.xxx sent to EPSON LX-300" , , 3)
  hb_IdleSleep(4)
  pThread2 := HB_ThreadStart(HB_THREAD_INHERIT_PUBLIC, @Notifier2(), CRLF+"File not found!", 1)
  HB_ThreadJoin(pThread1)
  HB_ThreadJoin(pThread2)
  SET WINDOW MAIN ON
Function Notifier1(cMsg,ERROR,nSeconds)
  LOCAL nHeight := 82, nWidth := 204
  LOCAL nLeft := (GetDesktopWidth() - 5) - nWidth
  LOCAL nTop := (GetDesktopHeight() - 50) - nHeight
  LOCAL hWnd, aBcolor, nWinRow := nTop, nWinCol := nLeft
  DEFAULT nSeconds := 2
     aBcolor := {0,153,0}
  Else
     aBcolor := {204,0,0}
  Endif
  DEFINE WINDOW Win_Msg1 AT nTop, nLeft WIDTH nWidth HEIGHT nHeight TOPMOST ;
      NOMAXIMIZE NOMINIMIZE NOSIZE NOSYSMENU NOCAPTION BACKCOLOR aBcolor
    DEFINE LABEL Label_1
        ROW         10
        COL         10
        WIDTH       nWidth - 20
        HEIGHT      nHeight - 20
        VALUE       cMsg
        FONTNAME    "MS Shell Dlg"
        FONTSIZE    10
        FONTBOLD    .F.
        BACKCOLOR   aBcolor
        FONTCOLOR   WHITE
        CENTERALIGN .T.
    END LABEL
  hWnd := GetFormHandle("Win_Msg1")
  HMG_ChangeWindowStyle(hWnd, WS_EX_CLIENTEDGE, NIL, .T.)
  AnimateWindow(hWnd, (nSeconds*300), AW_VER_NEGATIVE)
  hb_IdleSleep(nSeconds)
  AnimateWindow(hWnd, (nSeconds*1500), (AW_BLEND + AW_HIDE))
  SendMessage( hWnd, WM_SYSCOMMAND, SC_CLOSE, 0 )
Function Notifier2(cMsg,ERROR,nSeconds)
  LOCAL nLeft := 0
  LOCAL nTop := 0
  Else
  Endif
  DEFINE WINDOW Win_Msg2 AT nTop, nLeft WIDTH nWidth HEIGHT nHeight TOPMOST ;
        ROW         10
        COL         10
        WIDTH       nWidth - 20
        HEIGHT      nHeight - 20
        VALUE       cMsg
        FONTSIZE    10
        FONTBOLD    .F.
        BACKCOLOR   aBcolor
        FONTCOLOR   WHITE
        CENTERALIGN .T.
    END LABEL
  hWnd := GetFormHandle("Win_Msg2")
That is so cool!
Thx Pablo !
Hi Krzysztof thank you very much for teaching us a little more about Threads, for your contribution and your compliment and from others.
I'm trying another way with Not_HMG window (registered but not with _HMG_SYSDATA structure) but I'm not finished yet.
Based on your example, I added: hb_ThreadWait, hb_threadQuitRequest
  Version.........: 1.2
  Created by......: Pablo César on February 11th, 2017
#include "MyWindow.ch"
Function Main()
Load Window Demo2
Demo2.Center
Demo2.Activate
Function Send_Msgs()
LOCAL pThID
StopWindowEventProcedure("Demo2",.T.)
pThID := hb_ThreadStart(HB_THREAD_INHERIT_PUBLIC, @Notifier(), "Printing file xxxxx.xxx sent to EPSON LX-300", , 1)
If hb_ThreadWait( pThID ) = 1
   hb_threadQuitRequest( pThID )
   hb_ThreadStart(HB_THREAD_INHERIT_PUBLIC, @Notifier(), CRLF+"File not found!", 1, 1)
Endif
DoMethod("Demo2","SETFOCUS")
Return 1
Function Notifier(cMsg, ERROR, nSeconds)
LOCAL cLastForm := GetFormNameByIndex(GetLastActiveFormIndex())
DEFAULT cMsg := ""
If Empty(cMsg)
Endif
Else
Endif
// SET WINDOW MAIN OFF // Note need any more for not being HMG window
DEFINE MYWINDOW Win_Msg AT nTop, nLeft WIDTH nWidth HEIGHT nHeight TOPMOST ;
// hWnd := My_DefineWindow ( "Win_Msg",, nLeft, nTop, nWidth, nHeight, .F., .F., .F., .F., .T.,.F., "",, ,, , ,, aBcolor, , .F. , .T. , .F. , , .T. , ,, , , ,, , , , , , , , , , .F. , , , , .F. , , , , , , , , , , .F. )
        ROW         10
        COL         10
        WIDTH       nWidth - 20
        HEIGHT      nHeight - 20
        VALUE       cMsg
        FONTSIZE    10
        FONTBOLD    .F.
