Grid Sort (Function / Method)
Source code related resources
Re: Grid Sort (Function / Method)
A slight improvement to the procedure:
Now any grid column header can be clicked in ascending order. Immediately if you click again on the same column header it will be arranged in descending order.
Unicode arrow characters are suitably added to the column headers.
Claudio: Can we have a property to find out ColumnHeadClicked just like CellColClicked?
PROCEDURE SortGrid( cWindow , cGrid , nColumn, cSortAs, lDesc )
LOCAL L
LOCAL I
LOCAL aGrid := {}
local cHeader := ''
local nColCount := 0
local aJustify := {}
local aSorted := {}
default lDesc := .f.
default cSortAs := 'C'
default nColumn := 1
   domethod( cWindow, cGrid, 'DISABLEUPDATE' )
   cHeader := getproperty( cWindow, cGrid, 'ColumnHEADER', nColumn )
   if HB_URIGHT( cHeader, 2 ) == ' ▲' // already in ascending order. change to desc!
      lDesc := .t.
   if HB_URIGHT( cHeader, 2 ) == ' ▼' // already in descending order. change to asc!
      lDesc := .f.
   nColCount := getproperty( cWindow, cGrid, 'COLUMNCOUNT' )
   for i := 1 to nColCount
      cHeader := getproperty( cWindow, cGrid, 'ColumnHEADER', i )
      if HB_URIGHT( cHeader, 2 ) == ' ▲' .or. HB_URIGHT( cHeader, 2 ) == ' ▼' // remove the exising arrow
         cHeader := hb_usubstr( cHeader, 1, hmg_len( cHeader ) - 2 )
         setproperty( cWindow, cGrid, 'COLUMNHEADER', i, cHeader )
   next i
   WAIT WINDOW 'Sorting...' NOWAIT
   * Copy the grid content to an array.
   L := GetProperty ( cWindow , cGrid , 'ItemCount' )
   FOR I := 1 TO L
      AADD( aGrid , GetProperty( cWindow , cGrid , 'Item' , I ) )
   NEXT I
   * Then Sort The Array...
   if lDesc
      do case
      case cSortAS == 'C'
         aSorted := asort( aGrid, , , { |x, y| x[nColumn] > y[nColumn] } )
      case cSortAS == 'N'
         aSorted := asort( aGrid, , , { |x, y| val( x[nColumn] ) > val( y[nColumn] ) } )
      case cSortAS == 'D'
         aSorted := asort( aGrid, , , { |x, y| ctod( x[nColumn] ) > ctod( y[nColumn] ) } )
      endcase
      do case
      case cSortAS == 'C'
         aSorted := asort( aGrid, , , { |x, y| x[nColumn] < y[nColumn] } )
      case cSortAS == 'N'
         aSorted := asort( aGrid, , , { |x, y| val( x[nColumn] ) < val( y[nColumn] ) } )
      case cSortAS == 'D'
         aSorted := asort( aGrid, , , { |x, y| ctod( x[nColumn] ) < ctod( y[nColumn] ) } )
      endcase
   * Finally, Fill The Grid With The Sorted Array Content...
   DoMethod( cWindow , cGrid , 'DeleteAllItems' )
   FOR I := 1 TO L
      DoMethod( cWindow , cGrid , 'AddItem' , aSorted[I] )
   NEXT I
   if lDesc
      cHeader := cHeader + ' ▼'
      cHeader := cHeader + ' ▲'
   setproperty( cWindow, cGrid, 'COLUMNHEADER', nColumn, cHeader )
   domethod( cWindow, cGrid, 'ENABLEUPDATE' )
   * End
   WAIT CLEAR
jorge.posadas
Post by jorge.posadas »
Utilice tu funcion de SORTGRID, y ya me pone la flecha y me ordena el grid, pero si doy clic en la flecha no hace nada, yo implemente asi en mi codigo
SortGrid("Frm_ShowStates" ,"Grd_States" , 1, "C", .T. ) pero no funciona.
