HMG Case
Steed
Re: HMG Case
Post by Steed »
Gracias
luisvasquezcl
Re: HMG Case
Post by luisvasquezcl »
Dragan, great job.
Thanks for sharing.
Luis Vasquez
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: HMG Case
Post by dragancesu »
If some benefits here are new versions of program and the icons
add.zip
(13.52 KiB) Downloaded 483 times
hmgcase.zip
(1.66 MiB) Downloaded 496 times
Re: HMG Case
It really looks neat.
Thanks for sharing. Will try to implement like this for sqlite/mysql.
dragancesu
Re: HMG Case
I have this tool for MySQL, is not perfect when creating SQL commands and is not shared here
Re: HMG Case
Rathinagiri wrote:It really looks neat.
Re: HMG Case
Hola dragan, Thank
dragancesu
Re: HMG Case
This is preview version HMG Case for MySQL
and you need libmysql.dll from mysql instalation
myhmg.zip
(1.63 MiB) Downloaded 476 times
dragancesu
Re: HMG Case
@Rathinagiri
I was try with MySQL and SQLite, first step is read table definition, mysql is OK but read table definition from sqlite is not elegant
Re: HMG Case
Why not?
I have sqlite2dbf and dbf2sqlite utilities. 'PRAGMA table_info' is the command.
Here you can get the source code of the above. viewtopic.php?p=20587#p20587