        BACKCOLOR   aBcolor
        FONTCOLOR   WHITE
        CENTERALIGN .T.
    END LABEL
// END WINDOW
// hWnd := GetFormHandle("Win_Msg")
EnableWindow( hWnd, .T. )
// UnRegisterWindow("Win_Msg")
StopWindowEventProcedure(cLastForm,.F.)
// SET WINDOW MAIN ON
Function My_DefineWindow( FormName,  ;                  /* 01   "Form_1",*/
                          Caption,  ;                   /* 02           ,*/
                          x,  ;                         /* 03      nLeft,*/
                          y,  ;                         /* 04       nTop,*/
                          w,  ;                         /* 05     nWidth,*/
                          h,  ;                         /* 06    nHeight,*/
                          nominimize,  ;                /* 07        .F.,*/
                          nomaximize,  ;                /* 08        .F.,*/
                          nosize,  ;                    /* 09        .F.,*/
                          nosysmenu, ;                  /* 10        .F.,*/
                          nocaption, ;                  /* 11        .T.,*/
                          StatusBar, ;                  /* 12        .F.,*/
                          StatusText, ;                 /* 13         "",*/
                          initprocedure, ;              /* 14           ,*/
                          ReleaseProcedure, ;           /* 15           ,*/
                          MouseDragProcedure, ;         /* 16           ,*/
                          SizeProcedure, ;              /* 17           ,*/
                          ClickProcedure, ;             /* 18           ,*/
                          MouseMoveProcedure, ;         /* 19           ,*/
                          aRGB, ;                       /* 20    aBcolor,*/
                          PaintProcedure, ;             /* 21           ,*/
                          noshow, ;                     /* 22        .F.,*/
                          topmost, ;                    /* 23        .T.,*/
                          main, ;                       /* 24        .F.,*/
                          icon, ;                       /* 25           ,*/
                          child, ;                      /* 26        .T.,*/
                          fontname, ;                   /* 27           ,*/
                          fontsize, ;                   /* 28           ,*/
                          NotifyIconName, ;             /* 29           ,*/
                          NotifyIconTooltip, ;          /* 30           ,*/
                          NotifyIconLeftClick, ;        /* 31           ,*/
                          GotFocus, ;                   /* 32           ,*/
                          LostFocus, ;                  /* 33           ,*/
                          virtualheight, ;              /* 34           ,*/
                          VirtualWidth, ;               /* 35           ,*/
                          scrollleft, ;                 /* 36           ,*/
                          scrollright, ;                /* 37           ,*/
                          scrollup, ;                   /* 38           ,*/
                          scrolldown, ;                 /* 39           ,*/
                          hscrollbox, ;                 /* 40           ,*/
                          vscrollbox, ;                 /* 41           ,*/
                          helpbutton, ;                 /* 42        .F.,*/
                          maximizeprocedure, ;          /* 43           ,*/
                          minimizeprocedure, ;          /* 44           ,*/
                          cursor, ;                     /* 45           ,*/
                          NoAutoRelease, ;              /* 46        .F.,*/
                          InteractiveCloseProcedure, ;  /* 47           ,*/
                          visible, ;                    /* 48           ,*/
                          autorelease, ;                /* 49           ,*/