Use your SORTGRID function, and it makes me arrow and ordered me the grid, but if I click the arrow does nothing, so I implement in my code
SortGrid ("Frm_ShowStates", "Grd_States", 1, "C", .T.) Does not work.
Cordialmente
POSADAS SOFTWARE
Jorge Posadas Ch.
Programador independiente
Morelia, Mich.
M é x i c o .
Movil +52 44 3734 1858
SKYPE: jorge.posadasch
Rathinagiri wrote: Claudio: Can we have a property to find out ColumnHeadClicked just like CellColClicked?
I will investigate.
As you can see in the code, the fifth parameter is not used inside the function. Have you clicked repeatedly the same column and the ascending and descending order are working alternatively. Right?
jorge.posadas
I try differents test:
SortGrid("Frm_ShowStates" ,"Grd_States" , 1, "C",.F. )
SortGrid("Frm_ShowStates" ,"Grd_States" , 1, "C",.T. )
SortGrid("Frm_ShowStates" ,"Grd_States" , 1, "C")
I try diferents way
and any case dos no work. I'm using SQLITE
Cordialmente
POSADAS SOFTWARE
Jorge Posadas Ch.
Morelia, Mich.
M é x i c o .
Please try to use the following procedure. This will take care if the 5th parameter is present.
LOCAL L
LOCAL I
LOCAL aGrid := {}
local cHeader := ''
local aSorted := {}
   if pcount() < 5 // ldesc parameter not given
         lDesc := .t.
         lDesc := .f.
   next i
   FOR I := 1 TO L
   NEXT I
   if lDesc
      do case
      case cSortAS == 'C'
      case cSortAS == 'N'
      case cSortAS == 'D'
      endcase
      do case
      case cSortAS == 'C'
      case cSortAS == 'N'
      case cSortAS == 'D'
      endcase
   FOR I := 1 TO L
   NEXT I
   if lDesc
   * End
   WAIT CLEAR
Thanks Rathi !
KDJ
Post by KDJ »
Below I present a different solution (set HDF_SORTUP/HDF_SORTDOWN format in listview header).
#include 'hmg.ch'
FUNCTION Main()
  SET FONT TO 'MS Shell Dlg', 8
  OpenDB()
  DEFINE WINDOW MainWA;
    MAIN;
    WIDTH  380;
    HEIGHT 290;
    TITLE  'Grid - Sort Header';
    NOMAXIMIZE;
    NOSIZE
    DEFINE GRID CompGR
      ROW             10
      COL             10
      WIDTH          350
      HEIGHT         180
      HEADERS        {'RecNo', 'Name', 'Code', 'Price'}
      WIDTHS         {75, 110, 70, 70}
      CELLNAVIGATION .T.
      ROWSOURCE      'Comp'
      COLUMNFIELDS   {'RecNo()', 'Name', 'Code', 'Price'}
      JUSTIFY        {GRID_JTFY_RIGHT, GRID_JTFY_LEFT, GRID_JTFY_CENTER, GRID_JTFY_RIGHT}
    END GRID
    DEFINE BUTTON ExitBU
      ROW     200
      COL     140
      WIDTH    80
      HEIGHT   25
      CAPTION 'E&xit'
      ACTION  MainWA.RELEASE
    END BUTTON
    DEFINE MAINMENU
      DEFINE POPUP 'Set order'
        MENUITEM 'RecNo' ACTION SetOrder(1, .F.)
        SEPARATOR
        MENUITEM 'Name - ascending'  ACTION SetOrder(2, .F.)
        MENUITEM 'Name - descending' ACTION SetOrder(2, .T.)
        SEPARATOR
        MENUITEM 'Code - ascending'  ACTION SetOrder(3, .F.)
        MENUITEM 'Code - descending' ACTION SetOrder(3, .T.)
        SEPARATOR
        MENUITEM 'Price - ascending'  ACTION SetOrder(4, .F.)
        MENUITEM 'Price - descending' ACTION SetOrder(4, .T.)
