Notepad++ Function List
Tiger
Re: Notepad++ Function List
Post by Tiger »
Hi Marc,
I do some modifications on your files, please unpack the attached file to the folder of notepad++. You might need to import the hmg.xml file again. Try to open a .prg file and if the function list is empty then select the "HMG" langauge file again and close the notepad++. Open again the prg file with notepad++ and click the icon of functionlist to "on" "off" this function. It should work. Good luck.
I think the relation between these two "xml" file is as below:
function_hmg.rar
(8.38 KiB) Downloaded 696 times
TopsMarc
Post by TopsMarc »
Hi Tiger,
It works ! Thank you very very much :D
Best regards, Marc
tonton2
Post by tonton2 »
TopsMarc wrote:Hi Tiger,
Best regards, Marc
Hello
I think the problem lies in the new version (6.9.2) and not in the functionlist.
Check if your notpad ++. Exe is the new or the old?
Thank you
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
Tiger
Post by Tiger »
Hi Y.TABET,
Do you try my suggestion to see if it works?
If you can get this function work on old version such as the 6.8xx, you can download the new version 6.9.2 with "zip" file and then unpack to a temporary folder. You can then copy all the files except the "functionList.xml" and paste them back to the folder of NOTEPAD++. I am using the new version 6.9.2 and I use this way to upgrade the NOTEPAD++ every time.
tonton2
Post by tonton2 »
Tiger wrote:Hi Y.TABET,
Hello Tiger
Yes but does not work,it works with old version
thanks
Y.TABET
tonton2
Post by tonton2 »
Hi Tigercan you check if you have notepad.exe 6.9.2 version in the folder NOTEPAD ++
thank you
Y.TABET
Tiger
Post by Tiger »
FYI. I am using the version 6.9.2
tonton2
Post by tonton2 »
thanks
Y.TABET
jayadevu
Post by jayadevu »
Many thanks for the update.
Following 2 updates also need to be made:
1. If you prefix the function name with "Static": it does not show up in the function list.
2. Harbour Class and Methods also do no show up in the function list.
Hope one of the Gurus will chip in with their expertise.
Warm regards,
Jayadev
Tiger
Post by Tiger »
jayadevu wrote:Hi,
Warm regards,
Jayadev
Hi Jayadev,
Please try this ...
<parser id="HMG" displayName="HMG" commentExpr="">
<function
mainExpr="^[+\h]*(static\h+)?(CLASS|Func|Function|Proc|Procedure)[\t ]+[^\r\n]*$"
displayMode="$functionName">
<functionName>
<nameExpr expr="(?(?=[\t ]*)[\t ]*[\t ]+[^\s]+\w+[^\r\n]*)"/>
</functionName>
</function>
</parser>
