ERASE WINDOW command does not delete the graph titles
Hola
El comando ERASE WINDOW no borra los titulos de la grafica, creo que ya se habia dado una solucion
pero en esta version (3.4) sigue sin aplicarse. Quizas ya este implementada en la 3.41 ?
Hello
The ERASE WINDOW command does not delete the graph titles, I think they had already given a solution
but in this version (3.4) remains unimplemented. It may already be implemented in the 3.41?
Hello
Re: ERASE WINDOW command does not delete the graph titles
Esgici you are "HMG-ENCICLOPEDIA".-
Thanks for share with all of us your knowledge.-
With regards.
Eduardo
With regards.
Eduardo
Thanks Esgici that was the solution.
He sure is a "HMG-ENCICLOPEDIA" !
+1serge_girard wrote:He sure is a "HMG-ENCICLOPEDIA" !
IMHO, drawing graph on the window itself is an outdated HMG graphics functionality.
The permanent solution for drawing graph is using the ultimate and versatile Bos Taurus library.
I have tried to convert the existing draw graph function ( only BAR type and not 3D) using BT library and saved the graph in a bitmap file. That bitmap can be used to show or print.
May be we can extend this to all other types and we have a NEW graph functionality to save the graph easily to a bitmap in HMG.
define window graph at 0, 0 width 1000 height 700 main
define button ok
row 10
col 10
width 80
caption 'Draw'
action drawgraph()
end button
define image grapharea
row 50
col 50
width 800
height 600
end image
end window
graph.center
graph.activate
function drawgraph
local cImage := 'graph.bmp'
local nImageWidth := 800
local nImageHeight := 600
local cTitle := 'Sample Graph'
local aYValues := {"Jan","Feb","Mar","Apr","May"}
local aData := { {14280,20420,12870,25347, 7640},;
{ 8350,10315,15870, 5347,12340},;
{12345, -8945,10560,15600,17610} }
local nBarDepth := 15
local nBarWidth := 15
local nHValues := 5
local l3D := .f.
local lGrid := .t.
local lXGrid := .t.
local lYGrid := .t.
local lXVal := .t.
local lYVal := .t.
local nGraphType := BARS
local lViewVal := .t.
local lLegends := .t.
local cPicture := '99,999.99'
local aSeries := {"Serie 1","Serie 2","Serie 3"}
local aColors := { {128,128,255}, {255,102, 10}, {55,201, 48} }
local lNoBorder := .f.
local nLegendWidth := 50
graphsave( cImage, nImageWidth, nImageHeight, aData, cTitle, aYValues, nBarDepth, nBarWidth, nil, nHValues, l3d, lGrid, lXGrid, lYGrid, ;
lXVal, lYVal, lLegends, aSeries, aColors, nGraphType, lViewVal, cPicture, nLegendWidth ,lNoBorder )
graph.grapharea.picture := 'graph.bmp'
return nil
function graphsave( cImageFileName, nWidth, nHeight, aData, cTitle, aYVals, nBarD, nWideB, nSep, nXRanges, ;
l3D, lGrid, lxGrid, lyGrid, lxVal, lyVal, lLegends, aSeries, aColors, nType, lViewVal, cPicture , nLegendWindth , lNoborder )
LOCAL nI, nJ, nPos, nMax, nMin, nMaxBar, nDeep
LOCAL nRange, nResH, nResV, nWide, aPoint, cName
LOCAL nXMax, nXMin, nHigh, nRel, nZero, nRPos, nRNeg
local hBitMap, hDC, BTStruct
local nTop := 0
local nLeft := 0
local nBottom := nHeight
local nRight := nWidth
DEFAULT cTitle := ""
DEFAULT nSep := 0
DEFAULT cPicture := "999,999.99"
DEFAULT nLegendWindth := 50
private nPenWidth := 0.25
If ( HMG_LEN (aSeries) != HMG_LEN ( aData ) ) .or. ;
( HMG_LEN ( aSeries ) != HMG_LEN ( aColors ) )
MsgHMGError("DRAW GRAPH: 'Series' / 'SerieNames' / 'Colors' arrays size mismatch. Program terminated", "HMG Error" )
EndIf
hBitMap := BT_BitmapCreateNew ( nWidth, nHeight, { 255, 255, 255 } )
hDC := BT_CreateDC( hBitMap, BT_HDC_BITMAP, @BTStruct )
IF lGrid
lxGrid := lyGrid := .T.
