HMG 3.4.1
Pepe Ruano
Re: HMG 3.4.1
Post by Pepe Ruano »
Gracias a la sugerencia de Grigory, he podido solucionarlo y ahora funciona bien.
He modificado el archivo source\h_status.prg y luego he compilado todas las librerias.
En el código que pone:
 _DefineTimer ( 'StatusKeyBrd' , FormName , 200 , ;
Lo he sustituido por:
_DefineTimer ( 'StatusKeyBrd' , FormName , 50 , ;
Ahora todo funciona bien. Solucionado.
Muchas gracias a todos.
In English:
Thanks for the suggestion of Grigory, I could fix it and now it works fine.
I modified file source\h_status.prg and then I compiled all libraries
In the code that says:
  _DefineTimer ('StatusKeyBrd', FormName, 200;
I modified the value and I left it like this:
_DefineTimer ('StatusKeyBrd' FormName, 50;
Now everything works fine. Solved.
Thank you very much to all.
Saludos - Regards
Pepe Ruano
hmg.ruano.org
jorge.posadas
Re: HMG 3.4.1
Post by jorge.posadas »
He bajado esta version y al compilar un ejemplo que está en:
C:\hmg.3.4.1\SAMPLES\HFCL\SQL\SQLITE
usando BUILD DEMO, me manda este error:
Harbour 3.2.0dev (r1506261250)
C:/Users/ADMINI~1/AppData/Local/Temp/hbmk_khxhut.dir/demo.o:demo.c:(.data+0xa8): undefined reference to `HB_FUN_CONNECT2DB'
C:/Users/ADMINI~1/AppData/Local/Temp/hbmk_khxhut.dir/demo.o:demo.c:(.data+0x178): undefined reference to `HB_FUN_SQL'
C:/Users/ADMINI~1/AppData/Local/Temp/hbmk_khxhut.dir/demo.o:demo.c:(.data+0xe8): undefined reference to `HB_FUN_C2SQL'
C:/Users/ADMINI~1/AppData/Local/Temp/hbmk_khxhut.dir/demo.o:demo.c:(.data+0x188): undefined reference to `HB_FUN_MISCSQL'
C:/hmg.3.4.1/mingw/bin/../lib/gcc/i686-w64-mingw32/4.9.2/../../../../i686-w64-mingw32/bin/ld.exe: C:/Users/ADMINI~1/AppData/Local/Temp/hbmk_khxhut.dir/demo.o: bad reloc address 0xf in section `.text.startup'
C:/hmg.3.4.1/mingw/bin/../lib/gcc/i686-w64-mingw32/4.9.2/../../../../i686-w64-mingw32/bin/ld.exe: final link failed: Invalid operation
hbmk2: Error: Ejecutando enlazador. 1
gcc.exe C:/Users/ADMINI~1/AppData/Local/Temp/hbmk_khxhut.dir/demo.o C:/Users/ADMINI~1/AppData/Local/Temp/hbmk_khxhut.dir/hbmk_28ibhm.o C:/hmg.3.4.1/SAMPLES/HFCL/SQL/SQLITE/_temp.o -mwindows -Wl,--start-group -lhmg -lcrypt -ledit -leditex -lgraph -lini -lreport -lhfcl -lmsvfw32 -lvfw32 -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbmysql -lmysql -lhbtip -lhbsqlit3 -lsddodbc -lrddsql -lsddmy -lhbodbc -lodbc32 -lhbhpdf -lhbfimage -lhbpgsql -lhbnetio -lxhb -lpng -llibhpdf -lhbvpdf -lhbzebra -lhbextern -lhbdebug -lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -liphlpapi -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib -Wl,--end-group -odemo.exe -LC:/hmg.3.4.1/harbour/lib/win/mingw -LC:/hmg.3.4.1/lib
hbmk2: Error: Funci¢n(es) referenciada, no encontrada, pero desconocida:
CONNECT2DB(), SQL(), C2SQL(), MISCSQL()
¿Cómo puedo solucionar esto?
De antemanon muchas gracias
Cordialmente
POSADAS SOFTWARE
Jorge Posadas Ch.
Programador independiente
Morelia, Mich.
M é x i c o .
Movil +52 44 3734 1858
SKYPE: jorge.posadasch
Re: HMG 3.4.1
Please copy libhmgsqlite.a from the previous version lib folder to the current version lib folder.
Re: HMG 3.4.1
Rathinagiri wrote:Hi,
  • libeay32.a
    libhmgmysql.a
    libhmgpgsql.a
are also missing :(
May will be any problem copying them too :?
Viva HMG :D
Re: HMG 3.4.1
Esgici, files you have mentioned are not required if you don't use SQL/SQLCipher. So, I have stopped distributing these files. In the next version we have to properly handle these also.
Re: HMG 3.4.1
Rathinagiri wrote:Esgici, files you have mentioned are not required if you don't use SQL/SQLCipher. So, I have stopped distributing these files. In the next version we have to properly handle these also.
OK Rathi, thanks.
jucar_es
Re: HMG 3.4.1
Post by jucar_es »
Muy buenos dias
estoy tratando de compilar el ejemplo en postgresql
Y ME SALE ESTE ERROR
ME PUEDEN AYUDAR.
gracias
Re: HMG 3.4.1
this is a new patch that include all previous patches.
- Fixed bug in CreateEvent (reported by Roberto Lopez)
- Fixed bug in This.QueryData of Grid control (reported by Roberto Lopez)
- Fixed bug in BackColor of InputWindow (reported by Roberto Lopez)
- Fixed bug in Print Preview (reported by Roberto Lopez)
- New function HBtoWinDateFormat() for fixed bug in get date format of MonthCal/DatePick controls (contrib by Pablo Cesar)
- IsControlDefined, IsWindowDefine and IsWindowActive functions, accept parameters FormName/ControlName with/without quotation marks (contrib by Pablo Cesar)
- Now SplitChild Window support OnPaint event.
In this patch:
- Fixed bug in get Cell value of the Grid control (reported by Marek)
- Fixed bug in default color of HeaderDYNAMICBACKCOLOR of the Grid control (reported by Rathinagiri)
- Fixed bug in DYNAMICFONT and ONCHECKBOXCLICKED of Grid control in i_altsyntax.ch header file (contrib by Rathinagiri)
hmg.3.4.1_patch3.rar
(821.81 KiB) Downloaded 468 times
chrisjx2002
Re: HMG 3.4.1
Post by chrisjx2002 »
Thanks Dr Claudio!
Re: HMG 3.4.1
srvet_claudio wrote:Hi All,
Many Thanks Dr. Soto
Best regards
