HMG.3.4.2
Re: HMG.3.4.2
Postby srvet_claudio » Sat Oct 17, 2015 12:08 am
emzampi wrote:
Eminent Dr. Claudio Soto you gave me solve my problem ?? or is it just a matter of time?.
Your code works fine for my, I do not know if same thing happens other people ?
I think he has the same problem
viewtopic.php?f=5&t=4545
Re: HMG.3.4.2
Hallo!
Norton360 means that the file contains "WS.Reputation.1" and removes downloaded exe. Can anybody help me?
Gilbert
Gilbert
Re: HMG.3.4.2
Gilbert,
Try: Stop Norton and re-download.
Re: HMG.3.4.2
Bonjour tout le mondemustafa wrote:Hola Dr. Claudio
Reporto un nuevo Error que me está saliendo
con HPDFPRINT al generar el Fichero PDF
Sin alterar el antiguo código prg cuando compilo
con hmg341 veo que las lineas de texto salen correctas
pero con la nueva versión hmg342 las líneas de texto
tienden a bajarse de su ubicación.
Ver Código Fuente Factura_HPDPRINT.zip en
viewtopic.php?f=5&t=3706
Un cordial saludo
*------------------------------- Google ----------------------*
Hello Dr. Claudio
I reported a new error that is coming to me
with HPDFPRINT to generate the PDF File
Without altering the old code when I compile prg
with hmg341 I see that text lines out right
but with the new version hmg342 text lines
They tend to get down on your location.
View Source Factura_HPDPRINT.zip in
Best regards
dans le fichier SOURCE/ h_HMG_HPDF
Changer la ligne 312 ( nyPos -= nFontSize) en ( // nyPos -= nFontSize )
et tout redevient normal.
In File SOURCE/ h_HMG_HPDF
Change line 312 (nyPost -= FontSize) in ( // nyPost -= FontSize) and everything returns to normal
Best regards
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
Y.TABET
Re: HMG.3.4.2
These changes about generating PDF's were made for unifying positions of text while normal printing and pdf printing.
You should change your APP.
Re: HMG.3.4.2
Merci Mol
mais je l'ai mis pour les personnes qui ont beaucoup de lignes à modifier dans leurs applications.
thank you Mol
translation with google
but I put it to people who have a lot of lines to modify their applications.
thank you Mol
Y.TABET
Y.TABET
Re: HMG.3.4.2
pour garder ces changements d'unification et ne pas changer son application ,il faudrait changer la ligne 312 (nyPost -= FontSize) en (nyPost - 3 = FontSize)mol wrote:These changes about generating PDF's were made for unifying positions of text while normal printing and pdf printing.
translation google
to keep those changes and unification not change its application should be changed in line 312 Change line 312 (nyPost -= FontSize) in (nyPost - 3 = FontSize)
Y.TABET
Y.TABET
Re: HMG.3.4.2
Change line 312 (nyPost -= FontSize) in ( // nyPost - 3= FontSize)
Je m'excuse pour cet article , mais il y à erreur lors de la compilation que je n'avais pas remarqué
merci beaucoup pour votre comprehension.
I apologize for this article, but there in error during compilation that I had not noticed
Y.TABET
Y.TABET
- mustafa
Re: HMG.3.4.2
Hola tonton2
cuando compiling BuilLib.bat
da Error.
La unica solucion que veo es subir en
nuestras aplicaciones las cordenadas
de las líneas o compilar Hmg 3.4.1
Sample:
Anterior-> @ 066,020 HPDFPRINT "Código Cliente:"
Nuevo -> @ 062,020 HPDFPRINT "Código Cliente:"
Hello tonton2
when compiling BuilLib.bat
It fails.
The only solution I see is to climb
our applications the coordinates
lines or compile HMG 3.4.1
Sample: compile HMG 3.4.2
Above> @ 066.020 HPDFPRINT "Customer Code"
New -> @ 062.020 HPDFPRINT "Customer Code"
da Error.
Sample:
Hello tonton2
It fails.
- Error.jpg (16.92 KiB) Viewed 9472 times
Re: HMG.3.4.2
bonsoir
si vous remplacer dans hmg 3.4.2 dans SOURCE/ h_HMG_HPD la ligne 312 (nyPost -= FontSize par ( // nyPost -= FontSize) il n y a plus d'erreur dans la compilation et ca marche
translation google
if you replace in hmg in 3.4.2 SOURCE / h HMG HPD line 312 (nyPost - = FontSize) by ( // nyPost - = FontSize ) he has no more error in the compilation and it works
translation google
Y.TABET
Y.TABET
