OnLostFocus Event - Problem with sequence of called functions
Source code related resources
I need to create form with two textboxes, which values should be checked while focus loose.
I've prepared small sample - two fields, no one can not be empty. Program uses On LostFocus to test content of field. When is empty, message is generated.
Try to leave field 1 empty and observe messages
	DEFINE WINDOW Form_Main ;
		WIDTH 640 HEIGHT 600 ;
		TITLE 'ON LOST FOCUS TEST' ;
		@ 100,10 LABEL L1 ;
		WIDTH 150 HEIGHT 20 ;
		VALUE 'FIELD 1'
		@ 100,100 textbox T1 ;
		VALUE '' ;
		On lostfocus T1_CheckValue()
		@ 130,10 LABEL L2 ;
		VALUE 'FIELD 2'
		@ 130,100 textbox T2 ;
		VALUE '';
		On lostfocus T2_CheckValue()
		@ 180,10 LABEL L_Info1 ;
		WIDTH 120 HEIGHT 18 ;
		VALUE 'Focused control'
		@ 200,10 LABEL L_Info ;
		WIDTH 600 HEIGHT 380 ;
		BACKCOLOR {255,255,0};
		FONTCOLOR {255,0,0};
		VALUE 'Info label'
	CENTER WINDOW Form_Main
	ON KEY ESCAPE OF FORM_MAIN ACTION FORM_MAIN.RELEASE
	ACTIVATE WINDOW Form_Main
function T1_CheckValue
	Form_Main.L_Info.Value := hb_valtoexp(ThisWindow.FocusedControl) + ViewCallStack()
	if empty(This.Value)
		MsgStop("Field T1 can not be empty!" + chr(10)+"Focused control is: "+hb_valtoexp(ThisWindow.FocusedControl))
		Form_Main.T1.SetFocus
 return .t.
function T2_CheckValue
		MsgStop("Field T2 can not be empty!" + chr(10)+"Focused control is: "+hb_valtoexp(ThisWindow.FocusedControl))
		Form_Main.T2.SetFocus
 return .t.
function ViewCallStack
	local i := 2, cStack := ""
	while ( !Empty(ProcName(i)) )
		cStack += ProcName(i) + "(" + alltrim(str(ProcLine(i)) )+ ")"+" ----     "
		i++
	end
 return cStack
Re: OnLostFocus Event - Problem with sequence of called functions
OnLostFocus should be fired before the control looses focus, in my opinion.
Marek,
When using LostFocus property of two controls (that too consecutive) we should be very careful.
If you use Msg functions in between, then the head ache is still more!
The problem becomes still complex when we again set focus to the original control.
Using 'this.value' inside lostfocus event is also a problematic (might be a bug?) As you can see, before a lostfocus event of first control is fired, the next control is gotfocus. When you are again making a set focus to the original control, the second control lostfocus is fired!
Invoking the Msg function is nothing but activating a modal window created over and above our application window. So, this naturally fires the LostFocus event of the textbox again!
Now, some alternatives:
1. Instead of using Msg functions, you can use a LABEL with Red color to show the error/warning.
2. Data can be validated at the time of saving the record (may be after pressing the SAVE button. This is what I do) This way, I allow the user to move on through all the controls without any restrictions.
3. You can use a status bar also to indicate the warnings instead of msg functions.
4. Playing a beep is also good sometimes.
mol wrote:OnLostFocus should be fired before the control looses focus, in my opinion.
You can not fire lostfocus event before losing the focus as we can't know when it will. So, it is rightly named 'LOST' focus.
IMHO, there is no such intermediate state between controls. When one control loses focus, automatically the next control in the tab order gets the focus and there is no intermediate state in between. When we manually set focus to the original control the lostfocus of the second control is fired.
To avoid this we can use the wonderful feature:
StopControlEventProcedure ( cControlName, cFormName, lStop )
I am sure now this sample will be right for you.
      @ 100,10 LABEL L1 ;
      VALUE 'FIELD 1'
      VALUE '' ;
      @ 130,10 LABEL L2 ;
      VALUE 'FIELD 2'
      VALUE '';
      VALUE 'Info label'
      @ 10, 10 label warning width 200 fontcolor { 255, 0, 0 }
   if empty(Form_Main.t1.Value)
      form_main.warning.value := 'Field T1 can not be empty!'
      && MsgStop("Field T1 can not be empty!" + chr(10)+"Focused control is: "+hb_valtoexp(ThisWindow.FocusedControl))
      StopControlEventProcedure ( 't2', 'Form_Main', .t. )
      StopControlEventProcedure ( 't2', 'Form_Main', .f. )
      form_main.warning.value := ''
 return .t.
   if empty(Form_Main.t2.Value)
      form_main.warning.value := 'Field T2 can not be empty!'
      && MsgStop("Field T2 can not be empty!" + chr(10)+"Focused control is: "+hb_valtoexp(ThisWindow.FocusedControl))
      StopControlEventProcedure ( 't1', 'Form_Main', .t. )
      StopControlEventProcedure ( 't1', 'Form_Main', .f. )
 return .t.
      i++
   end
 return cStack
Marek,
LostFocus is fired before the window loses the focus, but see the remark section:
https://msdn.microsoft.com/en-us/libra ... .85).aspx
srvet_claudio wrote:Marek,
The link is not working... could be you so kind to re-post it?
TIA.
"https://msdn.microsoft.com/en-us/librar ... s.85).aspx"
I'm sorry, is my movil device.
Delete the quotes.
Thanks guys for help!
I've spenthalf a day for searhing right solution. I'll do some twsts tomorrow.
Rathinagiri wrote:Marek,
I fully agree, using this event is very risky...
Rathinagiri wrote: Now, some alternatives:
Really good alternative, I couldn't find why OnLostFocus is fired (because I've used MsgBox function)...
Rathinagiri wrote: 2. Data can be validated at the time of saving the record (may be after pressing the SAVE button. This is what I do) This way, I allow the user to move on through all the controls without any restrictions.
I need to check value of first field, because the rest of input process depends on this value.
Rathinagiri wrote: 3. You can use a status bar also to indicate the warnings instead of msg functions.
As good as label...
Rathinagiri wrote: 4. Playing a beep is also good sometimes.
It really can help if user has attached speakers and computers aren't located on production hall with loud machines :lol: :lol: :lol:
I thought about it, intermediate state would be useful, as you wrote.
Rathinagiri wrote: To avoid this we can use the wonderful feature:
I dind't know anything about this function, it saved my life :P
Many thanks for help!
srvet_claudio wrote:"https://msdn.microsoft.com/en-us/librar ... s.85).aspx"
Delete the quotes.
Thanks!
