is there a way to Zoom into an Image. Much like Irfan View or Windows Photos. Any example available ?
Warm regards,
Jayadev
Zoom Into an Image
Re: Zoom Into an Image
To control graphics, it is best Bos-Taurus. The help is very well detailed
Yes. That is right.
You have to use particularly this function.
BT_BitmapCopyAndResize (hBitmap, New_Width, New_Height, Mode_Stretch, Algorithm)
Copy and resizes the specified bitmap and returns a handle to the bitmap with the new size.
hBitmap: is a handle to the origin bitmap.
New_Width, New_Height: is the new size of the bitmap image.
Mode_Stretch: sets the mode as the bitmap of origin is adjusts (is stretches or compresses) in the new size bitmap, it is one of the constants: BT_SCALE or BT_STRETCH (defined in BosTaurus.CH). For default Mode_Stretch = BT_STRETCH.
Algorithm: sets the mode as the bitmap is resized, it is one of the constants: BT_RESIZE_COLORONCOLOR, BT_RESIZE_HALFTONE or BT_RESIZE_BILINEAR (defined in BosTaurus.CH). For default Algorithm = BT_RESIZE_HALFTONE.
Thanks ndarz and Rathinagiri.
Where is the documentation of BosTaurus ?, I am not able to find it in hmg.3.4.0
Warm regards,
Jayadev
Warm regards,
Jayadev
This path is the pdf file.
c:\You_Dir_hmg.3.4.0\DOC\data\HMG_UNICODE_DOC\BosTaurus-FunctionsReferenceGuide.pdf