IF nBottom <> NIL .AND. nRight <> NIL
nHeight := nBottom - nTop / 2
nWidth := nRight - nLeft / 2
nBottom -= IF( lyVal, 42, 32)
nRight -= IF( lLegends, 32 + nLegendWindth , 32 )
nTop += 1 + IF( Empty( cTitle ), 30, 44 ) // Top gap
nLeft += 1 + IF( lxVal, 80 + nBarD, 30 + nBarD ) // LEFT
DEFAULT nBottom := nHeight - 2 - IF( lyVal, 40, 30 ) // Bottom
DEFAULT nRight := nWidth - 2 - IF( lLegends, 30 + nLegendWindth , 30 ) // RIGHT
l3D := IF( nType == POINTS, .F., l3D )
nDeep := IF( l3D, nBarD, 1 )
nMaxBar := nBottom - nTop - nDeep - 5
nResH := nResV := 1
nWide := ( nRight - nLeft )* nResH / ( nMax( aData ) + 1 ) * nResH
// Graph area
IF ! lNoborder
DrawWindowBoxInBitMap( hDC, Max( 1, nTop - 44 ), Max( 1, nLeft - 80 - nBarD ), nHeight - 1, nWidth - 1 )
// Back area
IF l3D
drawrectinbitmap( hDC, nTop+1, nLeft, nBottom - nDeep, nRight, { 255, 255, 255 } )
drawrectinbitmap( hDC, nTop-5, nLeft, nBottom, nRight, { 255, 255, 255 } )
IF l3D
// Bottom area
FOR nI := 1 TO nDeep+1
DrawLineinbitmap( hDC, nBottom-nI, nLeft-nDeep+nI, nBottom-nI, nRight-nDeep+nI, { 255, 255, 255 } )
NEXT nI
// Lateral
DrawLineinbitmap( hDC, nTop+nI, nLeft-nI, nBottom-nDeep+nI, nLeft-nI, {192, 192, 192} )
NEXT nI
// Graph borders
DrawLineinbitmap( hDC, nBottom-nI ,nLeft-nDeep+nI-1 ,nBottom-nI ,nLeft-nDeep+nI ,GRAY )
DrawLineinbitmap( hDC, nBottom-nI ,nRight-nDeep+nI-1,nBottom-nI ,nRight-nDeep+nI ,BLACK )
DrawLineinbitmap( hDC, nTop+nDeep-nI+1,nLeft-nDeep+nI-1 ,nTop+nDeep-nI+1,nLeft-nDeep+nI ,BLACK )
DrawLineinbitmap( hDC, nTop+nDeep-nI+1,nLeft-nDeep+nI-3 ,nTop+nDeep-nI+1,nLeft-nDeep+nI-2,BLACK )
NEXT nI
FOR nI=1 TO nDeep+2
DrawLineinbitmap( hDC, nTop+nDeep-nI+1,nLeft-nDeep+nI-3,nTop+nDeep-nI+1,nLeft-nDeep+nI-2 ,BLACK )
DrawLineinbitmap( hDC, nBottom+ 2-nI+1,nRight-nDeep+nI ,nBottom+ 2-nI+1,nRight-nDeep+nI-2,BLACK )
NEXT nI
DrawLineinbitmap( hDC, nTop ,nLeft ,nTop ,nRight ,BLACK )
DrawLineinbitmap( hDC, nTop- 2 ,nLeft ,nTop- 2 ,nRight+ 2 ,BLACK )
DrawLineinbitmap( hDC, nTop ,nLeft ,nBottom-nDeep ,nLeft ,GRAY )
DrawLineinbitmap( hDC, nTop+nDeep ,nLeft-nDeep ,nBottom ,nLeft-nDeep ,BLACK )
DrawLineinbitmap( hDC, nTop+nDeep ,nLeft-nDeep-2,nBottom+ 2 ,nLeft-nDeep-2,BLACK )
DrawLineinbitmap( hDC, nTop ,nRight ,nBottom-nDeep ,nRight ,BLACK )
DrawLineinbitmap( hDC, nTop- 2 ,nRight+ 2 ,nBottom-nDeep+2,nRight+ 2 ,BLACK )
DrawLineinbitmap( hDC, nBottom-nDeep,nLeft ,nBottom-nDeep ,nRight ,GRAY )
DrawLineinbitmap( hDC, nBottom ,nLeft-nDeep ,nBottom ,nRight-nDeep ,BLACK )
DrawLineinbitmap( hDC, nBottom+ 2 ,nLeft-nDeep-2,nBottom+ 2 ,nRight-nDeep ,BLACK )
// Graph info
IF !Empty(cTitle)
DrawTextInBitmap( hDC, nTop - 30 * nResV, nLeft, cTitle, 'Arial', 12, RED, 2 )
