HMG 3.4.3
huiyi_ch
Re: HMG 3.4.3
Post by huiyi_ch »
各位前辈,各位同仁:你们好,
我发现GetstartupFolder()函数存在BUG,请看例子:假定该程序运行在“D:\中国”文件下:
REQUEST HB_CODEPAGE_GBK
Function Main()
msginfo(GetStartUpFolder(),"1")
hb_CdPSelect("GBK")
msginfo(GetStartUpFolder(),"2")
return nil
运行结果:
发现输出结果不相同!
但如果使用函数GetCurrentFolder()代替Getstartupfolder(),结果是正确的!
我的解决办法:
修改文件h_controlmisc.prg 第4853行
Return HB_ULEFT ( StartUpFolder , HB_UTF8RAT ( '\' , StartUpFolder ) - 1 )
为:
Return LEFT ( StartUpFolder , RAT ( '\' , StartUpFolder ) - 1 )
重新构建LIB库,再重新编译运行程序,显示结果正常。
Re: HMG 3.4.3
Something is wrong, when I try to compile Roberto sample netio server. I'm getting error after starting application.
Error description:
Date:09/27/16 Time: 13:34:57
Error BASE/1132 Bound error: array access
Called from EVENTPROCESSHMGWINDOWSMESSAGE(240)
Called from INIT(834)
Called from ERRORSYS(59)
Called from __HBVMINIT(0)
Code is very simple:
LOCAL nPort		:= 50000
LOCAL cIfAddr		:= '0.0.0.0'
LOCAL cRootDir		:= '.'
LOCAL lRPC		:= .T.
LOCAL cPasswd		:= 'secret'
LOCAL nCompressionLevel	:= 9
LOCAL nStrategy		:= NIL
LOCAL pSockSrv		:= NIL
	* Start Server
	pSockSrv := NETIO_MTSERVER( nPort , cIfAddr , cRootDir , lRPC , cPasswd , nCompressionLevel , nStrategy )
	if empty( pSockSrv )
		MSGSTOP("Can't Start Server!")
       //Load Window Main
	DEFINE WINDOW MainForm ;
        AT 50,50 ;
        WIDTH 500 HEIGHT 300 ;
        TITLE 'Netio Serwer' ;
		Main  ;
		NOSIZE
	END Window
        MainForm.Activate
	* Stop Server
	netio_serverstop( pSockSrv , .t. )
I've compiled app using hmg342 and everything is OK
Re: HMG 3.4.3
mol wrote:Something is wrong, when I try to compile Roberto sample netio server. I'm getting error after starting application.
Error description:
LOCAL lRPC		:= .T.
	* Start Server
       //Load Window Main
        AT 50,50 ;
		Main  ;
		NOSIZE
	END Window
        MainForm.Activate
	* Stop Server
I will check .
I think I have an idea of ​​what it can be.
Re: HMG 3.4.3
I think I mistake hmg version and tried to compile with hmg 340 :)
Sorry for this false alert :)
Re: HMG 3.4.3
mol wrote:I think I mistake hmg version and tried to compile with hmg 340 :)
Ok, not problem.
Leopoldo Blancas
Re: HMG 3.4.3
Post by Leopoldo Blancas »
Hola a Todos:
Este es mi primer día en HMG y es como "volver a empezar", gracias por esta nueva versión!!!
Hello everyone:
This is my first day as HMG and "start over", thank you for this new version !!!
HMG 3.4.3
Hola Leopoldo, bien venido !
nguyenchiduc
Re: HMG 3.4.3
Post by nguyenchiduc »
About Netio
I dont know why version 3.4.3 , 3.4.2 , 3.4.1 , I see config NetIO Servert is: C:\Project\NEIOServer\DataBase
I don't have C:\Project folder in my PC
When I edit database path is c:\temp and copy some file dbf in c:\temp but NetIO Client dont see !?
I use Window 8 , 32 bit
loi Netio.jpg (21.71 KiB) Viewed 8011 times
Re: HMG 3.4.3
You have to change Config.ini file located at "C:\hmg\SAMPLES\Miscellaneous\NETIO\NETIO_02\HmgNetIOServer"
nguyenchiduc
Re: HMG 3.4.3
bpd2000 wrote:You have to change Config.ini file located at "C:\hmg\SAMPLES\Miscellaneous\NETIO\NETIO_02\HmgNetIOServer"
Thank you
I fogot insert some dbf files in includes form before compiler by IDE
NetIO Server.png (61.97 KiB) Viewed 7997 times
