FuelWare
FuelWare
I am happy to share yet another project of mine with you all.
I have named this project as 'FuelWare' which can be used to track expenses related to vehicles in an organization like fuel, insurance, permit and other. I am making the documentation and once it is over, I will share that with you. I am sure the screens are self explanatory.
The project is based on SQLite database. It comes with a sample database. If you want to enter in a fresh database, please rename/delete the file named 'fuelwaredb.sqlite'. A new file in this name will be created.
Source Code:
FuelWare.zip
(570.44 KiB) Downloaded 541 times
You should include the following library file before compiling using IDE in the /lib folder.
libhmgsqlite.zip
(2.5 KiB) Downloaded 485 times
Compiled Executable
FuelWareExe.zip
(2.09 MiB) Downloaded 515 times
Help
fuelware_help.zip
(2.51 MiB) Downloaded 524 times
Now it is time for some screenshots: :)
Main Screen
Transaction Entry Screen
Vehicle Management Screen
Tag Management Screen
Report Screen
Re: FuelWare
Thanks Rathi for sharing !
Re: FuelWare
Great job!
Thanks for sharing!
I will return to sqlite testing after adventures with HMGScript.
I'm sure this sample will help me a tot!
Re: FuelWare
Hola amigo Rathi:
Magnífico , muchas gracias por su aportación
Creo que este proyecto suyo tendria que
incluirse en los samples SQlite de HMG para
la proxíma versión.
Quiero comentarle que el sample me daba
error de compilación , le adjunto Error
----- Solución -------------
he añadido al fichero FuelWare.hbp
Sql1.prg.
En fichero "solution.zip" adjunto
sql1.prg
error.log
build.3.4.2.bat
build.3.4.2_64.bat
Todo Ok con los cambios
saludos
*------------------ Google-----------------------*
Hello friend Rathi
Great, thank you very much for your input
I think this project would have to yours
SQlite included in the HMG samples for
The next version.
I want to tell the sample gave me
I attach compilation Error
------ Solution -----
I added to the file FuelWare.hbp
Sql1.prg.
In file "solution.zip" attached
sql1.prg
error.log
build.3.4.2.bat
build.3.4.2_64.bat
Everything Ok with changes
*--------------------------------------------------- Error Compilation ------------------------------------------------*
Harbour 3.2.0dev (r1509031202)
hmgleavedate.prg:26:0: warning: ignoring #pragma EMDDUMP [-Wunknown-pragmas]
C:/Users/jorge/AppData/Local/Temp/hbmk_4xv3la.dir/main.o:main.c:(.data+0x128): undefined reference to `HB_FUN_CONNECT2DB'
C:/Users/jorge/AppData/Local/Temp/hbmk_4xv3la.dir/main.o:main.c:(.data+0x168): undefined reference to `HB_FUN_SQL'
c:/hmg.3.4.2/mingw/bin/../lib/gcc/i686-w64-mingw32/4.9.2/../../../../i686-w64-mingw32/bin/ld.exe: C:/Users/jorge/AppData/Local/Temp/hbmk_4xv3la.dir/main.o: bad reloc address 0xf in section `.text.startup'
c:/hmg.3.4.2/mingw/bin/../lib/gcc/i686-w64-mingw32/4.9.2/../../../../i686-w64-mingw32/bin/ld.exe: final link failed: Invalid operation
hbmk2[FuelWare]: Error: Ejecutando enlazador. 1
gcc.exe C:/Users/jorge/AppData/Local/Temp/hbmk_4xv3la.dir/main.o C:/Users/jorge/AppData/Local/Temp/hbmk_4xv3la.dir/createdb.o C:/Users/jorge/AppData/Local/Temp/hbmk_4xv3la.dir/fueltxn.o C:/Users/jorge/AppData/Local/Temp/hbmk_4xv3la.dir/grid2csv.o C:/Users/jorge/AppData/Local/Temp/hbmk_4xv3la.dir/grid2html.o C:/Users/jorge/AppData/Local/Temp/hbmk_4xv3la.dir/hmganywhere.o C:/Users/jorge/AppData/Local/Temp/hbmk_4xv3la.dir/hmgleavedate.o C:/Users/jorge/AppData/Local/Temp/hbmk_4xv3la.dir/report.o C:/Users/jorge/AppData/Local/Temp/hbmk_4xv3la.dir/tagmanager.o C:/Users/jorge/AppData/Local/Temp/hbmk_4xv3la.dir/vehmast.o C:/Users/jorge/AppData/Local/Temp/hbmk_4xv3la.dir/hbmk_qrh9kf.o c:/Hmg.0_Musta_Total_11_03_2016/Sample_Adordd/FuelWare/_temp.o -mwindows -Wl,--start-group -lhmg -lcrypt -ledit -leditex -lgraph -lini -lreport -lhfcl -lmsvfw32 -lvfw32 -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbmysql -lmysql -lhbtip -lsqlite3 -lhbsqlit3 -lsddodbc -lrddsql -lsddmy -lhbodbc -lodbc32 -lhbhpdf -lhbfimage -lhbpgsql -lhbnetio -lxhb -lpng -llibhpdf -lhbvpdf -lhbzebra -lhbextern -lhbdebug -lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -liphlpapi -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -oFuelWare.exe -Lc:/hmg.3.4.2/harbour/lib/win/mingw -Lc:/hmg.3.4.2/lib
hbmk2: Error: Funci¢n(es) referenciada, no encontrada, pero desconocida:
CONNECT2DB(), SQL()
solution.zip
(3.05 KiB) Downloaded 375 times
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: FuelWare
Post by dragancesu »
Great looks
I have not tried it but I did like that so I think we should add this information, state flown kilometer when full, if you need to take into account the average consumption
Re: FuelWare
dragancesu wrote:Great looks
In this software I am giving provision to find out the mileage in a different way. Whenever possible, we can just enter the odometer reading (there is a separate field for entering the odometer reading in the transaction entry between amount and remarks). This will help in a later stage to find out the average mileage of a vehicle.
This can be tracked for any particular expense also (like battery or tyre replacement).
Please comment about my idea also.
Re: FuelWare
Dear Mustafa,
You have to include HMGSQLite bridge (as you can see in .hbc file) library in the compilation.
Thanks for your solution also.
Re: FuelWare
Thank you Mr. Rathi for sharing excellent code in HMG
Also it is used to learn Sqlite
luisvasquezcl
Re: FuelWare
Post by luisvasquezcl »
Very nice Rathi. thanks for sharing.
Best regards
Re: FuelWare
I have now attached the HMGSQLite Library file that is required while compiling the software. Please make use of it by copying the library file in hmg lib folder.
