HMG 3.4.3
Re: HMG 3.4.3
I've found strange behaviour of grid.
It's impossible to edit last column of grid which width is equal or less to sum of widths of all columns (remember, vertival lines separating columns count too as 1 px) by pressing ENTER key. When you double click with mouse, everything is OK.
I've lost half a day for this :evil: :oops: :x
Try my little sample
local i
private aHeaders, aWidths, aJust
private aRows := {}
private aValid := {}
private aWhen := {}
private aControls := {}
	aHeaders := {"Name","Age"}
	aWidths := {200, 100}
	aJust := { 0,1}
	aValid	:= { {|| DataValidation()},  {|| DataValidation()} }
	aWhen	:= { {|| .t.}, {||.t.} }
	aControls := { {"TEXTBOX","CHARACTER"}, {"TEXTBOX","NUMERIC","999"} }
	aADD(aRows, {"Simpson", 65 } )
	aADD(aRows, {"Mulder",41 } )
	aADD(aRows, {"Smart Max", 25} )
		WIDTH 500 ;
		HEIGHT 550 ;
		TITLE 'Editable Virtual Grid Test' ;
		@ 10,10 GRID Grid_1 ;
			WIDTH 300 ;
			HEIGHT 240 ;
			HEADERS aHeaders ;
			WIDTHS aWidths;
			VALUE {1,1} ;
			TOOLTIP 'Editable Grid Control' ;
			EDIT ;
			COLUMNCONTROLS aControls;
			COLUMNVALID aValid;
			COLUMNWHEN aWhen;
			VIRTUAL ;
            ITEMCOUNT len(aRows) ;
            ON QUERYDATA OnQuery() ;
	        JUSTIFY aJust;
			CELLNAVIGATION
		@ 400, 10 BUTTON B_1 ;
			CAPTION "EXPAND GRID +10px";
			ACTION SetProperty("Form_1","Grid_1","Width", GetProperty("Form_1","Grid_1","Width")+10) ;
			WIDTH 120 ;
			HEIGHT 30
	Form_1.Grid_1.EditOption := GRID_EDIT_REPLACEALL
	CENTER WINDOW Form_1
function OnQuery
	local nRow, nCol
	nRow := This.QueryRowIndex
	nCol := This.QueryColIndex
	if nRow>0 .and. nCol >0
		This.QueryData := aRows[nRow,nCol]
return .t.
function DataValidation
	nRow := this.Value[1]
	nCol := this.Value[2]
	if empty(This.CellValue)
		return .f.
	aRows[nRow,nCol] := This.CellValue
return .t.
Re: HMG 3.4.3
My another question is:
Is it possible to use different colors for two grids in one form?
I'm changing color by set of calls:
	CellNavigationColor ( _SELECTEDROW_FORECOLOR, {255,255,255} )
	CellNavigationColor ( _SELECTEDROW_BACKCOLOR, {0,196,128} )
	CellNavigationColor ( _SELECTEDCELL_BACKCOLOR, {0,128,0} )
	CellNavigationColor ( _SELECTEDROW_DISPLAYCOLOR, .t. )
My idea was to call these function everytime when grid gets focus. But, colors changes for two grids simultanously. (when changing actice grid with Tab key - colors stay as defined, but when moving focus with mouse - two grid changes.
Re: HMG 3.4.3
mol wrote:I've found strange behaviour of grid.
local i
private aRows := {}
private aWhen := {}
	aJust := { 0,1}
		WIDTH 500 ;
		HEIGHT 550 ;
			WIDTH 300 ;
			HEIGHT 240 ;
			HEADERS aHeaders ;
			WIDTHS aWidths;
			VALUE {1,1} ;
			EDIT ;
			COLUMNVALID aValid;
			COLUMNWHEN aWhen;
			VIRTUAL ;
	        JUSTIFY aJust;
			CELLNAVIGATION
			WIDTH 120 ;
			HEIGHT 30
function OnQuery
	local nRow, nCol
return .t.
		return .f.
return .t.
I will check.
Re: HMG 3.4.3
mol wrote:My another question is:
HMG uses a single global color for all grid controls.
Thank you for answer
huiyi_ch
Hmg.3.4.3 The Chinese can not be correctly read into the table
Post by huiyi_ch »
Hmg.3.4.3不能将中文正确读入表中
请看下面例子:
假如我要把下列文本添加到表中:
People2.txt(CHINESE、AMERICANE、RUSSIAN、JAPANINESE)
运行程序后可将文本正确读入表中.
如果我想把下列中文文本添加到表中:
People1.txt(中国、美国、俄国、日本)
程序将不能正确读入表中。
Consider the following example:
Suppose I want to add the following text to the table
After the program can be run correctly read the text into the table,
If I want to add the following Chinese text to the table:
The program will not be correctly read into the table.
open_table("2")
dbEval({||msginfo(PEOPLES->PEOPLE)})
use
open_table("1")
USE
function open_table(ctype)
local astru:={{"PEOPLE","c",30,0}}
dbCreate("PEOPLES",astru)
use PEOPLES new
if ctype="1"
append from PEOPLES1.txt delimited
append from PEOPLES2.txt delimited
return
test.rar
main.prg
(632 Bytes) Downloaded 277 times
Re: HMG 3.4.3
People1.txt is encoded as ANSI. Please encode it as UTF-8 and try.
huiyi_ch
Re: HMG 3.4.3
Post by huiyi_ch »
Thank you for your answer, however, will the file with Chinese save as utf8 format can not read correctly into the table too.
Re: HMG 3.4.3
Can you send me the saved utf file? I shall try.
huiyi_ch
Re: HMG 3.4.3
Post by huiyi_ch »
Of course! Please receive.
PEOPLES1.rar
(111 Bytes) Downloaded 276 times
