HMG 3.4.1
klauskugel
Re: HMG 3.4.1
Thanks Doc,
you're the greatest.
That should solve the probs.
Greetings from Germany
klauskugel
klauskugel
- dragancesu
Re: HMG 3.4.1
I tried a demo for SQLite, build demo.hbp fault occurs,
then I added a line sqlite.hbc in demo.hbp and build demo.hbp make compilation
demo from \hmg.3.4.1\samples\hfcl\sql\sqlite
hmg version 3.4.1 patch 3
Re: HMG 3.4.1
HI Dragan :
It works on 64-bit Windows 10, HMG.3.4.1 patch 3 and compiled in 32 bits
- Clip2Mania
Re: HMG 3.4.1 - Order of Controls
when I compile following code in 3.4.0 everything works fine.
When I compile this code in 3.4.1 (+ patch 3), I get a runtime-error that the "form is not defined"?
When I change the order of the Controls, i.e. I put the grid as first Control, followed by the menu, I get no error.
When I add a status-bar control, I have to put it below the grid also, otherwise: error again.
This has changed in comparison with 3.4.0. ??? Is there an order in which you have to place the controls ?
Erik
function main()
local aHeaders:={'Column1','Column2','Column3'}
public aList:={}
SET MULTIPLE OFF WARNING
SET DATE ITALIAN
DEFINE WINDOW MainForm;
AT 90,90;
WIDTH 1025;
HEIGHT 550;
TITLE 'Resize Error';
MAIN;
ON SIZE Resize();
ON MAXIMIZE Resize()
DEFINE MAIN Menu of MainForm
DEFINE POPUP "File"
MENUITEM "About" ACTION MsgInfo("Action")
END POPUP
END MENU
@ 005,005 GRID Grid_1 ;
WIDTH 1000 HEIGHT 490 ;
HEADERS aHeaders;
WIDTHS {300,300,300} ;
ITEMS aList ;
VALUE 1;
FONT "Courier New" SIZE 10 ;
FONTCOLOR {000,000,255};
EDIT;
CELLNAVIGATION;
LOCKCOLUMNS 1
MainForm.Center
MainForm.Activate
return NIL
function Resize()
MainForm.Grid_1.Width:=MainForm.Width-25
MainForm.Grid_1.Height:=MainForm.Height-60
return NIL
Erik
Re: HMG 3.4.1
Order of the Controls is often giving compile errors.
I don't have a sample at this moment.
- esgici
Hi ErikClip2Mania wrote:...
This has changed in comparison with 3.4.0. ??? Is there an order in which you have to place the controls ?![]()
IMO you need something like this :
function main()
public aList:={}
lFirstRun := .T. // <--- added
function Resize()
IF lFirstRun
lFirstRun := .F.
return NIL
But it's strange how this code running without error when compiled with 3.4.0
Happy HMG'ing
Viva INTERNATIONAL HMG
- Clip2Mania
Re: HMG 3.4.1
Esgici,
that is indeed a workaround, but how come if I place the controls in another order it works (in 3.4.0, all combinations work)... ?
So the order of the controls does matter.
More specifically, all my programs have a resize function, which also resizes the grid - so I have to change everything now...
Erik
Erik
- esgici
Re: HMG 3.4.1
This is really a big ( a bit academicClip2Mania wrote:... how come if I place the controls in another order it works (in 3.4.0, all combinations work)... ?
Apparently yes; and reason this effect too is also obscure for meSo the order of the controls does matter.
Did you tried with pre-3.4.0 verisons ?More specifically, all my programs have a resize function, which also resizes the grid - so I have to change everything now...
Happy HMG'ing
- Clip2Mania
Re: HMG 3.4.1
Maybe Dr. Soto can help - if he reads this?This is really a big ( a bit academic) question for me; definitely I don't know the answer
I only started working with version 3.4.0 last year, so I have no experience with older versions of HMG - and I really want to use 3.4.1 for the bug-fixes and new functions...Did you tried with pre-3.4.0 verisons ?
Erik
