HMG.3.4.2
Re: HMG.3.4.2
Thanks for new debugger.
It looks fine, but, how can I turn it off and recall old debugger?
Re: HMG.3.4.2
I think, in hmg.hbp remove the following lines and building the library may help. And, you have to use old IDE. May Claudio throw some light on this.
source/debugger/dbgHB.prg
source/debugger/dbgGUI.prg
Re: HMG.3.4.2
I have some suggestions about debugger for Claudio. I'll try to refer them. But now, I need to find some bugs as soon as possible.
Mario Mansilla
Re: HMG.3.4.2
Post by Mario Mansilla »
Hola :
cuando realizo la modificacion CLEAR MEMORY por RELEASE MEMORY en la linea 823 del archivo i_window.ch al intentar generar la libreria con BuildLib.bat modo ansi obtengo un error y no se genera la libreria .
Mario Rafael Mansilla
Re: HMG.3.4.2
Hi all,
I fixed the problem with rename the command RELEASE MEMORY.
This patch include all previous patches.
hmg.3.4.2_patch_2.rar
(844.61 KiB) Downloaded 380 times
Re: HMG.3.4.2
mol wrote:Thanks for new debugger.
Rathinagiri wrote:I think, in hmg.hbp remove the following lines and building the library may help. And, you have to use old IDE. May Claudio throw some light on this.
For now this is the only way.
Re: HMG.3.4.2
mol wrote:I have some suggestions about debugger for Claudio. I'll try to refer them. But now, I need to find some bugs as soon as possible.
It will be welcome.
Re: HMG.3.4.2
srvet_claudio wrote:Hi all,
Thank you sir for update
Re: HMG.3.4.2
Thanks! I'll test tomorrow.
Re: HMG.3.4.2
I've found a problem with IDE ANSI on WIn7 Pro 32 (Spanish).
In menus and other things (like tabs) instead of the expected text, only 'XXX' appears.
Image attached.
I'm sorry in advance if this was already reported... this is a long thread :)
TIA.
