JMG ALPHA 004 (moving)
Here is a new release of JMG at a new home.
- 2016.04.16 (alpha 004):
- added: select (combobox) widget.
- added: config.xml file for Phonegap.
- modified: beginGrid() does not requires number of columns as parameter.
- added: placeholder property for text and number widgets.
The new home for JMG from this release is GitHub:
http://jmgweb.github.io/main
GitHub has a lot of advantages, including that Phonegap build service can pull the code directly from it, to build apps. This is how I've created the apk from main demo.
Enjoy!
luisvasquezcl
Re: JMG ALPHA 004 (moving)
Post by luisvasquezcl »
Great news, thanks Roberto
Very good.
Now you can test the latest version of JMG from jmg
Thanks Roberto !
I've created db test and I've imported people.sql and can not connect to database test.
PhpMyAdmin works OK on this db.
What's going on?
I've installed jmg alpha 4 if folder jmg4 of DocumentRoot of serwer apache. When I call manually select.php, I get table:
[["20","John","Dow"],["21","Pepe","Grillo"],["22","Katherine","Janeway"],["23","Marek","Olszewski"]]
Rathinagiri wrote:Very good.
Oh Thanks!
mol wrote:I've created db test and I've imported people.sql and can not connect to database test.
What's going on?
mmm... check required username and password for your server and paths to php. Start the app using the server address (if you are local: 127.0.0.1).
That should be all.
I've tried :( without effects, but, I'll work on it tomorrow again and report about effects.
I'll test on another computer later.
It works now!
My apache configuration is too restricted :)
Thanks!
