Thanksmol wrote:Browse control crashes when FORMATS are used to change display of numeric columns.
I've modified a little BrowseUpdate function h_browse.prg for good work.
Against at BROWSE is obsolete (I'm still using it...), it would be great to have it without errors.
I'm attaching sources
HMG 3.4.3
- srvet_claudio
Re: HMG 3.4.3
Re: HMG 3.4.3
Hi Dr. Claudio
我又发现了一个问题,当我在HMG-UNICODE下编译C:\hmg.3.4.3\SAMPLES\Controls\RichEditBox\DEMO.PRG ,RichEditBox 运行正常.但是当我在HMG-ANSI模式下,重新编译这个例子时,RichEditBox 运行不正常.
I found a problem, when I compile C:\hmg.3.4.3\SAMPLES\Controls\RichEditBox\DEMO.PRG under HMG-UNICODE mode, RichEditBox works fine. But when I recompile this example under HMG-ANSI mode, RichEditBox works abnormal. My English is very poor, so please forgive me.
- rich_demo.JPG (142.61 KiB) Viewed 7697 times
- srvet_claudio
Re: HMG 3.4.3
I will check.huiyi_ch wrote:Hi Dr. Claudio
- luisvasquezcl
Re: HMG 3.4.3
Hola estimados, no sé si es un error o no, pero el ide de esta versión tiene un comportamiento raro, aunque no se da constantemente.
Al minimizar el ide y restaurarlo despues de un tiempo, se desaparen los botones de los controles y la barra de menú. Posteriormente, al volver a minimizar y restaurar comenzó a aparecer la barra de menú pero las opciones de cada menú no aparecían. incluso en un momento la ventana de los submenu se puso en negro.
a alguien le ha pasado?
Estoy usando Windows 7 32 bits.
Hmg 3.4.3.
Saludos cordiales,
Luis Vásquez.
Hello dear, I do not know if it is a mistake or not, but the ide of this version has a rare behavior, although not always given.
By minimizing the ide and restore it after a while, the buttons on the controls and menu bar desaparen. Later, returning to minimize and restore began to appear the menu bar but the options for each menu did not appear. even at a time when the submenu window put in black.
someone has happened to him?
I'm using Windows 7 32-bit.
HMG 3.4.3.
Luis Vasquez.
Hmg 3.4.3.
Saludos cordiales,
Luis Vásquez.
HMG 3.4.3.
Luis Vasquez.
Re: HMG 3.4.3
Regarding the IDE, I too have the same experience!
Re: HMG 3.4.3
+1luisvasquezcl wrote:Hola estimados, no sé si es un error o no, pero el ide de esta versión tiene un comportamiento raro, aunque no se da constantemente.
Hmg 3.4.3.
Saludos cordiales,
Luis Vásquez.
HMG 3.4.3.
Luis Vasquez.
meme chose pour moi ( the same for me)
I'm using Windows 10 64-bit.
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
Y.TABET
- srvet_claudio
Re: HMG 3.4.3
A user reported that the problem is solved by opening the section as administador.
Re: HMG 3.4.3
mercisrvet_claudio wrote:A user reported that the problem is solved by opening the section as administador.
I am going to try it
Y.TABET
Y.TABET
Re: HMG 3.4.3
Hi
meme dans HMG3.4.2 cela a commencer a le faire après le PATCH 4
translation google
even in HMG 3.4.2 it started to do it so after the PATCH 4
I'm sorry ,I wanted to say ,it's started after "the new version of IDE (ver 1.1)"
Best regards
translation google
Best regards
Y.TABET
Y.TABET
Re: HMG 3.4.3
Thanks a lot for all your work!!!
I have a installation that function without problems in 32 and 64 bits.
Excellent!!!
Excellent!!!
