Start main window in top right monitor
How can I start my main window in the top right corner of the monitor?
More specifically, how can I determine the screen resolution? It may be different on other user monitors?
Also, how do I change the font color of a label after the form is loaded?
--Russ
--Russ
Re: Start main window in top right monitor
I found the answer to my first question
DEFINE WINDOW Win_1 ;
AT 0,GetDesktopWidth()- myformwidth
2) Can I change the font color and/or the form background color after the form is active?
--Russ
--Russ
Definicion:
DEFINE WINDOW Form_1.......
@ 200,20 LABEL Label_1 VALUE "HMG" TRANSPARENT FONT "ARIAL" SIZE 36 ;
FONTCOLOR BLACK BACKCOLOR YELLOW AUTOSIZE
Ejecucion:
Form_1.Label_1.FONTCOLOR := WHITE
Form_1.Label_1.BACKCOLOR := BLUE
Ejecucion:
I know how to set the colors of a label at definition.
How can I change the property AFTER?
My form displays data that changes. I want to be able to change the color of a label to Green or Red based on status.
How can I set the color properties of a label?
--Russ
--Russ
my_form.my_label.fontcolor := aNewColor
You can change the color during runtime using the above property.
Background color of window is not changeable. You can define it only at creation time.
Marek,
He wants to change the color of the label and not the background color of the window.
Russ wrote about form background colorRussBaker wrote:I found the answer to my first question
--Russ
Quiza son 2 preguntas... pero si RussBaker no contesta los post, no sabremos...
Maybe are 2 questions ... but if RussBaker not answer the post not know ...
