Webcam Testing. Wish to improve
gfilatov
Re: Webcam Testing. Wish to improve
Post by gfilatov »
brain wrote: Kindly send the necessary library for this function. tnx and more power.
You can not to compile the above code in HMG because it is for a fork MiniGUI Ex at http://hmgextended.com.
Please be so kind to try the code which was kindly uploaded by Mustafa.
Thanks to Grigory and Claudio for including into HMG!!
brain
Post by brain »
good day mr gfilatov run ur demo.exe and this is what happened
brain
Post by brain »
and for mr Mustafa good day too. I ran your program too and nothing happened too. tnx for sharing.
quartz565
Post by quartz565 »
I found no problems with both programs.
Have you press the button top of the screen ?
Best Regards,
Nikos.
os: Windows Server 2019 - 64
brain
Post by brain »
hi quartz good day. try run the program on a 64bit OS like what I am using windows 10. tnx and more power HMG.
Funciona bien Mustafa , esta basado en la dll avicap32.dll
estaria bueno usar IWiavideo de Microsoft
https://msdn.microsoft.com/en-us/librar ... s.85).aspx
perdon :
Note WIA does not support video devices in Windows Server 2003, Windows Vista, or later. For those versions of the Windows, use DirectShow to acquire images from video.
vagblad
DBs Used: MySQL,DBF
Post by vagblad »
Hi all,
We've tried the app on the following systems:
Windows Server 2012 R2 x64
Windows 10 x64
Windows 8.1 x32
Works fine in all of the above systems with a usb camera.
The only problem we had was with windows 8.1 x32bit on a tablet which has 2 internal cameras. We couldn't make it to work with those 2 cameras. Worked fine with the usb one though.
Best regards
Vagelis Prodromidis
radohabjan
Post by radohabjan »
Hi all,
is it possible to make just a Picture from camera ?
br Rado
Hola amigos:
Hacia tiempo que me gustaria tener una base de datos donde al dar de alta o modificación de la ficha
se pudiera inconporar la foto de dos formas , en directo mediante la webcam a modo de maquina
de fotos o incorporar en la ficha una foto previamente guardada anteriormente.
El sample que presento por el compañero brain en: viewtopic.php?f=14&t=4862&hilit=brain
me ha servido de base para presentaros mi aportación DBF_Sample_WebCam , ver configuración en carpeta
Help_WebCam.
Todas las demas opciones no me funcionan con la configuración "Microsoft WDM image Capture (Win32)"
Solamente me esta funcionando con esta configuración de Adobe Flash Player.
A ver si os puede interesar
Hello friends:
For some time I would like to have a database where when registering or modifying the file
the photo could be taken in two ways, live through the webcam as a machine
of photos or incorporate in the file a photo previously saved previously.
The sample I present for the fellow brain at: viewtopic.php?f=14&t=4862&hilit=brain
It has served as a base to present my contribution DBF_Sample_WebCam, see configuration in folder
Help_WebCam
All other options do not work for me with the "Microsoft WDM image Capture (Win32)" setting
It's just working for me with this Adobe Flash Player configuration.
To see if you can be interested
DBF_Sample_WebCam.zip
(1.37 MiB) Downloaded 475 times
