GRID : problem with delete and refresh
TopsMarc
Post by TopsMarc »
Dear Sirs,
I am having troubles with the control Grid.
Could you help me please ? I included my sources and database in attachment in a zip-file.
I use Windows 10 Home, and installed HMG.3.4.2.Setup.exe.
Open the project VM.hbp. When I run the project and click 'articles' and 'valuta', my database VM.DBF is shown. I have 3 records
The current record is 'BEF'. I press the DEL button to delete the current record. There are 2 records left, 'EUR' and 'NLG'. Ok so far. (see IMG 2)
The current record is now 'EUR'. I press the DEL button.
Instead of the NLG-record, I see the EUR-record. (see IMG 3)
I don't understand why I don't see the NLG-record now.
And when I press the 'Refresh' button, again the EUR record is shown, and not the NLG record.
What am I doing wrong ? Or could there be a bug in the .save and .delete and .refresh method ?
If you need more information, please ask me.
Kind regards,
Marc Tops
IMG 2.png (33.37 KiB) Viewed 7712 times
IMG 3.png (26.68 KiB) Viewed 7712 times
VM.zip
(3.47 KiB) Downloaded 334 times
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: GRID : problem with delete and refresh
Post by dragancesu »
The order in the table and the grid is not the same
FUNCTION KR_Button_Del()
        msgingo( 'Order in grid : ' +  str(Win_KR.KR_Grid_KR.Value) )
        msgingo( 'Order in dbf : ' +  str(recno()) )
	Win_KR.KR_Grid_KR.Delete
	Win_KR.KR_Grid_KR.Save
and you must know when line in grid is actual, MUST BE SELECTED (just click on line), only refresh is not solution, try
Win_KR.KR_Grid_KR.Value :=1
Win_KR.KR_Grid_KR.Refresh // if you want go to top line in grid
Welcome to HMG
Dag Marc, Welkom !
TopsMarc
Post by TopsMarc »
Hi mr Dragancesu.
Thank you for your suggestions. I entered these lines
msginfo( 'Order in grid : ' + str(Win_KR.KR_Grid_KR.Value[1]) + ' ' + str(Win_KR.KR_Grid_KR.Value[2]) )
msginfo( 'Order in dbf : ' + str(recno()) )
and I get it that recno() is not the same as the order in the grid.
I tried as you suggested clicking on the line before hitting the DEL-button. But the result was the same as before.
For the refresh, I also tried as you suggested
Again the result was the same as before. The refresh doesn't work.
I don't understand why, but the content of the grid is incorrect when I use delete , save or refresh method.
Kind regards, Marc
Dag Serge,
Blij hier al een taalgenoot te vinden. Groeten uit de Kempen.
Mvg, Marc
Dag Marc, Ik heb je persoonlijk berichtje gestuurd. Zie private messages.
dragancesu
Transition from Clipper to HMG not easy for me, I think it's easier to use the browse
It's been half a year until I made my way to standardize applications but now look like in demo
I do not use HMG-ide
HMG is excellent
vmdemo.zip
(3.84 KiB) Downloaded 320 times
TopsMarc
Post by TopsMarc »
Instead of deleting a record in a grid with the delete and save method that doesn't seem to work (and I don't know why not) ...
I tried it now like this ...
VM->(DBGoto ( Win_KR.KR_Grid_KR.RecNo ))
VM->(DBDelete())
VM->(DBSkip())
IF VM->(EOF())
VM->(DBGobottom())
Win_KR.KR_Grid_KR.RecNo := VM->(recno())
Win_KR.KR_Grid_KR.Setfocus
It didn't work either.
When the BEF record is deleted, recno() becomes 2, and the current record in the grid becomes EUR. Fine so far.
When the EUR record is deleted, recno() becomes 3, but the current record in the grid doesn't become NLG, but it is again EUR, and NLG is not shown in the grid. I don't get that at all.
And the refresh button ...
also again shows EUR instead of NLG. Why is that ?
it is so frustrating not being able to use the grid without such errors, and I can't figure out what I am doing wrong. Or is this a serious bug ?
Kind regards, Marc
TopsMarc
Post by TopsMarc »
Hi mr Dragancesu,
Thank you very much for your excellent vmdemo. I am studying the program.
Kind regards, Marc
TopsMarc
Post by TopsMarc »
Dag Serge,
Voorlopig zie ik bij private messages nog niets staan. Misschien zit er wat vertraging op. Ik hou het in de gaten.
Mvg, Marc
Hola Marc
Si tratas de hacerlo de la siguiente forma, te da el mismo resultado ?
Hello Marc
If you try to do as follows, it gives you the same result?
see the following: viewtopic.php?f=20&t=4666&p=44516#p44516
