ERASE WINDOW command does not delete the graph titles
Hola
El comando ERASE WINDOW no borra los titulos de la grafica, creo que ya se habia dado una solucion
pero en esta version (3.4) sigue sin aplicarse. Quizas ya este implementada en la 3.41 ?
Hello
The ERASE WINDOW command does not delete the graph titles, I think they had already given a solution
but in this version (3.4) remains unimplemented. It may already be implemented in the 3.41?
Re: ERASE WINDOW command does not delete the graph titles
Post by EduardoLuis »
Esgici you are "HMG-ENCICLOPEDIA".-
Thanks for share with all of us your knowledge.-
With regards.
Eduardo
Thanks Esgici that was the solution.
He sure is a "HMG-ENCICLOPEDIA" !
serge_girard wrote:He sure is a "HMG-ENCICLOPEDIA" !
IMHO, drawing graph on the window itself is an outdated HMG graphics functionality.
The permanent solution for drawing graph is using the ultimate and versatile Bos Taurus library.
I have tried to convert the existing draw graph function ( only BAR type and not 3D) using BT library and saved the graph in a bitmap file. That bitmap can be used to show or print.
May be we can extend this to all other types and we have a NEW graph functionality to save the graph easily to a bitmap in HMG.
   define window graph at 0, 0 width 1000 height 700 main
      define button ok
         row 10
         col 10
         width 80
         caption 'Draw'
         action drawgraph()
      end button
      define image grapharea
         row 50
         col 50
         width 800
         height 600
      end image
   end window
   graph.center
   graph.activate
function drawgraph
   local cImage := 'graph.bmp'
   local nImageWidth := 800
   local nImageHeight := 600
   local cTitle := 'Sample Graph'
   local aYValues := {"Jan","Feb","Mar","Apr","May"}
   local aData := { {14280,20420,12870,25347, 7640},;
           { 8350,10315,15870, 5347,12340},;
           {12345, -8945,10560,15600,17610} }
   local nBarDepth := 15
   local nBarWidth := 15
   local nHValues := 5
   local l3D := .f.
   local lGrid := .t.
   local lXGrid := .t.
   local lYGrid := .t.
   local lXVal := .t.
   local lYVal := .t.
   local nGraphType := BARS
   local lViewVal := .t.
   local lLegends := .t.
   local cPicture := '99,999.99'
   local aSeries := {"Serie 1","Serie 2","Serie 3"}
   local aColors := { {128,128,255}, {255,102, 10}, {55,201, 48} }
   local lNoBorder := .f.
   local nLegendWidth := 50
   graphsave( cImage, nImageWidth, nImageHeight, aData,  cTitle, aYValues, nBarDepth, nBarWidth, nil, nHValues, l3d, lGrid, lXGrid, lYGrid, ;
            lXVal, lYVal, lLegends, aSeries, aColors, nGraphType, lViewVal, cPicture, nLegendWidth ,lNoBorder )
   graph.grapharea.picture := 'graph.bmp'
   return nil
function graphsave( cImageFileName, nWidth, nHeight, aData, cTitle, aYVals, nBarD, nWideB, nSep, nXRanges, ;
	              l3D, lGrid, lxGrid, lyGrid, lxVal, lyVal, lLegends, aSeries, aColors, nType, lViewVal, cPicture , nLegendWindth , lNoborder )
   LOCAL nI, nJ, nPos, nMax, nMin, nMaxBar, nDeep
   LOCAL nRange, nResH, nResV,  nWide, aPoint, cName
   LOCAL nXMax, nXMin, nHigh, nRel, nZero, nRPos, nRNeg
   local hBitMap, hDC, BTStruct
   local nTop := 0
   local nLeft := 0
   local nBottom := nHeight
   local nRight := nWidth
	DEFAULT cTitle   := ""
	DEFAULT nSep     := 0
	DEFAULT cPicture := "999,999.99"
	DEFAULT nLegendWindth := 50
   private nPenWidth := 0.25
	If ( HMG_LEN (aSeries) != HMG_LEN ( aData ) ) .or. ;
		( HMG_LEN ( aSeries ) != HMG_LEN ( aColors ) )
		MsgHMGError("DRAW GRAPH: 'Series' / 'SerieNames' / 'Colors' arrays size mismatch. Program terminated", "HMG Error" )
	EndIf
   hBitMap := BT_BitmapCreateNew ( nWidth, nHeight, { 255, 255, 255 } )
   hDC := BT_CreateDC( hBitMap, BT_HDC_BITMAP, @BTStruct )
   IF lGrid
      lxGrid := lyGrid := .T.