// Legends
IF lLegends
nPos := nTop
FOR nI := 1 TO HMG_LEN( aSeries )
DrawBarinbitmap( hDC, nRight+(8*nResH), nPos+(9*nResV), 8*nResH, 7*nResV, l3D, 1, aColors[nI] )
DrawTextInBitmap( hDC, nPos, nRight+(20*nResH), aSeries[nI], 'Arial', 8, BLACK, 0 )
nPos += 18*nResV
NEXT nI
// Max, Min values
nMax := 0
FOR nJ := 1 TO HMG_LEN(aSeries)
FOR nI :=1 TO HMG_LEN(aData[nJ])
nMax := Max( aData[nJ][nI], nMax )
NEXT nI
NEXT nJ
nMin := 0
nMin := Min( aData[nJ][nI], nMin )
NEXT nI
NEXT nJ
nXMax := IF( nMax > 0, DetMaxVal( nMax ), 0 )
nXMin := IF( nMin < 0, DetMaxVal( nMin ), 0 )
nHigh := nXMax + nXMin
nMax := Max( nXMax, nXMin )
nRel := ( nMaxBar / nHigh )
nMaxBar := nMax * nRel
nZero := nTop + (nMax*nRel) + nDeep + 5 // Zero pos
IF l3D
DrawLineinbitmap( hDC, nZero-nI+1, nLeft-nDeep+nI , nZero-nI+1, nRight-nDeep+nI, {192, 192, 192} )
NEXT nI
DrawLineinbitmap( hDC, nZero-nI+1, nLeft-nDeep+nI-1 , nZero-nI+1, nLeft -nDeep+nI, GRAY )
DrawLineinbitmap( hDC, nZero-nI+1, nRight-nDeep+nI-1, nZero-nI+1, nRight-nDeep+nI, BLACK )
NEXT nI
DrawLineinbitmap( hDC, nZero-nDeep, nLeft, nZero-nDeep, nRight, GRAY )
aPoint := Array( HMG_LEN( aSeries ), HMG_LEN( aData[1] ), 2 )
nRange := nMax / nXRanges
// xLabels
nRPos := nRNeg := nZero - nDeep
FOR nI := 0 TO nXRanges
IF lxVal
IF nRange*nI <= nXMax
DrawTextInBitmap( hDC, nRPos, nLeft-nDeep-70, Transform(nRange*nI, cPicture), 'Arial', 8, BLUE )
IF nRange*(-nI) >= nXMin*(-1)
DrawTextInBitmap( hDC, nRNeg, nLeft-nDeep-70, Transform(nRange*-nI, cPicture), 'Arial', 8, BLUE )
IF lxGrid
IF l3D
FOR nJ := 0 TO nDeep + 1
DrawLineinbitmap( hDC, nRPos + nJ, nLeft - nJ - 1, nRPos + nJ, nLeft - nJ, BLACK )
NEXT nJ
DrawLineinbitmap( hDC, nRPos, nLeft, nRPos, nRight, BLACK )
IF nRange*-nI >= nXMin*-1
IF l3D
DrawLineinbitmap( hDC, nRNeg + nJ, nLeft - nJ - 1, nRNeg + nJ, nLeft - nJ, BLACK )
NEXT nJ
DrawLineinbitmap( hDC, nRNeg, nLeft, nRNeg, nRight, BLACK )
nRPos -= ( nMaxBar / nXRanges )
nRNeg += ( nMaxBar / nXRanges )
NEXT nI
IF lYGrid
nPos:=IF(l3D, nTop, nTop-5 )
nI := nLeft + nWide
FOR nJ := 1 TO nMax(aData)
DrawlineinBitmap( hDC, nBottom-nDeep, nI, nPos, nI, {100,100,100} )
DrawlineinBitmap( hDC, nBottom, nI-nDeep, nBottom-nDeep, nI, {100,100,100} )
nI += nWide
DO WHILE .T. // Bar adjust
nPos = nLeft + ( nWide / 2 )
nPos += ( nWide + nSep ) * ( HMG_LEN(aSeries) + 1 ) * HMG_LEN(aData[1])
IF nPos > nRight
nWide--
EXIT
ENDDO
nMin := nMax / nMaxBar
nPos := nLeft + ( ( nWide + nSep ) / 2 ) // first point graph
nRange := ( ( nWide + nSep ) * HMG_LEN(aSeries) ) / 2
IF lyVal .AND. HMG_LEN( aYVals ) > 0 // Show yLabels
nWideB := ( nRight - nLeft ) / ( nMax(aData) + 1 )
nI := nLeft + nWideB
cName := "yVal_Name_"+LTRIM(STR(nJ))
DrawTextInBitmap( hDC, nBottom + 8, nI - nDeep - IF(l3D, 0, 8), aYVals[nJ], 'Arial', 8, BLUE )
nI += nWideB
// Bars
IF nType == BARS
if nMin <> 0
FOR nI=1 TO HMG_LEN(aData[1])
FOR nJ=1 TO HMG_LEN(aSeries)
DrawBarinbitmap( hDC, nPos, nZero, aData[nJ,nI] / nMin + nDeep, nWide, l3D, nDeep, aColors[nJ] )
nPos += nWide+nSep
NEXT nJ
nPos += nWide+nSep
NEXT nI
BT_BitmapSaveFile(hBitmap, cImageFileName )
BT_DeleteDC( BTstruct )
BT_BitmapRelease( hBitmap )
&& // Lines
&& IF nType == LINES
&& if nMin <> 0
&& nWideB := ( nRight - nLeft ) / ( nMax(aData) + 1 )
&& nPos := nLeft + nWideB
&& FOR nI := 1 TO HMG_LEN(aData[1])
&& FOR nJ=1 TO HMG_LEN(aSeries)
&& IF !l3D
&& DrawPoint( parent, nType, nPos, nZero, aData[nJ,nI] / nMin + nDeep, aColors[nJ] )
&& ENDIF
&& aPoint[nJ,nI,2] := nPos
&& aPoint[nJ,nI,1] := nZero - ( aData[nJ,nI] / nMin + nDeep )
&& NEXT nJ
&& nPos += nWideB
&& NEXT nI
&& FOR nI := 1 TO HMG_LEN(aData[1])-1
&& FOR nJ := 1 TO HMG_LEN(aSeries)
&& IF l3D
&& drawpolygon(parent,{{aPoint[nJ,nI,1],aPoint[nJ,nI,2]},{aPoint[nJ,nI+1,1],aPoint[nJ,nI+1,2]}, ;
&& {aPoint[nJ,nI+1,1]-nDeep,aPoint[nJ,nI+1,2]+nDeep},{aPoint[nJ,nI,1]-nDeep,aPoint[nJ,nI,2]+nDeep}, ;
&& {aPoint[nJ,nI,1],aPoint[nJ,nI,2]}},,,aColors[nJ])
&& ELSE
&& DrawLine(parent,aPoint[nJ,nI,1],aPoint[nJ,nI,2],aPoint[nJ,nI+1,1],aPoint[nJ,nI+1,2],aColors[nJ])
&& ENDIF
&& NEXT nI
&& NEXT nI
&& endif
&& ENDIF
&& // Points
&& IF nType == POINTS
&& if nMin <> 0
&& aPoint[nJ,nI,1] := nZero - aData[nJ,nI] / nMin
&& NEXT nJ
&& nPos += nWideB
&& NEXT nI
&& ENDIF
&& IF lViewVal
&& IF nType == BARS
&& nPos := nLeft + nWide + ( (nWide+nSep) * ( HMG_LEN(aSeries) / 2 ) )
&& ELSE
&& ENDIF
&& cName := "Data_Name_"+LTRIM(STR(nI))+LTRIM(STR(nJ))
&& @ nZero - ( aData[nJ,nI] / nMin + nDeep ), IF(nType == BARS, nPos - IF(l3D, 8, 10), nPos + 10) ;
&& LABEL &cName OF &parent ;
&& VALUE Transform(aData[nJ,nI], cPicture) AUTOSIZE ;
&& FONT "Arial" SIZE 8 BOLD TRANSPARENT
&& nPos+=IF( nType == BARS, nWide + nSep, 0)
&& NEXT nJ
&& IF nType == BARS
&& nPos += nWide + nSep
&& ELSE
&& nPos += nWideB
&& ENDIF
&& NEXT nI
&& ENDIF
&& IF l3D
&& DrawLine( parent, nZero, nLeft-nDeep, nZero, nRight-nDeep, BLACK )
&& ELSE
&& IF nXMax<>0 .AND. nXMin<>0
&& DrawLine( parent, nZero-1, nLeft-2, nZero-1, nRight, RED )
&& ENDIF
&& endif
&& ENDIF
function DrawWindowBoxInBitMap( hDC, row, col, rowr, colr )
BT_DrawRectangle ( hDC, Row, Col, Colr - col, rowr - row, { 0, 0, 0 }, nPenWidth )
return nil
function drawrectinbitmap( hDC, row, col, row1, col1, aColor )
BT_DrawFillRectangle (hDC, Row, Col, col1 - col, row1 - row, aColor, aColor, nPenWidth )
return nil
function DrawLineinbitmap( hDC, Row1, Col1, Row2, Col2, aColor )
BT_DrawLine ( hDC, Row1, Col1, Row2, Col2, aColor, nPenWidth )
return nil
function DrawTextInBitmap( hDC, Row, Col, cText, cFontName, nFontSize, aColor, nAlign )
default nAlign := 0
do case
case nAlign == 0
BT_DrawText ( hDC, Row, Col, cText, cFontName, nFontSize, aColor, )
case nAlign == 1
BT_DrawText ( hDC, Row, Col, cText, cFontName, nFontSize, aColor, , BT_TEXT_RIGHT )
case nAlign == 2
BT_DrawText ( hDC, Row, Col, cText, cFontName, nFontSize, aColor, , BT_TEXT_CENTER )
endcase
return nil
function DrawBarinbitmap( hDC, nY, nX, nHigh, nWidth, l3D, nDeep, aColor )
LOCAL nI, nColTop, nShadow, nH := nHigh
&& nColTop := ClrShadow( RGB(aColor[1],aColor[2],aColor[3]), 15 )
&& nShadow := ClrShadow( nColTop, 15 )
&& nColTop := {GetRed(nColTop),GetGreen(nColTop),GetBlue(nColTop)}
&& nShadow := {GetRed(nShadow),GetGreen(nShadow),GetBlue(nShadow)}
FOR nI=1 TO nWidth
DrawLineinbitmap( hDC, nX, nY+nI, nX+nDeep-nHigh, nY+nI, aColor ) // front
NEXT nI
&& IF l3D
&& // Lateral
&& drawpolygoninBitmap( parent,{{nX-1,nY+nWidth+1},{nX+nDeep-nHigh,nY+nWidth+1},;
&& {nX-nHigh+1,nY+nWidth+nDeep},{nX-nDeep,nY+nWidth+nDeep},;
&& {nX-1,nY+nWidth+1}},nShadow,,nShadow )
&& // Superior
&& nHigh := Max( nHigh, nDeep )
&& drawpolygon( parent,{{nX-nHigh+nDeep,nY+1},{nX-nHigh+nDeep,nY+nWidth+1},;
&& {nX-nHigh+1,nY+nWidth+nDeep},{nX-nHigh+1,nY+nDeep},;
&& {nX-nHigh+nDeep,nY+1}},nColTop,,nColTop )
&& // Border
&& DrawBox( parent, nY, nX, nH, nWidth, l3D, nDeep )
&& ENDIF
STATIC FUNCTION nMax(aData)
LOCAL nI, nMax := 0
FOR nI :=1 TO HMG_LEN( aData )
nMax := Max( HMG_LEN(aData[nI]), nMax )
NEXT nI
RETURN( nMax )
STATIC FUNCTION DetMaxVal(nNum)
LOCAL nE, nMax, nMan, nVal, nOffset
nE:=9
nVal:=0
nNum:=Abs(nNum)
DO WHILE .T.
nMax := 10**nE
IF Int(nNum/nMax)>0
nMan:=(nNum/nMax)-Int(nNum/nMax)
nOffset:=1
nOffset:=IF(nMan<=.75,.75,nOffset)
nOffset:=IF(nMan<=.50,.50,nOffset)
nOffset:=IF(nMan<=.25,.25,nOffset)
nOffset:=IF(nMan<=.00,.00,nOffset)
nVal := (Int(nNum/nMax)+nOffset)*nMax
EXIT
nE--
ENDDO
RETURN (nVal)
- esgici
Thanks Mr. RathinagiriRathinagiri wrote:IMHO, drawing graph on the window itself is an outdated HMG graphics functionality.
I couldn't understand lines commented by old style "&&" sign instead of "//"
Is there a special meaning / purpose of that coding style
Viva INTERNATIONAL HMG
- esgici
Hi friends, please don't exaggerateEduardoLuis, Serge, Marek wrote:..."HMG-ENCICLOPEDIA"...
I'm simply a HMG student
Viva HMG
I don't know the difference. But NotePad++ comments the lines we select and press Control+Q with &&.
