OptionBox()
Source code related resources
quartz565
Re: OptionBox()
Post by quartz565 »
Ευχαστώ Pablo !
Best Regards,
Nikos.
os: Windows Server 2019 - 64
OptionBox()
Είστε ευπρόσδεκτοι, Νίκος ! :D
trmpluym
Re: OptionBox()
Post by trmpluym »
Hi Pablo,
I have a small improvement for your fantastic OptionBox. When the lenght of the parameter cTitle1 or cTitle2 is longer than the length of the longest parameter in the array aOptions, cTitle1 or cTitle2 is not displayed right. For example:
OptionBox("Choice","This is a OptionBox with a very long string in cTitle2",{"TEST1","TEST2"}, 2)
2017-02-04 17_59_29-OptionBox - LongTitle.png (5.14 KiB) Viewed 4625 times
This can be solved by adding 2 lines of code:
nWidth:=iif(nWidth<GetTextWidth(NIL,cTitle1,FontHandle),GetTextWidth(NIL,cTitle1,FontHandle),nWidth)
nWidth:=iif(nWidth<GetTextWidth(NIL,cTitle2,FontHandle),GetTextWidth(NIL,cTitle2,FontHandle),nWidth)
Now the result is:
2017-02-04 17_59_29-OptionBox - LongTitle 2.png (4.43 KiB) Viewed 4625 times
I included the modified version as an attachement.
Theo
optionbox.zip
(1.5 MiB) Downloaded 301 times
Re: OptionBox()
Thx Theo !
OptionBox()
Ohhh you are right to add this.
But you have forgotten to include in your last code:
Function OptionBox( cTitle1, cTitle2, aOptions, nDefault, cIcon )
DEFAULT cIcon := "ZZZ_AAAWINDOW" // Default HMG ICON
OptionBox_Ok(@nRet)
So here's but I would like to solve FontHandle case:
OptionBox.rar
Source files
(1.8 KiB) Downloaded 287 times
Bedankt Theo :)
trmpluym
Re: OptionBox()
Post by trmpluym »
It is a pleasure working with you Pablo !
OptionBox()
Thank you Theo. It is also very good for me to work together. :)
Welkom degenen die veel van zichzelf te geven filantropische manier. :D