   IF nBottom <> NIL .AND. nRight <> NIL
      nHeight := nBottom - nTop / 2
      nWidth  := nRight - nLeft / 2
      nBottom -= IF( lyVal, 42, 32)
      nRight  -= IF( lLegends, 32 + nLegendWindth , 32 )
   nTop    += 1 + IF( Empty( cTitle ), 30, 44 )             // Top gap
   nLeft   += 1 + IF( lxVal, 80 + nBarD, 30 + nBarD )     // LEFT
   DEFAULT nBottom := nHeight - 2 - IF( lyVal, 40, 30 )    // Bottom
   DEFAULT nRight  := nWidth - 2 - IF( lLegends, 30 + nLegendWindth , 30 ) // RIGHT
   l3D     := IF( nType == POINTS, .F., l3D )
   nDeep   := IF( l3D, nBarD, 1 )
   nMaxBar := nBottom - nTop - nDeep - 5
   nResH   := nResV := 1
   nWide   := ( nRight - nLeft )* nResH / ( nMax( aData ) + 1 ) * nResH
   // Graph area
   IF ! lNoborder
	   DrawWindowBoxInBitMap( hDC, Max( 1, nTop - 44 ), Max( 1, nLeft - 80 - nBarD ), nHeight - 1, nWidth - 1 )
   // Back area
   IF l3D
      drawrectinbitmap( hDC, nTop+1, nLeft, nBottom - nDeep, nRight, { 255, 255, 255 } )
      drawrectinbitmap( hDC, nTop-5, nLeft, nBottom, nRight, { 255, 255, 255 } )
   IF l3D
         // Bottom area
         FOR nI := 1 TO nDeep+1
             DrawLineinbitmap( hDC, nBottom-nI, nLeft-nDeep+nI, nBottom-nI, nRight-nDeep+nI, { 255, 255, 255 } )
         NEXT nI
         // Lateral
             DrawLineinbitmap( hDC, nTop+nI, nLeft-nI, nBottom-nDeep+nI, nLeft-nI, {192, 192, 192} )
         NEXT nI
         // Graph borders
             DrawLineinbitmap( hDC, nBottom-nI     ,nLeft-nDeep+nI-1 ,nBottom-nI     ,nLeft-nDeep+nI  ,GRAY )
             DrawLineinbitmap( hDC, nBottom-nI     ,nRight-nDeep+nI-1,nBottom-nI     ,nRight-nDeep+nI ,BLACK )
             DrawLineinbitmap( hDC, nTop+nDeep-nI+1,nLeft-nDeep+nI-1 ,nTop+nDeep-nI+1,nLeft-nDeep+nI  ,BLACK )
             DrawLineinbitmap( hDC, nTop+nDeep-nI+1,nLeft-nDeep+nI-3 ,nTop+nDeep-nI+1,nLeft-nDeep+nI-2,BLACK )
         NEXT nI
         FOR nI=1 TO nDeep+2
             DrawLineinbitmap( hDC, nTop+nDeep-nI+1,nLeft-nDeep+nI-3,nTop+nDeep-nI+1,nLeft-nDeep+nI-2 ,BLACK )
             DrawLineinbitmap( hDC, nBottom+ 2-nI+1,nRight-nDeep+nI ,nBottom+ 2-nI+1,nRight-nDeep+nI-2,BLACK )
         NEXT nI
         DrawLineinbitmap( hDC, nTop         ,nLeft        ,nTop           ,nRight       ,BLACK )
         DrawLineinbitmap( hDC, nTop- 2      ,nLeft        ,nTop- 2        ,nRight+ 2    ,BLACK )
         DrawLineinbitmap( hDC, nTop         ,nLeft        ,nBottom-nDeep  ,nLeft        ,GRAY  )
         DrawLineinbitmap( hDC, nTop+nDeep   ,nLeft-nDeep  ,nBottom        ,nLeft-nDeep  ,BLACK )
