GetControlType in CHECKBUTTON
Recently I found there was not any demo for CHECKBUTTON at SAMPLES. This is not terrible but following bug occurrs for a very long time... (probably before 3.0.35) :shock: :
Function Main()
   WIDTH 200 ;
   HEIGHT 200 ;
   MAIN;
   TITLE 'CheckButton Test'
   @ 20,20 CHECKBOX CheckBox_1 CAPTION "Control Type" WIDTH 150 HEIGHT 50 ;
           ON CHANGE MsgInfo("Control type: "+GetControlType("CheckBox_1","Form_1"),(This.Name))
   @ 70,20 CHECKBUTTON CheckButton_1 CAPTION "Control Type" WIDTH 150 HEIGHT 50 ;
           ON CHANGE MsgInfo("Control type: "+GetControlType("CheckButton_1","Form_1"),(This.Name))
CENTER WINDOW Form_1
In this demo the result should be CHECKBUTTON not CHECKBOX, right ?
At least in HMG/IDE we have these names for control types. Or am I wrong about it ?
I've checked at C:\hmg.3.4.3\SOURCE\h_checkbox.prg and _DefineCheckButton function is declared IMO wrongly as "CHECKBOX" :o
Ths same occurs at HMG Extended. Please note Mr. Filatov
Re: GetControlType in CHECKBUTTON
I will check
srvet_claudio wrote:I will check
Siempre guardo mi más alta consideracion por todo lo que haces por nosotros.
Lo siento Claudio por darte más trabajo... :|
Images and codes proves that is wrong control type for CheckButtons (for long time... :o )
MsgInfo("Control type: "+GetControlType("CheckButton_1","Form_1"),(This.Name)) => "CHECKBOX" :?:
This is not a bug :)
CheckBox and CheckButton are both defined on "h_checkbox.prg", because they are (basically) the same control (exactly the same behavior) with different styles.
The following was a deliberate design decision:
_HMG_SYSDATA [1] [k] := "CHECKBOX"
The most important thing:
GetControlType() IS AN INTERNAL FUNCTION, NOT AIMED TO BE EXPOSED TO THE FINAL USERS, THIS IS THE REASON BECAUSE I'VE NOT INCLUDED IN THE DOCUMENTATION.
Advanced users, digging in HMG internals, will find their way to (if required) differentiate both controls.
Please, don't fix something that is not broken :)
Sorry to disagree. :oops: Is not broken but wrongly working... :?
You said not exposed before because there was a fail?
Its means that we should not use GetControlType() ?
Because we can not trust in GetControlType().
So, what about GetProperty() ? We should not use neither ?
Please note this another demo:
Function Main()
   WIDTH 200 ;
   HEIGHT 200 ;
   MAIN;
           ON CHANGE MsgInfo("Control type: "+GetProperty("Form_1","CheckBox_1","TYPE"),(This.Name))
//            ON CHANGE MsgInfo("Control type: "+GetControlType("CheckBox_1","Form_1"),(This.Name))
           ON CHANGE MsgInfo("Control type: "+GetProperty("Form_1","CheckButton_1","TYPE"),(This.Name))
//           ON CHANGE MsgInfo("Control type: "+GetControlType("CheckButton_1","Form_1"),(This.Name))
Please Roberto, give us a good reason to understand it better and turn up the failed info for a good one. Because for me to know what type is the control is IMPORTANT. Is not a private case. In the future others will find same problem, of course there is a way to turn around but IMHO this is not good.
Dear Rathinagiri,
I love this forum... I want to be here... I'm happy here... but I'm relly sick to be constantly 'bullied' over the years via various kinds of aggressions...
Please... I want to stay here... but, if this is the price... maybe not...
Roberto Lopez wrote: Please, don't fix something that is not broken :)
OK, no problem.
Roberto Lopez wrote:but I'm relly sick to be constantly 'bullied' over the years via various kinds of aggressions...
Why you felt bullied Roberto? From my side It's nothing personal. I make my arguments and I asked for your opinion... :oops:
Pablo,
I think Roberto had explained to you rightly.
But you still hang on the same thing that is why he feels he is bullied. Any body will be.
See his words. GetControlType, like Handle, ControlEvents are for advanced users who has some knowledge about C.
HMG is simple simply because it is a wrapper around the Win32API. An ordinary user needs not to go beyond HMG main functions.
Only when we need to write some tools (like yours) we need to go beyond HMG internals. If you make a small dig, you can differentiate things.
Even after going through the internals if you can't find the difference you might have come with the question where to find such difference.
GetProperty() is also a wrapper for HMG controls as you know. There also TYPE property is touching internal.
So, when the developer who had actually developed that code tries to explain something, please give your thought and effort on that.