      END POPUP
    END MENU
  MainWA.CompGR.RECNO := RecNo()
  MainWA.CompGR.ColumnONHEADCLICK(1) := { || SetOrder(1) }
  MainWA.CompGR.ColumnONHEADCLICK(2) := { || SetOrder(2) }
  MainWA.CompGR.ColumnONHEADCLICK(3) := { || SetOrder(3) }
  MainWA.CompGR.ColumnONHEADCLICK(4) := { || SetOrder(4) }
  SetOrder(2, .F.)
  MainWA.CENTER
  MainWA.ACTIVATE
FUNCTION SetOrder(nColumn, lDescend)
  LOCAL nOrder  := ordNumber(ordSetFocus())
  LOCAL nRecord := MainWA.CompGR.RECNO
  GridHeader_SetSort(MainWA.CompGR.HANDLE, nOrder + 1, 0)
  IF ValType(lDescend) != 'L'
    IF nColumn == 1
      lDescend := .F.
      lDescend := If(nOrder == nColumn - 1, ! ordDescend(nOrder), .F.)
  nOrder := nColumn - 1
  GridHeader_SetSort(MainWA.CompGR.HANDLE, nColumn, If(lDescend, -1, 1))
  ordSetFocus(nOrder)
  ordDescend(nOrder, NIL, lDescend)
  MainWA.CompGR.RECNO := nRecord
  MainWA.CompGR.REFRESH
FUNCTION OpenDB()
  LOCAL cDbf   := 'Comp.dbf'
  LOCAL cNtx   := 'Comp.ntx'
  LOCAL lIsDbf := File(cDbf)
  IF lIsDbf
    dbUseArea(NIL, NIL, cDbf)
    dbCreate(cDbf, {{'Name', 'C', 30, 0}, {'Code', 'C', 3, 0}, {'Price', 'N', 6, 2}})
    dbAppend()
    Comp->Name  := 'Main board'
    Comp->Code  := '002'
    Comp->Price := 120.34
    dbAppend()
    Comp->Name  := 'Processor'
    Comp->Code  := '004'
    Comp->Price := 97.95
    dbAppend()
    Comp->Name  := 'RAM'
    Comp->Code  := '006'
    Comp->Price := 204.58
    dbAppend()
    Comp->Name  := 'HDD'
    Comp->Code  := '008'
    Comp->Price := 142.71
    dbAppend()
    Comp->Name  := 'SSD'
    Comp->Code  := '010'
    Comp->Price := 316.94
    dbAppend()
    Comp->Name  := 'Graphics card'
    Comp->Code  := '012'
    Comp->Price := 143.48
    dbAppend()
    Comp->Name  := 'Power supply'
    Comp->Code  := '014'
    Comp->Price := 54.29
    dbAppend()
    Comp->Name  := 'PC case'
    Comp->Code  := '013'
    Comp->Price := 72.85
    dbAppend()
    Comp->Name  := 'Pendrive'
    Comp->Code  := '011'
    Comp->Price := 12.78
    dbAppend()
    Comp->Name  := 'Monitor'
    Comp->Code  := '009'
    Comp->Price := 315.61
    dbAppend()
    Comp->Name  := 'Keyboard'
    Comp->Code  := '007'
    Comp->Price := 16.92
    dbAppend()
    Comp->Name  := 'Mouse'
    Comp->Code  := '005'
    Comp->Price := 9.84
    dbAppend()
    Comp->Name  := 'Modem'
    Comp->Code  := '003'
    Comp->Price := 31.45
    dbAppend()
    Comp->Name  := 'Speakers'
    Comp->Code  := '001'
    Comp->Price := 43.59
  IF lIsDbf .and. File(cNtx)
    ordListAdd(cNtx)
    ordCreate(cNtx, 'Name',  'Name',  {|| Comp->Name},  .F. /*lUnique*/)
    ordCreate(cNtx, 'Code',  'Code',  {|| Comp->Code},  .F. /*lUnique*/)
    ordCreate(cNtx, 'Price', 'Price', {|| Comp->Price}, .F. /*lUnique*/)
  dbGoTop()
#pragma BEGINDUMP
  #include "HMG_UNICODE.h"
  #include <windows.h>
