HMG.3.4.2
Re: HMG.3.4.2
Post by EduardoLuis »
Hi BPD2000:
I disscard any virus, because on my office all hardware is protected by ESSET and upgraded automatically every hour.-
I used WIN XP SP3 this less memory, so if any app developed here, works fine, must work perfect on higher SO.- I've never develope under WIN 7 or higher, just test on its final appe.-
Thanks for your confirmation.-
When any systems growsup this issues are frecuently, but as testers, we must notify each issue we discovered; this way we help to get a more stable HMG.-
Again with regards to The Fellowship of HMG.-
Eduardo
Re: HMG.3.4.2
Thanks a lot for reporting Eduardo. I think Claudio can throw some light on this.
Re: HMG.3.4.2
Rathi,
Some strange behaviour which I noticed in earlier versions: when pressing F5 in the IDE it starts compiling.
Often when I press in F5 in another application (refresh) the compiler starts as if the IDE stays active all the time.
Any idea what's wrong?
Re: HMG.3.4.2
Hi Serge:
I don't experiment that issue (because i don't try F key), but i'll check it soon.-
With regards.-
Eduardo
Re: HMG.3.4.2
serge_girard wrote:Rathi,
I've reported this issue long time ago.
I'm using total commander, and every time, when I want to copy some files (F5 key) IDE starts to compile. When you press F5 to refresh internet browser, you can reach the same behaviour
Re: HMG.3.4.2
Gracias Claudio y Rathi por esta nueva version
Re: HMG.3.4.2
mol wrote:Thanks for new version!
Steed
Re: HMG.3.4.2
Post by Steed »
Please , Harbour 64bits, files.
Thanks in advance
Re: HMG.3.4.2
EduardoLuis wrote:Hi Rathi:
In advance thanks for your test.-
I'm attaching GRID_24.EXE generated just to show what happends.-
I frequently develope my app on a machine with WIN XP SP3, because many of my clients uses that SO and don't want to upgrade to new ones.-
Hopping you can guide me to solve this issue with regards.
Thanks in advance. Eduardo
I will check in XP, maybe the problem is in manifest file.
This attachment files .EXE works fine in Win10.
