OptionBox()
Source code related resources
tonton2
Re: OptionBox()
Post by tonton2 »
Merci beaucoup Roberto
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
OptionBox()
Roberto Lopez wrote: Fri Jul 01, 2016 12:19 pm
tonton2 wrote:Hello to all the team,
how to use this program with IDE
Thank you for your help
This is a simple function. You could add it to your own code (using the IDE or not).
Thank you big boss Roberto for nice and simple solution. :)
I've already started using it but with some changes.
Attached is my contribution with following improving:
  • Fixed overwriting control display in RadioGroup items on frame
  • Added multilanguage support in buttons
  • Autoadjustable width sizes (form, and RadioGroup) by size of items and size o Title and buttons centralized
  • Optional title in frame. Useful when form title is too long.
  • FontSize definition for whole controls
And along with a practical example:
MsgBox.rar
Source files
(1.56 KiB) Downloaded 280 times
I hope you enjoy :P
I know that we still need to improve the ItemsMaxLen function for the FontHandle could work correctly, especially if the FontSize changes.
I could not get FontHandle because at this stage there is no control nor form created yet. I think that for you want to work with source change you must enable the line:
AEVAL( aItems, { | cItem | nMxLn := Max( nMxLn, HMG_Len( cItem ) * nFontSize * .8 ) } )
This line-example is a contribution of the colleague Esgici that I borrowed.
This is with FontSize 12 (exaggerated but automatic adjustment working, just for fun). :P
Re: OptionBox()
Thanks Pablo and Roberto!
trmpluym
Re: OptionBox()
Post by trmpluym »
Hi Roberto,
Thanks for this great new function ! Very useful !
Here some minor improvements based on the last modified version of Pablo:
(1) Centre in parent Window when a parent window is defined
IF ASCAN( _HMG_SYSDATA[69], "A" ) > 0 .AND. _HMG_MainWindowFirst==.T.
  cParentWindowName:=ThisWindow.Name
  CENTER WINDOW OPTIONBOX IN &cParentWindowName
   CENTER WINDOW OPTIONBOX DESKTOP
ASCAN( _HMG_SYSDATA[69], "A" ) > 0 if a MAIN window is defined
_HMG_MainWindowFirst==.F. when SET WINDOW MAIN OFF (like Pablo uses often)
(2) nRet variable changed from PRIVATE to LOCAL
    DEFINE BUTTON CANCEL
       ROW     110 + ( 30 * ( LEN(aOptions) - 2 ) )
       COL     nColButtons + 110
       CAPTION cCaption2
       ACTION  OptionBox_Cancel(@nRet)
	   FONTNAME "Arial"
       FONTSIZE nFontSize
    END BUTTON
    ON KEY ESCAPE ACTION OptionBox_Cancel(@nRet)
And
Function OptionBox_Cancel(nRet)
ThisWindow.RELEASE
SET WINDOW MAIN ON
Without the PRIVATE variable i can use the nRet variable 'safely' in other code.
msgbox.zip
(1.5 MiB) Downloaded 299 times
OptionBox()
Dank u Theo !
Ik vergat je aangegeven centralisatie.
I am adopting your changes, thanks again
trmpluym
Re: OptionBox()
Post by trmpluym »
Você é meu amigo Pablo!
OptionBox()
trmpluym wrote: Sat Jan 21, 2017 6:32 pm Você é meu amigo Pablo!
Thank Theo, you are as my friend too ! :)
I think we can add an optional parameter giving chance to include personalized ICON at this window of OptionBox()
But do not forget to:
  1. Remove NOSYSMENU at DEFINE WINDOW OPTIONBOX
  2. Change LOCAL cParentWindowName, nRet for LOCAL cParentWindowName, nRet: = 0 based on Theo example
  3. Add the 5th parameter and variable for ICON name
  4. Add ON RELEASE (nRet := 0) to the end of DEFINE WINDOW OPTIONBOX
  5. Changed MODAL by TOPMOST
  6. To fix Cancel option at line after Function OptionBox_Cancel(nRet) add nRet := 0.
    Otherwise always will wrong return the value of RadioGroup (never as zero) :|
To insure us about the changes, please review the attached example:
<Attached file was removed due there is a newest version ahead this topic (fixed bug)>
I hope you like it. :)
OptionBox()
There was two bugs due removing NOSYSMENU and missing pass variable as reference (@).
Button "x" for exit form interferes when be cRet equal to zero or when is valid radioGroup value.
So, I have disabled this button with:
SetProperty("OPTIONBOX","NOCLOSE",.T.)
And also was fixed/added OptionBox_Ok(@nRet) due cRet now is not PRIVATE as Theo has recommended.
Here's fixed version:
MsgBox.rar
Executable and source files
(1.24 MiB) Downloaded 315 times
Sorry for my mistake.
trmpluym
Re: OptionBox()
Post by trmpluym »
Perfect Pablo, the function improves everytime :D
Theo
OptionBox()
Bedankt Theo!