         DrawLineinbitmap( hDC, nTop+nDeep   ,nLeft-nDeep-2,nBottom+ 2     ,nLeft-nDeep-2,BLACK )
         DrawLineinbitmap( hDC, nTop         ,nRight       ,nBottom-nDeep  ,nRight       ,BLACK )
         DrawLineinbitmap( hDC, nTop- 2      ,nRight+ 2    ,nBottom-nDeep+2,nRight+ 2    ,BLACK )
         DrawLineinbitmap( hDC, nBottom-nDeep,nLeft        ,nBottom-nDeep  ,nRight       ,GRAY  )
         DrawLineinbitmap( hDC, nBottom      ,nLeft-nDeep  ,nBottom        ,nRight-nDeep ,BLACK )
         DrawLineinbitmap( hDC, nBottom+ 2   ,nLeft-nDeep-2,nBottom+ 2     ,nRight-nDeep ,BLACK )
   // Graph info
   IF !Empty(cTitle)
      DrawTextInBitmap( hDC, nTop - 30 * nResV, nLeft, cTitle, 'Arial', 12, RED, 2 )
   // Legends
   IF lLegends
      nPos := nTop
      FOR nI := 1 TO HMG_LEN( aSeries )
         DrawBarinbitmap( hDC, nRight+(8*nResH), nPos+(9*nResV), 8*nResH, 7*nResV, l3D, 1, aColors[nI] )
         DrawTextInBitmap( hDC, nPos, nRight+(20*nResH), aSeries[nI], 'Arial', 8, BLACK, 0 )
         nPos += 18*nResV
      NEXT nI
   // Max, Min values
   nMax := 0
   FOR nJ := 1 TO HMG_LEN(aSeries)
      FOR nI :=1 TO HMG_LEN(aData[nJ])
         nMax := Max( aData[nJ][nI], nMax )
      NEXT nI
   NEXT nJ
   nMin := 0
         nMin := Min( aData[nJ][nI], nMin )
      NEXT nI
   NEXT nJ
   nXMax := IF( nMax > 0, DetMaxVal( nMax ), 0 )
   nXMin := IF( nMin < 0, DetMaxVal( nMin ), 0 )
   nHigh := nXMax + nXMin
   nMax  := Max( nXMax, nXMin )
   nRel  := ( nMaxBar / nHigh )
   nMaxBar := nMax * nRel
   nZero := nTop + (nMax*nRel) + nDeep + 5    // Zero pos
   IF l3D
          DrawLineinbitmap( hDC, nZero-nI+1, nLeft-nDeep+nI   , nZero-nI+1, nRight-nDeep+nI, {192, 192, 192} )
      NEXT nI
          DrawLineinbitmap( hDC, nZero-nI+1, nLeft-nDeep+nI-1 , nZero-nI+1, nLeft -nDeep+nI, GRAY )
          DrawLineinbitmap( hDC, nZero-nI+1, nRight-nDeep+nI-1, nZero-nI+1, nRight-nDeep+nI, BLACK )
      NEXT nI
      DrawLineinbitmap( hDC, nZero-nDeep, nLeft, nZero-nDeep, nRight, GRAY )
   aPoint := Array( HMG_LEN( aSeries ), HMG_LEN( aData[1] ), 2 )
   nRange := nMax / nXRanges
   // xLabels
   nRPos := nRNeg := nZero - nDeep
   FOR nI := 0 TO nXRanges
      IF lxVal
         IF nRange*nI <= nXMax
            DrawTextInBitmap( hDC, nRPos, nLeft-nDeep-70, Transform(nRange*nI, cPicture), 'Arial', 8, BLUE )
         IF nRange*(-nI) >= nXMin*(-1)
            DrawTextInBitmap( hDC, nRNeg, nLeft-nDeep-70, Transform(nRange*-nI, cPicture), 'Arial', 8, BLUE )
      IF lxGrid
