HMG GridPlus - New Version
This is a new version of GridPlus.
The following are the new features:
- Printing part of Grid
- Font Selection for Headers, footer and main report
- Grouping
- Column Sum
Soon, I have to create some demos and documentation and make it into a full fledged library. Until then test play with it! Please don't forget to report the bugs
Addendum: I have uploaded a new version here. viewtopic.php?p=47913#p47913
- Grouping
- Column Sum
Re: HMG GridPlus - New Version
Hello Rathi, I get a compile error at line 2587 pp.redraw() syntax error.
Are you using the latest version ie., HMG3.4.3 ?
Compiled w/o error
Column sum showing incorrect result, Group on Date is on showing properly after 2 or 3 date
Rathi, It works, I was using 342 instead of 343. Sorry!!
Especially Report Config is amazing!!
Hi!
I've compiled with hmg343 ansi.
I've changed paper to landscape and tried to scroll pp panel window and strange things with this window are happening.
I thnk something is wrong with HMG because I observe the same problems in my app while using panel window.
Marek, Indeed me too have the same phenomenon when maximizing Report Config all went strange and had I kill the app.
Gracias por compartir Rathi !!!!
I am uploading the latest version now.
Change log:
- Grouping and ColumnSum Bug fixed
- Page Center and Whitespace Spread options
- Included two demos.
Now, it is almost getting into the shape.
Change log:
