Programa para BACKUP
Re: Programa para BACKUP
I'm using my own function to backup files. I'm putting here listing. I translated names of variables, if you find any error, please send a comment.
(This function uses sys2.dbf which contains definitions of .dbf files, in this case I use it as a list of files to archive)
function MakeBackup
	param cArchiveFolder, cArchiveName
	local CFileName
	local cComment, cPassword
	static lPendingArchivization := .f.
	if lPendingArchivization
		return
	lPendingArchivization := .t.
	cPassword := 'you can give your password to zip file here'
	cComment := "Archive from day: " + dtoc(date())+" "+time() +;
		chr(13)+chr(10)+;
		"Company: Your company name" +;
		chr(13)+chr(10)+;
		"Program FAKTURY (MOL-SK Marek Olszewski)"+;
		chr(13)+chr(10)+;
		"Version: "+ cApplicationVersion
	if substr(cArchiveFolder,-1) <> "\"
		cArchiveFolder += "\"
	if !file(cArchiveFolder+"nul")
		CreateFolder(cArchiveFolder)
		if !file(cArchiveFolder+"\nul")
			MsgStop("Cannot create archive folder. Stopped!!!")
			return
	cArchiveName := cArchiveFolder + cArchiveName + ".zip"
	if file(cArchiveName)
		if !MsgYesNo("Archive File already exists. Overwrite?","Overwrite archive file?",.t.)
			return
	// database sys2 contains list of all .dbf files to archive
	Use sys2 new
	sys2->(DBGoTop())
	hZip :=  HB_ZIPOPEN( cArchiveName )
	if ! empty( hZip )
		do while !sys2->(eof())
			CFileName := alltrim(sys2->FileName)
			if ascan(CFileName, ".") = 0
				// filename does not contain extension
				CFileName += ".dbf"
			HB_ZipStoreFile( hZip, cFileName, cFileName, cPassword )
			sys2->(DBSkip())
		enddo
		sys2->(DBCloseArea())
		HB_ZIPCLOSE( hZip, cComment )
return
JALMAG
DBs Used: DBF, MariaDB
Post by JALMAG »
Hola Daniel, los ejemplos son de Notepad...no de Backup.
Steed
Post by Steed »
Use HMG_MYSYNC is made whit HMG
HMG_MYSYNC.rar
(1.22 MiB) Downloaded 385 times
ES
Thanks for sharing John Steed!
I'm using a combination of three things:
1. "System Scheduler" (http://www.splinterware.com/products/wincron.htm): It allows schedule the backups at specified times. It is wonderful and has a free version that does all required things.
2. "7-zip" (http://www.7-zip.org/): It is the most efficient compressor out there and it is FREE.
3. MOVEit Freely FTP Client (http://www.ipswitchft.com/moveitfreely): It is a free commandline FTP client that allows to send the backup file created by 7Zip to a server (local or remote) for storage.
Of course, the "glue" for all this is a batch file like this (launched by "System Scheduler" at desired time):
cd c:\util
7z u -mx9 -r -mmt=off c:\upload\My.Backup.%date:~-4,4%.%date:~-7,2%.%date:~-10,2%.7z c:\MyFiles\*.*
cd c:\upload
echo put My.Backup.%date:~-4,4%.%date:~-7,2%.%date:~-10,2%.7z > temp.txt
echo quit >> temp.txt
c:\util\ftps -a -e:off -user:myuser -password:mypass -s:temp.txt  my.server.ip  my.server.port
del temp.txt
cd c:\util
I hope this will be useful for someone.
Thx Roberto !
Roberto Lopez wrote:I'm using a combination of three things:
Extremely simple in appearance and extremely powerful, helpful and useful inside :o
AS ALWAYS :arrow: 8-)
Thank you very much Maestro for everything you gave us :oops:
Viva HMG :D
And... the FTP server (for the backup destination machine) I use Filezilla Server. A rock-solid, free FTP server: https://filezilla-project.org/download.php?type=server