            IF l3D
               FOR nJ := 0 TO nDeep + 1
                  DrawLineinbitmap( hDC, nRPos + nJ, nLeft - nJ - 1, nRPos + nJ, nLeft - nJ, BLACK )
               NEXT nJ
            DrawLineinbitmap( hDC, nRPos, nLeft, nRPos, nRight, BLACK )
         IF nRange*-nI >= nXMin*-1
            IF l3D
                  DrawLineinbitmap( hDC, nRNeg + nJ, nLeft - nJ - 1, nRNeg + nJ, nLeft - nJ, BLACK )
               NEXT nJ
            DrawLineinbitmap( hDC, nRNeg, nLeft, nRNeg, nRight, BLACK )
      nRPos -= ( nMaxBar / nXRanges )
      nRNeg += ( nMaxBar / nXRanges )
   NEXT nI
   IF lYGrid
      nPos:=IF(l3D, nTop, nTop-5 )
      nI  := nLeft + nWide
      FOR nJ := 1 TO nMax(aData)
         DrawlineinBitmap( hDC, nBottom-nDeep, nI, nPos, nI, {100,100,100} )
         DrawlineinBitmap( hDC, nBottom, nI-nDeep, nBottom-nDeep, nI, {100,100,100} )
         nI += nWide
   DO WHILE .T.    // Bar adjust
      nPos = nLeft + ( nWide / 2 )
      nPos += ( nWide + nSep ) * ( HMG_LEN(aSeries) + 1 ) * HMG_LEN(aData[1])
      IF nPos > nRight
         nWide--
         EXIT
   ENDDO
   nMin := nMax / nMaxBar
   nPos := nLeft + ( ( nWide + nSep ) / 2 )            // first point graph
   nRange := ( ( nWide + nSep ) * HMG_LEN(aSeries) ) / 2
   IF lyVal .AND. HMG_LEN( aYVals ) > 0                // Show yLabels
      nWideB  := ( nRight - nLeft ) / ( nMax(aData) + 1 )
      nI := nLeft + nWideB
         cName := "yVal_Name_"+LTRIM(STR(nJ))
         DrawTextInBitmap( hDC, nBottom + 8, nI - nDeep - IF(l3D, 0, 8), aYVals[nJ], 'Arial', 8, BLUE )
         nI += nWideB
   // Bars
	IF nType == BARS
		if nMin <> 0
			FOR nI=1 TO HMG_LEN(aData[1])
				FOR nJ=1 TO HMG_LEN(aSeries)
					DrawBarinbitmap( hDC, nPos, nZero, aData[nJ,nI] / nMin + nDeep, nWide, l3D, nDeep, aColors[nJ] )
					nPos += nWide+nSep
				NEXT nJ
				nPos += nWide+nSep
			NEXT nI
   BT_BitmapSaveFile(hBitmap, cImageFileName )
   BT_DeleteDC( BTstruct )
   BT_BitmapRelease( hBitmap )
   && // Lines
   && IF nType == LINES
	&& if nMin <> 0
      && nWideB  := ( nRight - nLeft ) / ( nMax(aData) + 1 )
      && nPos := nLeft + nWideB
      && FOR nI := 1 TO HMG_LEN(aData[1])
         && FOR nJ=1 TO HMG_LEN(aSeries)
            && IF !l3D
               && DrawPoint( parent, nType, nPos, nZero, aData[nJ,nI] / nMin + nDeep, aColors[nJ] )
            && ENDIF
            && aPoint[nJ,nI,2] := nPos
            && aPoint[nJ,nI,1] := nZero - ( aData[nJ,nI] / nMin + nDeep )
         && NEXT nJ
         && nPos += nWideB
      && NEXT nI
