hmg 3.4.1 error help
kiritved
Re: hmg 3.4.1 error help
Post by kiritved »
hi to all
my request is to go through the test code of 47 lines
attached below & guide me how to eliminate the error
listed below instead of taking pain of going through
2500 lines of code
REQUEST HB_GT_WIN_DEFAULT
function main
set date american
define window m0 at 0,0 height 400 width 400 main on init (my())
end window
activate window m0
retu nil
function my
if my_hi()
test()
retu nil
function test
define window m1 at 50,50 height 300 width 300
end window
activate window m1
retu nil
function my_hi
local rl
rl=.f.
if !file("c:\windows\system32\mymem.mem")
rl=.f.
restore from "c:\windows\system32\mymem.mem"
mdt1=ctod(enc_str(substr(z4,1,10)))
mdt2=ctod(enc_str(substr(z4,14,10)))
if date()>mdt2
rl=.f.
rl=.t.
retu rl
function enc_chr(s)
local rs
rs=chr(255-asc(s))
retu rs
function enc_str(s)
local rs,l
l=len(s)
rs=""
for i=1 to l
ks=substr(s,i,1)
rs=rs+enc_chr(ks)
next
retu rs
Application Internal Error - E:\sai\err_test.exe
Terminated at: 2015-12-16 17:03:52
Unrecoverable error 9003: Too many recursive error handler calls
Called from DEFERROR(73) in source\ErrorSys.prg
Called from (b)ERRORSYS(55) in source\ErrorSys.prg
Called from _DEFINEWINDOW(4072) in source\h_windows.prg
Called from TEST(15) in err_test.prg
Called from MY(11) in err_test.prg
Called from (b)MAIN(5) in err_test.prg
Called from _PROCESSINITPROCEDURE(5855) in source\h_windows.prg
Called from _ACTIVATEWINDOW(5606) in source\h_windows.prg
Called from MAIN(7) in err_test.prg
1.- Si sigues estándares de programación, será mas fácil para los miembros del foro leer tu código,
ya que el leer una "tira" de instrucciones a primera vista "desanima" leerlo.
2.- El código que enviaste funciona bien sin el error que comentas.
probado en HMG 3.4
3.- Mientras más información pongas en tu post, quizá más miembros puedan probarlo.
1. If you follow coding standards, it will be easier for forum members read your code,
       and that reading is a "strip" instruction at first sight "I discouraged" read.
2. The code sent works well without the error you mention.
       HMG tested 3.4
3. The more information you put in your post, perhaps more members to try.
function main
	set date american
	end window
	activate window m0
retu nil
function my
	if my_hi()
		test()
retu nil
function test
	end window
	activate window m1
retu nil
function my_hi
	local rl
	rl=.f.
		MSGINFO( "NO hay archivo .MEM" )
		rl=.f.
		MSGINFO( "SI hay archivo .MEM" )
		if date()>mdt2
			rl=.f.
			rl=.t.
retu rl
function enc_chr(s)
	local rs
	rs=chr(255-asc(s))
retu rs
function enc_str(s)
	local rs,l
	l=len(s)
	rs=""
	for i=1 to l
		ks=substr(s,i,1)
		rs=rs+enc_chr(ks)
	next
retu rs
kiritved
Post by kiritved »
hi thanks for your guideline. i am totally new to this forum.
i will pick up the norms suggested by you very soon
i request you to run following code separately,which will generate mymem.mem file in c:\windows\system32.
after generating this file if you run the program you have previously tested you will get the error mentioned by me.
i will be thankful to you , if you can check this and guide me
main()
function main()
	set console off
	local ddt,nnum
	set date american
	set century on
	ddt=ctod("12-31-2015")
	nnum=180
	dedt=ddt+nnum
	z4=dtoc(ddt)+str(nnum,3)+dtoc(dedt)
	z4=enc_str(z4)
	save all to  c:\windows\system32\mymem.mem
	set console on
	retu .t.
function enc_chr(s)
local rs
rs=chr(255-asc(s))
retu rs
function enc_str(s)
local rs,l
l=len(s)
rs=""
for i=1 to l
ks=substr(s,i,1)
rs=rs+enc_chr(ks)
next
retu rs
Perdón, con lo anterior me refería a tabular el código que envias y separar cada función
con una linea de comentario (al menos) para que lo podamos leer mejor.
Forgiveness, with the above I meant you send the code tabular and separate each function
with a comment line (at least) so that we can read better.
Este nuevo código que envías da error de compilación,
ejecutaste y probaste este código en tu pc ?
This new code that you send fails compilation,
you ran and you tried this code on your pc?
Aún corrigiendo ese error, no genera el archivo .MEM
Cualquier código que envíes, asegúrate de haberlo probado.
Syntax
SAVE TO <xcMemFile> [ALL [LIKE | EXCEPT <skeleton>]]
Even correcting that error does not generate the .MEM file
Any code that you send, be sure to trying it.
Syntax
AYUDAS/HELP
\HMG\3.4\DOC\hmgdoc.htm
\HMG\3.4\HARBOUR\doc\harbour.html
viewtopic.php?f=6&t=4023&hilit=danny#p37755
kiritved
Post by kiritved »
thanks.
alternatively i resolved the error by simply typing
restore from "c:\windows\system32\mymem.mem" additive
once again thanking all of you for your efforts.
kiritved
help on hbformat error
Post by kiritved »
when the code is compiled with harbour it works well with out any error.
using hbformat give following error
reformatting tmp.prg (2590 lines)
<..error 3 on line 96 :enddo
what is the reason ?
where i am going wrong ?
Carlos Britos
Re: help on hbformat error
Post by Carlos Britos »
kiritved wrote:when the code is compiled with harbour it works well with out any error.
Hi
If is not exist error at compilation time, then be sure is not wrong.
hbFormat is harbour tool and is not 100% error free, you can check it at harbour forum. You have to do manually some things after the format, maybe an IF inline sentence is not well formated. Personally i prefer my own format while typing code.
Hi Kiritved
First, you are welcome aboard :)
HBFormat is a "Harbour only" utility; doesn't support HMG commands, statements.
You can temporary comment such statements in your code; and after formatting ...
And a humble request : your previous question has too long and un-formatted samples. Please keep your sample short, simple and working (SSW); or with a more common acronym: KISS ( Keep It Simple and Short).
For save format (especially indentation) of your code, you can use "Code" facility of post editor of our forum.
kiritved
Post by kiritved »
thanks for your hearty welcome.
which utility , we normally use to format hmg,3,4,2 source code ?
kiritved wrote:thanks for your hearty welcome.
No idea :(
I'm using HBFormat with with described precautions :arrow:
IMO the best way is formatting while writing, as Carlos Britos commented.