                          minbutton, ;                  /* 50           ,*/
                          maxbutton, ;                  /* 51           ,*/
                          sizable, ;                    /* 52           ,*/
                          sysmenu, ;                    /* 53           ,*/
                          titlebar, ;                   /* 54           ,*/
                          cPanelParent, ;               /* 55           ,*/
                          panel ;                       /* 56        .F. */
LOCAL vscroll , hscroll , BrushHandle , FormHandle, ParentHandle
/* Unused Parameters */
StatusBar := Nil
StatusText := Nil
DEFAULT x := GetDesktopRealLeft()
DEFAULT y := GetDesktopRealTop()
DEFAULT w := GetDeskTopRealWidth()
DEFAULT h := GetDeskTopRealHeight()
DEFAULT nosize        := .Not. sizable
DEFAULT nosysmenu     := .Not. sysmenu
DEFAULT nocaption     := .Not. titlebar
DEFAULT nominimize    := .Not. minbutton
DEFAULT nomaximize    := .Not. maxbutton
DEFAULT NoAutoRelease := .Not. AutoRelease
DEFAULT NoShow        := .Not. Visible
FormName := AllTrim(FormName)
DEFAULT Caption            := ""
DEFAULT scrollup           := ""
DEFAULT scrolldown         := ""
DEFAULT scrollleft         := ""
DEFAULT scrollright        := ""
DEFAULT hscrollbox         := ""
DEFAULT vscrollbox         := ""
DEFAULT InitProcedure      := ""
DEFAULT ReleaseProcedure   := ""
DEFAULT MouseDragProcedure := ""
DEFAULT SizeProcedure      := ""
DEFAULT ClickProcedure     := ""
DEFAULT MouseMoveProcedure := ""
DEFAULT PaintProcedure     := ""
DEFAULT GotFocus           := ""
DEFAULT LostFocus          := ""
DEFAULT VirtualHeight      := 0
DEFAULT VirtualWidth       := 0
DEFAULT aRGB               := { -1, -1, -1 }
If VirtualHeight = 0
   vscroll := .f.
Else
    vscroll := .t.
Endif
If VirtualWidth = 0
   hscroll := .f.
Else
   hscroll := .t.
Endif
UnRegisterWindow(FormName)
If ValType( icon ) == 'U' .and. ValType( _HMG_DefaultIconName ) != 'U'
   icon := _HMG_DefaultIconName
Endif
BrushHandle := RegisterWindow( icon, FormName, aRGB )
Formhandle = InitWindow( Caption , x, y, w, h, nominimize, nomaximize, nosize, nosysmenu, nocaption, topmost, FormName, ParentHandle, vscroll, hscroll, helpbutton, panel )
If Valtype ( cursor ) != "U"
   SetWindowCursor( Formhandle , cursor )
EndIf
If valtype(NotifyIconName) == "U"
   NotifyIconName := ""
Else
   ShowNotifyIcon( FormHandle , .T., LoadTrayIcon(GETINSTANCE(), NotifyIconName ), NotifyIconTooltip )
Endif
InitDummy(FormHandle)
If VirtualHeight > 0
    SetScrollRange ( Formhandle, SB_VERT, 0, VirtualHeight - h, .T. )
EndIf
If VirtualWidth > 0
    SetScrollRange ( Formhandle, SB_HORZ, 0, VirtualWidth - w, .T. )
EndIf
_HMG_SYSDATA [ 264 ] := .F.
Return (FormHandle)
Rathinagiri wrote: Fri Feb 10, 2017 5:44 am Looks very nice and decent! My small addition to center window and transparency.
Now, until the notifier is removed, does the application stop processing? If yes, can this process be moved to a multi-threading enabled thread?
Function Main()
SET WINDOW MAIN OFF
Notifier("Printing file xxxxx.xxx sent to EPSON LX-300",,3)
Notifier(CRLF+"File not found!",1)
Notifier("Printing file xxxxx.xxx sent to EPSON LX-300",,3, .t., 128 )
Notifier(CRLF+"File not found!",1,, .t., 100 )
SET WINDOW MAIN ON
Function Notifier(cMsg,ERROR,nSeconds, lCenter, nTransparency)
DEFAULT lCenter := .f.
DEFAULT nTransparency := 255
Else
Endif
DEFINE WINDOW Win_Msg AT nTop, nLeft WIDTH nWidth HEIGHT nHeight TOPMOST ;
        ROW         10
        COL         10
        WIDTH       nWidth - 20
        HEIGHT      nHeight - 20
        VALUE       cMsg
        FONTSIZE    10
        FONTBOLD    .F.
        BACKCOLOR   aBcolor
        FONTCOLOR   WHITE
        CENTERALIGN .T.
    END LABEL
if lCenter
   center window win_msg
SET WINDOW win_msg TRANSPARENT TO nTransparency
Change in Notifier function:
for this:
nTimeIni := hb_MilliSeconds()
WHILE( ( hb_MilliSeconds() - nTimeIni ) < nSeconds * 1000 )
DO EVENTS
hb_releaseCPU()
ENDDO