      && FOR nI := 1 TO HMG_LEN(aData[1])-1
         && FOR nJ := 1 TO HMG_LEN(aSeries)
            && IF l3D
               && drawpolygon(parent,{{aPoint[nJ,nI,1],aPoint[nJ,nI,2]},{aPoint[nJ,nI+1,1],aPoint[nJ,nI+1,2]}, ;
                           && {aPoint[nJ,nI+1,1]-nDeep,aPoint[nJ,nI+1,2]+nDeep},{aPoint[nJ,nI,1]-nDeep,aPoint[nJ,nI,2]+nDeep}, ;
                           && {aPoint[nJ,nI,1],aPoint[nJ,nI,2]}},,,aColors[nJ])
            && ELSE
               && DrawLine(parent,aPoint[nJ,nI,1],aPoint[nJ,nI,2],aPoint[nJ,nI+1,1],aPoint[nJ,nI+1,2],aColors[nJ])
            && ENDIF
         && NEXT nI
      && NEXT nI
	&& endif
   && ENDIF
   && // Points
   && IF nType == POINTS
		&& if nMin <> 0
            && aPoint[nJ,nI,1] := nZero - aData[nJ,nI] / nMin
         && NEXT nJ
         && nPos += nWideB
      && NEXT nI
   && ENDIF
   && IF lViewVal
      && IF nType == BARS
         && nPos := nLeft + nWide + ( (nWide+nSep) * ( HMG_LEN(aSeries) / 2 ) )
      && ELSE
      && ENDIF
            && cName := "Data_Name_"+LTRIM(STR(nI))+LTRIM(STR(nJ))
            && @ nZero - ( aData[nJ,nI] / nMin + nDeep ), IF(nType == BARS, nPos - IF(l3D, 8, 10), nPos + 10) ;
			&& LABEL &cName OF &parent ;
			&& VALUE Transform(aData[nJ,nI], cPicture) AUTOSIZE ;
			&& FONT "Arial" SIZE 8 BOLD TRANSPARENT
            && nPos+=IF( nType == BARS, nWide + nSep, 0)
         && NEXT nJ
         && IF nType == BARS
            && nPos += nWide + nSep
         && ELSE
            && nPos += nWideB
         && ENDIF
      && NEXT nI
   && ENDIF
   && IF l3D
      && DrawLine( parent, nZero, nLeft-nDeep, nZero, nRight-nDeep, BLACK )
   && ELSE
      && IF nXMax<>0 .AND. nXMin<>0
         && DrawLine( parent, nZero-1, nLeft-2, nZero-1, nRight, RED )
      && ENDIF
	&& endif
   && ENDIF
function DrawWindowBoxInBitMap( hDC, row, col, rowr, colr )
   BT_DrawRectangle ( hDC, Row, Col, Colr - col, rowr - row, { 0, 0, 0 }, nPenWidth )
return nil
function drawrectinbitmap( hDC, row, col, row1, col1, aColor )
   BT_DrawFillRectangle (hDC, Row, Col, col1 - col, row1 - row, aColor, aColor, nPenWidth )
return nil
function DrawLineinbitmap( hDC, Row1, Col1, Row2, Col2, aColor )
   BT_DrawLine ( hDC, Row1, Col1, Row2, Col2, aColor, nPenWidth )
return nil
function DrawTextInBitmap( hDC, Row, Col, cText, cFontName, nFontSize, aColor, nAlign )
   default nAlign := 0
   do case
   case nAlign == 0
      BT_DrawText ( hDC, Row, Col, cText, cFontName, nFontSize, aColor, )
   case nAlign == 1
