Webcam Testing. Wish to improve
brain
Post by brain »
I want to share my work about webcam. I wish there is someone who can share a better work than mine which runs in a 64bit OS without using HTML.
Make sure you have webcam attached to your pc and working properly
TESTCAM.zip
(198.04 KiB) Downloaded 785 times
Instructions:
Compile and run the program
Click Allow
If you want not to ask again every time you run the program right click to the moving object
then check the Remember
Re: Webcam Testing. Wish to improve
Perfecto!!!
gracias por compartir Brain!!!!
danielmaximiliano wrote:Perfecto!!!
gfilatov
Post by gfilatov »
Hello Brain,
Thanks for sharing your interested work!
The Minigui Extended Edition have an internal support of the primary Webcam with the following simple command:
@ <row>,<col> WEBCAM <Camera> [ OF <parent> ] ;
[ WIDTH <nWidth> ] [ HEIGHT <nHeight> ] ;
[ RATE <nRate> ] [ START ]
Please take a look for a working attached sample application :arrow:
Your feedback is welcome :!:
WebCam.zip
Sample application along with a source
(736.38 KiB) Downloaded 585 times
Thanks for sharing Grigory!
Is it hard to achieve the same in HMG?
gfilatov
Post by gfilatov »
serge_girard wrote:Thanks for sharing Grigory!
Hi Serge,
Thanks for your interest!
It is possible, of course, because a WebCam control is based upon the simple C-wrappers to the CAP WinAPI.
And it is an open source also ;)
Thanks!
gfilatov wrote:Hello Brain,
Thanks Grigory, I will include in HMG.
brain
Post by brain »
hi mr filatov. I compiled your program and it is what happened.
Kindly send the necessary library for this function. tnx and more power.
Hola brain:
Encontré en mis prgs, este Sample que alguien
publicó en esta Web.he visto que no da Error al Compilar
pero no puedo probarlo porque no tengo Web_Cam
Hello brain
I found in my PRGS, this Sample someone
He published in this Web.he seen that does not Compiling Error
but I can not prove it because I have Web_Cam
Webcam_Hmg.zip
(15.09 KiB) Downloaded 518 times
