Si Pablo César,
Estaría muy bien o que al hacer control+Click seleccionara un control más! y cambiar propiedades semejantes como dices!!!
HMG IDE - Suggestions
Re: HMG IDE - Suggestions
It would be great to have possibility to move selected controls into another place. Sometimes I need to insert new control between already defined.
Si estaria muy bueno eso tambien. Pero sugiero apenas hacerlo por lo menos atravéz de un listbox (para facilitar), pero creo que nos vamos morir y no vamos poder hacer nada con la IDE de HMG...Javier Tovar wrote:o que al hacer control+Click seleccionara un control más!
Wow Marek ! I never though about it, nice feature it would be !mol wrote:It would be great to have possibility to move selected controls into another place. Sometimes I need to insert new control between already defined.
Thank you guys for your interest a nice ideas !
Controls should be selected by selecting region by mouse (difficult to do, IMO), or by clicking with SHIFT key pressed - easy to realize.
I'd like to add one more idea that might be of great use.
We use IDE to elaborate our projects, compile and also as a form designer. So it was in this last option as a resource that could the IDE from the command line, accept to edit FMG files without having to open any project. At the same time it accepts hbp file as parameter that would accept this extension and release for editing/modifying fmg files too.
This would make it easier for those who keep screens in separate folders to the project or even those who just want to patch the screenshots.
This idea is very good!. I'd like to add one idea again .
When create FMT files, by the user to select the file mode(UNICODE or ANSI).
Now is possible thru Call_IDE app to support it.Pablo César wrote: ↑Fri Nov 08, 2013 11:26 pm 13. When start creating a new project, automatically creates the main.prg file. So is it posible to create with the same name of project as main source file ?
For more details and download at: viewtopic.php?f=10&t=5084
