HMG.3.4.2
- Roberto Lopez
- HMG Founder
Re: HMG.3.4.2
And...
Another thing is that there is no default edior for prg.
In the settings, the default editor is set to: C:\Windows\system32\shell32.dll
Re: HMG.3.4.2
Hola Roberto! You need to check ini files of IDE.
I don't remember names of files, I can't check it - I'm writing from tablet, but, I'm sure, you will find it.
Re: HMG.3.4.2
because in this version of hmg, forgotten the language files in ide-ansi, copy the language files (*.ans) from the latest version into \IDE_ANSI.
Best Regards,
Nikos.
os: Windows Server 2019 - 64
Nikos.
- Roberto Lopez
- HMG Founder
Re: HMG.3.4.2
Marek, Nikos,
Thanks for the clues...
I've figured it out, but, it need to be reported anyway, to be corrected in future versions...
Re: HMG.3.4.2
Sorry Roberto. This will be rectified in the next version.
- Roberto Lopez
- HMG Founder
Re: HMG.3.4.2
Thanks!Rathinagiri wrote:Sorry Roberto. This will be rectified in the next version.
I guess that I one of the few using 32 bits OS and ANSI, so, I catch the problems related to that
Re: HMG.3.4.2
Hi Roberto:
I attach a zip file with notepad++ folder and IDE_ANSI folder
Just unzip on your HMG folder.-
Hopping this helps you.-
Regards.
Eduardo
Regards.
Eduardo
- IDE_ANSI.zip
- (5.52 MiB) Downloaded 306 times
- Roberto Lopez
- HMG Founder
Re: HMG.3.4.2
Thanks!EduardoLuis wrote:Hi Roberto:
Regards.
Eduardo
I have a new PC and I've not finished yet to install all of 'my things'.
And maybe (just an opinion) HMG should be bundled with an editor again. Its influence of an editor in the size size of HMG installer should be minimal.
Re: HMG.3.4.2
I'm trying to test new version. It looks OK, but, when I declare CHECK control with background color defined, I'm not getting background in real app.
Screen from windows 7:
Screean from windows XP - check caption is covered by black color:
What's wrong?
What's wrong?
Re: HMG.3.4.2
For me it is working nice. Mine is Win7 64 Bits but compiled used HMG 3.4.2 32 Bits.
