PathCompactPath
PathCompactPath
Yes, you're right. Thank you.
Re: PathCompactPath
Done. Two versions: one in C, second in HMG.
Please compare them.
- PathCompact.png (18.33 KiB) Viewed 4517 times
- PathCompact.zip
- (4.18 KiB) Downloaded 259 times
PathCompactPath
Perfect !!
Quite same speed (little time difference) when executing both.
PathCompact_C seems faster, but for really.
Just FYI, I have seen your hbp files Krzysztof and the proper way should be:
PathCompact_C.prg
or
PathCompact_HMG.prg
And in hbc files like this:
libs=shlwapi
When we want to compile by IDE and Build.bat in HMG.
I is really good.
I will not need to make automatic lenght. Because the example item "Compact path to control width" serves the same purpose.
Thank you very much Krzysztof. You're so kind and also competent.
PathCompact_C.prg
or
PathCompact_HMG.prg
libs=shlwapi
I is really good.
Re: PathCompactPath
Try provided below speed test.Pablo César wrote: ↑Sun Jan 15, 2017 9:42 pm Quite same speed (little time differance) when executing both.
It compares the functions that perform the same operations.
- SpeedTest.png (10.19 KiB) Viewed 4463 times
- SpeedTest.zip
- (1.6 KiB) Downloaded 243 times
PathCompactPath
So big difference !
I know it was faster...Pablo César wrote: ↑Sun Jan 15, 2017 9:42 pm Quite same speed (little time differance) when executing both.
But not how it much...
Thank you man !
Re: PathCompactPath
Very nice KDJ.
