RadioGroup can be MULTILINE
Hi all, there is a way to increase (but not long, only two lines).
This is by the reason that in c_radio.c is fixed value to 28 of height item... :|
Here's the code to become MULTILINE in RadioGroup:
#define BS_MULTILINE         8192
Function Main()
Load Window Demo1
Demo1.Center
Demo1.Activate
Function ChngRadios()
HMG_ChangeWindowStyle ( GetControlHandle("RadioGroup_2","Demo1"), BS_MULTILINE, NIL, .F. )
Demo1.RadioGroup_2.Caption(3) := "Text will be in multiline and NOT at third line when is longer"
@ Claudio
Is it possible to increase height of item programmatically ? May you teach us how to do it, please ?
As you can in third item in red marked, it is not display for complete.
Re: RadioGroup can be MULTILINE
Usar:
SetWindowPos(
hWnd,
cx,
cy,
SWP_DRAWFRAME + SWP_NOMOVE + SWP_NOZORDER
También hay una función interna llamada _SetWindowHeight o algo parecido.
Usar:
SetWindowPos(
hWnd,
cx,
cy,
Antes del cx y cy existen dos parametros más. No es cierto ?
Esta función iria cambiar el ancho de los items de un RadioGroup ?
KDJ
Post by KDJ »
Pablo
Maybe in this way:
FUNCTION Main()
  SET FONT TO 'MS Shell Dlg', 8
  DEFINE WINDOW MainWA;
    MAIN;
    ROW    100;
    COL    100;
    WIDTH  190;
    TITLE  "RadioGroup multiline";
    NOSIZE;
    NOMAXIMIZE;
    NOMINIMIZE
    DEFINE FRAME RadioFR
      ROW      10
      COL      50
      WIDTH    80
      CAPTION "RadioGroup"
    END FRAME
    DEFINE RADIOGROUP RadioRG
      ROW      30
      COL      60
      WIDTH    60
      VALUE     2
      OPTIONS {"Radio 1", e"Radio 2\ntwo lines", e"Radio 3\nthree\nlines"}
    END RADIOGROUP
    DEFINE BUTTON HeightBU
      COL      40
      WIDTH   100
      HEIGHT   25
      CAPTION ""
      ACTION  ChangeHeightRG()
    END BUTTON
    ON KEY ESCAPE ACTION MainWA.RELEASE
  ChangeHeightRG()
  MainWA.CENTER
  MainWA.ACTIVATE
FUNCTION ChangeHeightRG()
  STATIC lFixedH := .T.
  LOCAL nHeight
  lFixedH := ! lFixedH
  nHeight := RadioGroup_Format("RadioRG", "MainWA", 7, lFixedH)
  MainWA.RadioFR.HEIGHT := nHeight + 30
  MainWA.HeightBU.ROW   := MainWA.RadioFR.HEIGHT + 25
  MainWA.HEIGHT := (MainWA.HEIGHT - MainWA.CLIENTAREAHEIGHT) + MainWA.HeightBU.ROW + MainWA.HeightBU.HEIGHT + 10
  MainWA.HeightBU.CAPTION := If(lFixedH, "&Set variable height", "&Set fixed height")
FUNCTION RadioGroup_Format(cControl, cForm, nGap, lFixedHeight) //for vertical RadioGroup
  LOCAL nTotalH := 0
  LOCAL nFixedH := 0
  LOCAL nCount
  LOCAL aHandle
  LOCAL aHeight
  LOCAL cText
  LOCAL nLines
  LOCAL nRow, nCol, nWidth
  LOCAL nValue
  LOCAL n
  IF _IsControlDefined(cControl, cForm)
    IF (! HB_IsNumeric(nGap)) .or. (nGap < 0)
      nGap := 10
    IF ! HB_IsLogical(lFixedHeight)
      lFixedHeight := .F.