  #include <commctrl.h>
  #include "hbapi.h"
          //GridHeader_SetSort(nHWndLV, nColumn[, nType /*0==none, positive==UP arrow or negative==DOWN arrow*/]) -> nType (previous setting)
  HB_FUNC ( GRIDHEADER_SETSORT )
    HWND   hWndHD = (HWND) SendMessage((HWND) HMG_parnl(1), LVM_GETHEADER, 0, 0);
    INT    nItem  = hb_parni(2) - 1;
    INT    nType;
    HDITEM hdItem;
    hdItem.mask = HDI_FORMAT;
    SendMessage(hWndHD, HDM_GETITEM, nItem, (LPARAM) &hdItem);
    if (hdItem.fmt & HDF_SORTUP)
      hb_retni(1);
    else if (hdItem.fmt & HDF_SORTDOWN)
      hb_retni(-1);
      hb_retni(0);
    if ((hb_pcount() > 2) && HB_ISNUM(3))
      nType = hb_parni(3);
      if (nType == 0)
        hdItem.fmt &= ~(HDF_SORTDOWN | HDF_SORTUP);
      else if (nType > 0)
        hdItem.fmt = (hdItem.fmt & ~HDF_SORTDOWN) | HDF_SORTUP;
        hdItem.fmt = (hdItem.fmt & ~HDF_SORTUP) | HDF_SORTDOWN;
      SendMessage(hWndHD, HDM_SETITEM, nItem, (LPARAM) &hdItem);
#pragma ENDDUMP
KDJ wrote: Wed Jan 11, 2017 8:03 pm Below I present a different solution (set HDF_SORTUP/HDF_SORTDOWN format in listview header).
#include 'hmg.ch'
FUNCTION Main()
  OpenDB()
    MAIN;
    WIDTH  380;
    HEIGHT 290;
    NOMAXIMIZE;
    NOSIZE
    DEFINE GRID CompGR
      ROW             10
      COL             10
      WIDTH          350
      HEIGHT         180
      CELLNAVIGATION .T.
      ROWSOURCE      'Comp'
    END GRID
      ROW     200
      COL     140
      WIDTH    80
      HEIGHT   25
      CAPTION 'E&xit'
    END BUTTON
    DEFINE MAINMENU
        SEPARATOR
        SEPARATOR
        SEPARATOR
      END POPUP
    END MENU
  SetOrder(2, .F.)
  MainWA.CENTER
  MainWA.ACTIVATE
    IF nColumn == 1
      lDescend := .F.
  ordSetFocus(nOrder)
FUNCTION OpenDB()
  IF lIsDbf
    dbAppend()
    Comp->Code  := '002'
    dbAppend()
    Comp->Code  := '004'
    dbAppend()
    Comp->Name  := 'RAM'
    Comp->Code  := '006'
    dbAppend()
    Comp->Name  := 'HDD'
    Comp->Code  := '008'
    dbAppend()
    Comp->Name  := 'SSD'
    Comp->Code  := '010'
    dbAppend()
    Comp->Code  := '012'
    dbAppend()
    Comp->Code  := '014'
    dbAppend()
    Comp->Code  := '013'
    dbAppend()
    Comp->Code  := '011'
    dbAppend()
    Comp->Code  := '009'
    dbAppend()
    Comp->Code  := '007'
    dbAppend()
    Comp->Code  := '005'
    Comp->Price := 9.84
    dbAppend()
    Comp->Code  := '003'
    dbAppend()
    Comp->Code  := '001'
    ordListAdd(cNtx)
  dbGoTop()
#pragma BEGINDUMP
  #include "hbapi.h"
    INT    nType;
    HDITEM hdItem;
      hb_retni(1);
      hb_retni(-1);
      hb_retni(0);
      if (nType == 0)
      else if (nType > 0)
#pragma ENDDUMP
Very Nice!!
PD:The refence is: https://msdn.microsoft.com/en-us/librar ... s.85).aspx
Nice, Thx for sharing
