Reportes con HMG
Re: Reportes con HMG
Exporting to HTML is also an option.
- srvet_claudio
+1Rathinagiri wrote:Exporting to HTML is also an option.
- dragancesu
At first glance sounds nice, but are you've tried to put the code for "new page" in html documents?
- edufloriv
- DBs Used: DBF, MariaDB, MySQL, MSSQL, MariaDB
Si, es cierto Claudio. Yo no he usado aún HMGHPDF, no sé si es posible usarlo con HMG 3.0.46. Actualmente estoy usando el PDF creator , el cual puede ser configurado para trabajar en segundo plano y de esa forma genero los PDF que necesito. Así he podido dar a mis usuarios la facilidad de grabar las ordenes de compra en PDF y automáticamente enviarlas a los correos de los proveedores.
Seria bueno tener más material al respecto para poder implementar en nuestros sistemas y creo que podriamos poner el logo de la hojita verde en los mismos
Yo por mi parte me ofrezco a compartir código para crear reportes en Excel, tengo bastante material al respecto, solo sería cuestión de ordenarlo y estructurarlo para fines didácticos.
Saludos cordiales a todos.
Eduardo Flores Rivas
LIMA - PERU
Gracias Eduardo. Seria una EXCELlente contribucion de su parte.
That's right. Most of the reports are not printed out now-a-days.dragancesu wrote:-1Rathinagiri wrote:
Also, the browsers decently print the reports into pages when required.
jozef
Big, big thanks Mr. Esgici for your 10 steps. I have started with reporting a week ago and this is very useful.esgici wrote:Thanks to rememberdragancesu wrote:User Esgici has set the content (maybe last year?), how to make a perfect report in 10 steps, since there are many forum posts I could not find, if someone can help it would be nice
Thanks
Beginning of that topic is here.
Happy HMG'ing
Many thanks again
Jozef
- esgici
Hi Josefjozef wrote:... I have started with reporting a week ago and this is very useful.
Thanks to your nice words
You are welcome to wonderful of HMG
Happy HMG'ing
Viva INTERNATIONAL HMG
Estimado Eduardo:
Advierto que aún sigues usando una versión muy antigua de HMG (3.046), versión en la que no se incluyeron las librerías HMGHPDF.-
Creo que es menester que avances a la última versión (3.42), de otro modo, hay infinidad de funciones que podrían mejorar tus aplicaciones.- Es una pena que no las utilizes.-
Puedo entender que te sientas a gusto con ella, pero los avances logrados ameritan que inviertas algo de tiempo actualizándote.-
HMGHPDF fue introducido en la version 3.30.-
Cordialmente.
Eduardo
Dear Eduardo:
I notice that you are stil using and version of HMG (3.046), this version not includes HMGHPDF libs.-
I think you must advance till last version (3.024), otherwise, there are a lot of functions that can make more powerfull your app. It's a pity you don't use them.-
I can understand that you feel happy with 3.046, but advances on new versions will justify your time invest upgrading it.-
HMGHPDF was introduced since version 3.30.-
With Regards.
Eduardo
Cordialmente.
Eduardo
Dear Eduardo:
With Regards.
Eduardo
Eduardo is explaining to Eduardo.
Thank you for both Eduardos.
