I am trying to get the most out of the IDE. I have the BROWSE control working well with Oracle on numeric and character (varchar2) field types. When I try to use the BROWSE control with a date field I get the error indicated below.
I am basically using the IDE\Browse as detailed in the docs. Giving values to the indicated properties (FIELDS,HEADERS,WORKAREA) and initializing the WorkArea as indicated via calling the corresponding PROCEDURE.
The moment I change a FIELDS property to that of a DATE type field I get the error.
OK = FIELDS: {'Test->ID','Test->Name'}
Error = FIELDS: {'Test->ID','Test->MyDateFld'}
ERROR
BROWSE "BASE/1100 Argument error: TRIM"
Thanks,
Michael
