HMG_Upper() function causes a memory leak
Hi Claudio,
I do not know well if this would helps to you in HMG_UPPER case:
Or if these C functions are acting under ANSI mode with UTF8 because cdp parameter.
Please check: hb_cdpnDupUpper(), hb_cdpnDupLower(), hb_cdpnDup2Upper(), hb_cdpnDup2Lower() or hb_strUpper() and hb_strLower()
ADDED LATER:
These other C functions: hb_strncpy(), hb_strncpyLower(), hb_strncpyUpper()
Re: HMG_Upper() function causes a memory leak
Pablo César wrote:Hi Claudio,
ADDED LATER:
Thanks Pablo.
I fixed the problem in hmg_upper and hmg_lower
KDJ
Post by KDJ »
srvet_claudio wrote: Wed Oct 05, 2016 1:50 pm I fixed the problem in hmg_upper and hmg_lower
Hi Claudio
Memory leaks are a serious problem in HMG.
I do not know how you solved it in hmg_upper and hmg_lower.
But I noticed that this occurs in all C functions, that uses HMG_parc, HMG_retc and HMG_storc macros.
So I checked this more accurately, and it seems to me that I was able to locate the bug.
HMG_UNICODE.h wrote:
   #define HMG_CHAR_TO_WCHAR(c)     ((c != NULL) ? hb_osStrU16Encode(c) : NULL)  // return WCHAR
      #define HMG_parc(n)            HMG_CHAR_TO_WCHAR (hb_parc(n))
      #define HMG_parvc(n,i)         HMG_CHAR_TO_WCHAR (hb_parvc(n,i))
      #define HMG_arrayGetCPtr(a,n)  HMG_CHAR_TO_WCHAR (hb_arrayGetCPtr(a,n))
   #define HMG_WCHAR_TO_CHAR(c)      hb_osStrU16Decode(c)                       // return CHAR
      #define HMG_retc(c)            hb_retc    (HMG_WCHAR_TO_CHAR(c))
      #define HMG_storc(c,i)         hb_storc   (HMG_WCHAR_TO_CHAR(c),i)
      #define HMG_storvc(c,l,n)      hb_storvc  (HMG_WCHAR_TO_CHAR(c),l,n)
      #define HMG_retclen(c,l)       hb_retclen (HMG_WCHAR_TO_CHAR(c),l)
      #define HMG_retc_buffer(c)     hb_retc_buffer (HMG_WCHAR_TO_CHAR(c))
      #define HMG_itemPutC(p, c)            hb_itemPutC      (p, HMG_WCHAR_TO_CHAR(c))
      #define HMG_itemPutCL(p, c, l)        hb_itemPutCL     (p, HMG_WCHAR_TO_CHAR(c), l)
      #define HMG_itemPutCConst(p, c)       hb_itemPutCConst (p, HMG_WCHAR_TO_CHAR(c))
      #define HMG_itemPutCLConst(p, c, l)   hb_itemPutCLConst(p, HMG_WCHAR_TO_CHAR(c), l)
      #define HMG_itemPutCPtr(p, c)         hb_itemPutCPtr   (p, HMG_WCHAR_TO_CHAR(c))
      #define HMG_itemPutCLPtr(p, c, l)     hb_itemPutCLPtr  (p, HMG_WCHAR_TO_CHAR(c), l)
set.c (in Harbour) wrote:
HB_WCHAR * hb_osStrU16Encode( const char * pszName )
   if( hb_vmIsReady() )
      PHB_CODEPAGE cdp = hb_vmCDP();
      if( cdp )
         HB_SIZE nLen, nSize;
         HB_WCHAR * pszBufferW;
         nLen = strlen( pszName );
         nSize = hb_cdpStrAsU16Len( cdp, pszName, nLen, 0 );
         pszBufferW = ( HB_WCHAR * ) hb_xgrab( ( nSize + 1 ) * sizeof( HB_WCHAR ) );
         hb_cdpStrToU16( cdp, HB_CDP_ENDIAN_NATIVE, pszName, nLen, pszBufferW, nSize + 1 );
         return pszBufferW;
   return hb_mbtowc( pszName ); /* No HVM stack */
Note that the buffer is initialized by using hb_xgrab function:
and it is nowhere released by hb_xfree.
Many thanks for the info. I will fixed
Congratulations guys.
This is teamwork, pure altruism and a lot of fellowship.
It is not enough to just criticize.
The guy, detects, looks for a possible solution and informs.
Perfect work of the two colleagues.
I love this kind of things. Congratulations Claudio and Krzysztof.
We are all winners when there is competence on both sides and a lot of humility.
I want to learn a lot from you.
Many thanks to both.
My best regards
quartz565
Post by quartz565 »
Best Regards,
Nikos.
os: Windows Server 2019 - 64
Pablo César wrote: Thu Jan 19, 2017 12:41 am
My best regards
Anand
Post by Anand »
Pablo César wrote: Thu Jan 19, 2017 12:41 am Congratulations guys.
Rightly said. It is the base of HMG. Congratulations to all who work hard for it.
Anand
Anand
quartz565
Post by quartz565 »
serge_girard wrote: Thu Jan 19, 2017 8:22 am+10
+1 :D
Best Regards,
Nikos.
