HMG 3.4.3
Re: HMG 3.4.3
serge_girard wrote:Claudio,
I use it as following:
FOR A = 1 TO LEN(acTitles)
	GRID_SetColumnControl ("Grid_Materiaal", "Form_PR004A", _GRID_COLUMNCAPTION_, A, acTitles [A])
NEXT A
Then I get this error:
C:/Users/GEBRUI~1/AppData/Local/Temp/hbmk_0c2ksu.dir/pr004.o:pr004.c:(.data+0x598): undefined reference to `HB_FUN_GRID_SETCOLUMNCONTROL'
hbmk2[sporserv]: Error: Running linker. 1
gcc.exe C:/Users/GEBRUI~1/AppData/Local/Temp/hbmk_0c2ksu.dir/ss000.o C:/Users/GEBRUI~1/AppData/Local/Temp/hbmk_0c2ksu.dir/pr004.o C:/Users/GEBRUI~1/AppData/Local/Temp/hbmk_0c2ksu.dir/ss001.o C:/Users/GEBRUI~1/AppData/Local/Temp/hbmk_0c2ksu.dir/ss002.o C:/Users/GEBRUI~1/AppData/Local/Temp/hbmk_0c2ksu.dir/ss00716.o C:/Users/GEBRUI~1/AppData/Local/Temp/hbmk_0c2ksu.dir/ss015.o C:/Users/GEBRUI~1/AppData/Local/Temp/hbmk_0c2ksu.dir/ss020.o C:/Users/GEBRUI~1/AppData/Local/Temp/hbmk_0c2ksu.dir/ss022.o C:/Users/GEBRUI~1/AppData/Local/Temp/hbmk_0c2ksu.dir/ss025.o C:/Users/GEBRUI~1/AppData/Local/Temp/hbmk_0c2ksu.dir/ss030.o C:/Users/GEBRUI~1/AppData/Local/Temp/hbmk_0c2ksu.dir/ss040.o C:/Users/GEBRUI~1/AppData/Local/Temp/hbmk_0c2ksu.dir/ss050.o C:/Users/GEBRUI~1/AppData/Local/Temp/hbmk_0c2ksu.dir/ss050p.o C:/Users/GEBRUI~1/AppData/Local/Temp/hbmk_0c2ksu.dir/ss055.o C:/Users/GEBRUI~1/AppData/Local/Temp/hbmk_0c2ksu.dir/ss100.o C:/Users/GEBRUI~1/AppData/Local/Temp/hbmk_0c2ksu.dir/ss150.o C:/Users/GEBRUI~1/AppData/Local/Temp/hbmk_0c2ksu.dir/ss200.o C:/Users/GEBRUI~1/AppData/Local/Temp/hbmk_0c2ksu.dir/ss900.o C:/Users/GEBRUI~1/AppData/Local/Temp/hbmk_0c2ksu.dir/ss_help.o C:/Users/GEBRUI~1/AppData/Local/Temp/hbmk_0c2ksu.dir/hbmk_mcj70k.o P:/hmg.3.0.44/SPORSERV/_temp.o -mwindows -Wl,--start-group -lhmg -lcrypt -ledit -leditex -lgraph -lini -lreport -lhfcl -lmsvfw32 -lvfw32 -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbmysql -lmysql -lhbtip -lsqlite3 -lhbsqlit3 -lsddodbc -lrddsql -lsddmy -lhbodbc -lodbc32 -lhbhpdf -lhbfimage -lhbpgsql -lhbnetio -lxhb -lpng -llibhpdf -lhbvpdf -lhbzebra -lhbextern -lhbdebug -lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -liphlpapi -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -osporserv.exe -LP:/hmg.3.4.2/harbour/lib/win/mingw -LP:/hmg.3.4.2/lib
hbmk2: Error: Referenced, missing, but unknown function(s):
GRID_SETCOLUMNCONTROL()
GRID_SetColumnControl it is an internal function that name is changed, instead use:
SetProperty (cFormName, cGridName, cProp, nColumn, xValue)
where cProp:
"COLUMNHEADER"
"COLUMNWIDTH"
"COLUMNJUSTIFY"
"COLUMNCONTROL"
"COLUMNDYNAMICBACKCOLOR"
"COLUMNDYNAMICFORECOLOR"
"COLUMNDYNAMICFONT"
"HEADERDYNAMICFONT"
"HEADERDYNAMICBACKCOLOR"
"HEADERDYNAMICFORECOLOR"
"COLUMNVALID"
"COLUMNWHEN"
"COLUMNONHEADCLICK"
"COLUMNDISPLAYPOSITION"
Re: HMG 3.4.3
Claudio, Thank you so much!
Re: HMG 3.4.3
mol wrote:The same error caused by Dynamic Display solution is generated by samples: grid\grid_26, grid\grid_29, grid\grid_30.
Please, change line 3212 of file source\h_grid.prg:
This.CellValue := iif( lBufferedCell == .T., xBufferedCellValue, GetFiledData( index , This.QueryColIndex ) )
for this:
_HMG_SYSDATA [ 318 ] := iif( lBufferedCell == .T., xBufferedCellValue, GetFiledData( index , This.QueryColIndex ) )
and rebuild HMG library.
Re: HMG 3.4.3
Hola
Me sucede un detalle (que no pasa en la 3.4) y es que al mostrar la ventana de PRINT PREVIEW
y luego cerrarla, me borra el color fondo de la ventana anterior. (es una VIRTUAL WINDOW)
Alguna idea ?
mmm..... Viendolo por otro lado, es posible que el color de fondo de las ventanas sea transparente ??
Hello
It happens a detail (which does not happen in 3.4) is that the display window PRINT PREVIEW
and then close it, I deleted the color bottom of the previous window. (It is a VIRTUAL WINDOW)
Any ideas ?
mmm ..... seeing on the other hand, it is possible that the background color is transparent windows ??
Re: HMG 3.4.3
for this:
H_GRID.PRG ends at the line #3054 :shock: :?
Re: HMG 3.4.3
May be line # is 2843
Re: HMG 3.4.3
Hola
Estoy probando el ejemplo de SQLite y me da error al compilar...
Hello
I'm testing the example of SQLite and gives me error when compiling ...
Encontré en la carpeta LIBS de la version 3.2 la libhmgsqlite.a y la copie a la carpeta de la
3.4.3 y ya funciona. ( pero no se si esta version la traía ó sea la correcta)
I found in the folder LIBS version 3.2 the libhmgsqlite.a and copy the folder
3.4.3 and it works. (but not if this version brought it or it is correct)
Buscando en el foro, creo que la tome de aquí... ( no deberian venir por default en cada version ??? )
-------------------------------------------------------->>> search.php?st=0&sk=t&sd=d&sr=posts&keyw ... D&start=50
I looking in the forum, I think the take from here ... (Should not come by default in each version ???)
Re: HMG 3.4.3
bpd2000 wrote:May be line # is 2843
Yes you you're right, I'm sorry,
it is the line 2843 of file h_grid.prg in the GetDataGridCellData function.
replace this line:
for this:
and rebuild the lib.
Re: HMG 3.4.3
andyglezl wrote:Hola
Hello
Thanks for reporting. I will give patch for HMGSQLite.
GodkarPS
hmg with SQL SERVER
Re: HMG 3.4.3
Post by GodkarPS »
Really it is good, thank you very much to the HMG development team.
GodkarPS