      BT_DrawText ( hDC, Row, Col, cText, cFontName, nFontSize, aColor, , BT_TEXT_RIGHT )
   case nAlign == 2
      BT_DrawText ( hDC, Row, Col, cText, cFontName, nFontSize, aColor, , BT_TEXT_CENTER )
   endcase
return nil
function DrawBarinbitmap( hDC, nY, nX, nHigh, nWidth, l3D, nDeep, aColor )
   LOCAL nI, nColTop, nShadow, nH := nHigh
   && nColTop := ClrShadow( RGB(aColor[1],aColor[2],aColor[3]), 15 )
   && nShadow := ClrShadow( nColTop, 15 )
   && nColTop := {GetRed(nColTop),GetGreen(nColTop),GetBlue(nColTop)}
   && nShadow := {GetRed(nShadow),GetGreen(nShadow),GetBlue(nShadow)}
   FOR nI=1 TO nWidth
      DrawLineinbitmap( hDC, nX, nY+nI, nX+nDeep-nHigh, nY+nI, aColor )  // front
   NEXT nI
   && IF l3D
      && // Lateral
      && drawpolygoninBitmap( parent,{{nX-1,nY+nWidth+1},{nX+nDeep-nHigh,nY+nWidth+1},;
                   && {nX-nHigh+1,nY+nWidth+nDeep},{nX-nDeep,nY+nWidth+nDeep},;
                   && {nX-1,nY+nWidth+1}},nShadow,,nShadow )
      && // Superior
      && nHigh   := Max( nHigh, nDeep )
      && drawpolygon( parent,{{nX-nHigh+nDeep,nY+1},{nX-nHigh+nDeep,nY+nWidth+1},;
                   && {nX-nHigh+1,nY+nWidth+nDeep},{nX-nHigh+1,nY+nDeep},;
                   && {nX-nHigh+nDeep,nY+1}},nColTop,,nColTop )
      && // Border
      && DrawBox( parent, nY, nX, nH, nWidth, l3D, nDeep )
   && ENDIF
STATIC FUNCTION nMax(aData)
   LOCAL nI, nMax := 0
   FOR nI :=1 TO HMG_LEN( aData )
      nMax := Max( HMG_LEN(aData[nI]), nMax )
   NEXT nI
RETURN( nMax )
STATIC FUNCTION DetMaxVal(nNum)
   LOCAL nE, nMax, nMan, nVal, nOffset
   nE:=9
   nVal:=0
   nNum:=Abs(nNum)
   DO WHILE .T.
      nMax := 10**nE
      IF Int(nNum/nMax)>0
         nMan:=(nNum/nMax)-Int(nNum/nMax)
         nOffset:=1
         nOffset:=IF(nMan<=.75,.75,nOffset)
         nOffset:=IF(nMan<=.50,.50,nOffset)
         nOffset:=IF(nMan<=.25,.25,nOffset)
         nOffset:=IF(nMan<=.00,.00,nOffset)
         nVal := (Int(nNum/nMax)+nOffset)*nMax
         EXIT
      nE--
   ENDDO
RETURN (nVal)
Rathinagiri wrote:IMHO, drawing graph on the window itself is an outdated HMG graphics functionality.
Thanks Mr. Rathinagiri :)
I couldn't understand lines commented by old style "&&" sign instead of "//" :?
Is there a special meaning / purpose of that coding style :?:
Regards :D
EduardoLuis, Serge, Marek wrote:..."HMG-ENCICLOPEDIA"...
Hi friends, please don't exaggerate :oops:
I'm simply a HMG student :P
Viva HMG :D
I don't know the difference. But NotePad++ comments the lines we select and press Control+Q with &&.
