The FONTCOLOR, TRANSPARENT properties do not work 'Windows Panel'
Hola a todos
Estoy tratando de desplegar información en una ventana tipo PANEL, pero no funcionan
las propiedades de "FONTCOLOR" ni "TRANSPARENT"... Alguna idea ?
(Estoy trabajando con la version 3.4)
Hello everyone
I'm trying to display information in a window PANEL type, but do not work
properties "FONTCOLOR" or "transparent" ... Any ideas?
(I'm working with version 3.4)
#include "HMG.CH"
#define  COLORFDO  	{ 176, 224, 230 }
#define  cTITLE		"PRUEBA..."
STATIC  aActi, aTOpc, aTTip, aColo
FUNCTION MAIN()
	aActi := { "N", "N", "N", "N", "N", "N", "N", "N", "N", "N" }
	aTOpc := { "OPTION 1", "OPTION 2", "OPTION 3", "OPTION 4", "OPTION 5", "OPTION 6", "OPTION 7", "OPTION 8", "OPTION 9", "OPTION 10" }
	DEFINE WINDOW Form_1 AT 000,000 WIDTH 800 HEIGHT 640 MAIN BACKCOLOR COLORFDO TITLE cTITLE NOMAXIMIZE NOMINIMIZE
		@ 050,010 LABEL LB_A1 VALUE "Opcion 1" WIDTH 150 HEIGHT 22 FONT "Consolas" SIZE 12 FONTCOLOR BLACK BACKCOLOR { 210, 233, 255 }  BORDER ;
						 ACTION LlenaPanel( "1" ) CENTERALIGN
		DEFINE WINDOW Form_2 ROW 050 COL 170 WIDTH 600 HEIGHT 545 VIRTUALWIDTH 601 VIRTUALHEIGHT 700 WINDOWTYPE PANEL BACKCOLOR {  70, 130, 180 }
	CENTER WINDOW Form_1
FUNCTION LlenaPanel( cOpc )
	LOCAL nRen, cCtrlPso
	nRen := 50
	FOR i1 = 1 TO LEN( aActi )
		cCtrlPso := "LB_x"+STRZERO( i1, 2 )
		@ nRen,010 LABEL &cCtrlPso. OF Form_2 VALUE aTOpc[ i1 ] + ":" WIDTH 160 HEIGHT 22 FONT "Consolas" SIZE 12 ;
					FONTCOLOR BLUE BACKCOLOR { 210, 233, 255 } RIGHTALIGN  TRANSPARENT		//  <=== The FONTCOLOR, TRANSPARENT properties do not work 'Windows Panel'
		nRen += 25
	@ 050,180 LABEL LB_x11 OF Form_2 VALUE "<=== The FONTCOLOR, TRANSPARENT properties do not work 'Windows Panel'" WIDTH 330 HEIGHT 35 FONT "Consolas" SIZE 10 ;
					FONTCOLOR RED BACKCOLOR { 210, 233, 255 } TRANSPARENT
	MSGINFO( "OPCION "+cOpc )
	FOR i1 = 1 TO 11
		Form_2.&cCtrlPso..Release
Re: The FONTCOLOR, TRANSPARENT properties do not work 'Windows Panel'
No funciona en forma automática porque estas creado los controles en forma dinámica y no en forma estática dentro del DEFINE WINDOW.
Para que funcione tu ejemplo tenes que forzar el repintado de la ventana, pone antes del MSGINFO( "OPCION "+cOpc ) lo siguiente:
RedrawWindow ( Form_2.Handle )
It does not work automatically because these controls are created dynamically and not statically within the DEFINE WINDOW.
To work fine your example, you got to force repainting of the window, put before MsgInfo ("Option" + COPC) the following:
RedrawWindow (Form_2.Handle)
Gracias Dr. Claudio, funciona OK.
Hice una prueba con esto:
BT_ClientAreaInvalidateAll( "Form_1", .F.)
BT_ClientAreaInvalidateAll( "Form_2", .F.)
y tambien funcionó.
Viva HMG !!!
EVAL() is not running
Hola
Tengo otra situacion con el siguiente ejemplo.
La Función EVAL() no se ejecuta, alguna ayuda...
Hello
I have another situation with the next example ...
EVAL() is not running, any help...
#include "HMG.CH"
FUNCTION MAIN()
                   ACTION LlenaPanel( "2" ) CENTERALIGN
                   *ACTION LlenaPanel( "1" ) CENTERALIGN
	IF cOpc = "1"
		nRen := 50
			nRen += 25
		RedrawWindow ( Form_2.Handle )		// OK,  Dr. Claudio
		FOR i1 = 1 TO 11
	ELSE		// "2"
		nRen := 5
		nColS := 10
		FOR i1 = 1 TO 10
			cCtrlPso := "IMG_"+STRZERO( i1, 2 )
			@ nRen,nColS IMAGE &cCtrlPso. OF Form_2 PICTURE "Boton1.jpg" WIDTH 200 HEIGHT 32 STRETCH  ;
						 ACTION ( cOpc := "IMG_" + SUBSTR( This.Name, 5, 2 ) + "( " + SUBSTR( This.Name, 5, 2 ) + " )", ;		// IMG_0x( x )
						 EVAL( { || cOpc } ), MSGINFO( cOpc ) )			// <===  No se ejecuta el EVAL(), pero si el MSGINFO()  ???
			IF RIGHT( ALLTRIM( STR( i1, 2 ) ), 1 ) $ "2.4.6.8.0"
                nColS := 10
				nRen += 35
                nColS += 205
FUNCTION IMG_01( nOpc )
	MSGINFO( "Estoy dentro de la funcion: " + STRZERO( nOpc, 2 ) )
RETURN Nil
Anexo imagen .../ Annex picture ...