    nRow    := GetProperty(cForm, cControl, "ROW")
    nCol    := GetProperty(cForm, cControl, "COL")
    nWidth  := GetProperty(cForm, cControl, "WIDTH")
    nValue  := GetProperty(cForm, cControl, "VALUE")
    aHandle := GetControlHandle(cControl, cForm)
    nCount  := Len(aHandle)
    aHeight := Array(nCount)
    FOR n := 1 TO nCount
      cText      := GetWindowText(aHandle[n])
      nLines     := HB_TokenCount(cText, .T. /*lEOL*/)
      aHeight[n] := GetTextHeight(0, cText, GetWindowFont(aHandle[n])) * nLines
      nFixedH    := Max(nFixedH, aHeight[n])
      IF nLines > 1
        HMG_ChangeWindowStyle(aHandle[n], 0x2000 /*BS_MULTILINE*/, NIL, .F.)
      IF nValue > 0
        IF nValue == n
          HMG_ChangeWindowStyle(aHandle[n], WS_TABSTOP, NIL, .F.)
          HMG_ChangeWindowStyle(aHandle[n], NIL, WS_TABSTOP, .F.)
    IF lFixedHeight
        SetWindowPos(aHandle[n], 0, nCol, nRow, nWidth, nFixedH, 0x14 /*SWP_NOZORDER|SWP_NOACTIVATE*/)
        nRow += nGap + nFixedH
      nTotalH += nFixedH * nCount + nGap * (nCount - 1)
        SetWindowPos(aHandle[n], 0, nCol, nRow, nWidth, aHeight[n], 0x14 /*SWP_NOZORDER|SWP_NOACTIVATE*/)
        nRow    += nGap + aHeight[n]
        nTotalH += aHeight[n]
      nTotalH += nGap * (nCount - 1)
RETURN nTotalH
Pablo César wrote: Sun Feb 05, 2017 6:45 pm
Usar:
SetWindowPos(
hWnd,
cx,
cy,
Si los parámetros son col y row
KDJ wrote: Sun Feb 05, 2017 7:50 pm Pablo
Maybe in this way:
Nice, nice NICE !! Always you Krzysztof surprising us. How nice ! I liked it !
Sometimes it doesn't seem so simple... much less so that when we have very little knowledge in C language... :oops:
I got something different. I did this a couple of hours ago and I was late to post on time while having my afternoon coffee ... sorry Krzysztof hopefully if this my message seems redundant but still think it is never late to show other ways to do. Do not you think ?
I really liked the way you do it, Krzysztof. Very creative by the way.
I did it this way I can work with RadioGroup horizontally as well. However, changing the spacing between the items and changing height and width has its consequences. The way I do it requires the user to discern all factors involved. Otherwise everything is weird and unfeasible.
The important thing to succeed in the result, attached what I had achieved:
RadioGroupMultiLine.rar
Source files
(1.8 KiB) Downloaded 258 times
My code is not finished. I know it can be done better.
Many thanks Krzysztof for your excellent and impeccable work.
I loved the use of ClientAreaHeight based on the size of the Frame in it.
Awesome !
Dziękuję za nauczenie nas :geek:
(Sorry for my poor Polish language)
Thx Pablo & Krzysztof and others: DreamTeam...?
Hahaha not so much Serge... (at least I speak for myself, I'm a continuous student)
Thanks Serge but, I believe we each of us can do part of the HMG Dream Team when we collaborating, participating and we spreading to others our work tools. As the same you do too. :)
I ended up forgetting to mention about the 9th optional parameter which is the number to which you want to change only.
Re-remembering that the 8th parameter should also must be changed.
Because the combination of these factors changes the layout of RadioGroup in a sometimes radical way.
Here's the little changed code:
Source files
(1.85 KiB) Downloaded 251 times
I think this code is only useful in cases where the text size of RadioGroup items does not change at all times. I mean that even if of different sizes, they are always of the fixed size. Not the same as OptionBox, for example.
I hope it's educational and funny... :D
PS: The gray backcolor of RadioGroups is just to duly denote size and position of each item.
KDJ
Post by KDJ »
Pablo, probably there is something missing in this code.
It did not succeed to me to get such effect like on your picture.
Post by EduardoLuis »
Hi Pablo:
I agree with Krzysztof, compiled you sample differs with your posted picture.-
May be something is missing.-
With regards.
Eduardo
