HMG.3.4.2
Re: HMG.3.4.2
mol wrote:All tabs, eg. Source, Stack, Watch etc. should be moved to child windows if it's possible.
Marek this is more difficult because require rewrite all GUI part of debugger.
mol wrote:It would be great to have keyboard shortcuts to most used functionalities - as in standard harbour debugger - F5, F8, F10 etc.
It's ok, but what are the functionalities that are used in the practice most frequently?
Re: HMG.3.4.2
Hi all,
I updated HMG Debugger, this version is especially dedicated to Marek :lol:
Press Crtl+H for help of hotkey and F11 to switch between Toolbar and menu options.
hmg.3.4.2_patch_3.rar
(845.61 KiB) Downloaded 932 times
Re: HMG.3.4.2
Thank you Dr. Claudio for update
Steed
Re: HMG.3.4.2
Post by Steed »
Thanks
Re: HMG.3.4.2
srvet_claudio wrote:Hi all,
Wow!
Many thanks!
Re: HMG.3.4.2
Hi!
I'm using such a code:
	CREATE EVENT PROCNAME SearchTable('Form1', 'Grid1') HWND Form1.Grid1.HANDLE MSG WM_CHAR STOREINDEX nSearchEvent
for incremental searching.
Everything worked OK in hmg 3.40
Now, I'm testing the same code recompiled with HMG 3.42 all patches and this event does not work!
What's going on?
Claudio, could you inspect source code?
Best regards, Marek
Re: HMG.3.4.2
:D
Last edited by danielmaximiliano on Thu Nov 19, 2015 8:01 pm, edited 1 time in total.
Re: HMG.3.4.2
Steed wrote:
Please , Harbour 64bits, files.
Thanks in advance
Dwonload from: claudio/MinGW-64%20and%20Harbour-64%20( ... 11-24).rar
Claudio, hay actualizaciones nuevas para x64 ?
Re: HMG.3.4.2
mol wrote:Hi!
What's going on?
Best regards, Marek
I will check the code.
Re: HMG.3.4.2
Thanks in advance
Not, it must be recompiled Harbour from the source files with MinGW64.
