HMG 3.4.1
Re: HMG 3.4.1
Post by EduardoLuis »
Hi Claudio:
I've finished testing some complex appe i develope, and all works fine.-
I notice best speed response on normal and virtual grids both with graphics.-
All test were made on Win XP SP3, and Win 8 both 32 bits.-
These information is for the records.-
Thanking your efforts and generosity.
With regards.
Eduardo
klauskugel
Re: HMG 3.4.1
Post by klauskugel »
Hi Claudio,
MiniWriter works in in 64-bit Mode and makes trouble in 32-bit Mode.
Printing-System doesn't work in 64-Bit.
Applications work.
I just love it. :)
Greetings from Germany
klauskugel
Re: HMG 3.4.1
EduardoLuis wrote:Hi Claudio:
With regards.
Eduardo
Thanks for your test Eduardo.
Re: HMG 3.4.1
klauskugel wrote:Hi Claudio,
Applications work.
I just love it. :)
klauskugel
Hi Klauskugel,
MiniWriter and Printing-System work fine for me when building it's in 32 and 64-bit (Win7).
Re: HMG 3.4.1
klauskugel wrote:...
Hi Klaus
In my side ( Win7, HMG 3.4.1 ) no problem encountered :arrow:
If you clarify your "trouble", we can deeper test.
Viva HMG :D
Re: HMG 3.4.1
Hi Klauskugel:
After install HMG341 Patch2, please perform BuildLib in it's two options: ANSI and Unicode.-
Although you use IDE ansi or IDE unicode, you must rebuild both libraries.-
Does that, and recompile Miniwrite.- There will not be any trouble.-
With regards.
Eduardo
Re: HMG 3.4.1
Does anybody else have this problem in Grid headers backcolor?
Please see the difference between compiled in previous version and current version.
My target system is WinXP.
In Windows 7 it works ok and shows no difference.
dhaine_adp
Re: HMG 3.4.1
Post by dhaine_adp »
Rathinagiri wrote:Does anybody else have this problem in Grid headers backcolor?
Maybe it has something to do with Win XP theme?
Danny
Manila, Philippines
Re: HMG 3.4.1
Hi Rathi:
About your questión, i agree with dahine, may be an skin trouble with XP default theme.-
I don't experiment such difference as you describe.- On my XP SP3 target system I've installed since long time skin Vista Inspirat Ultimate 2, so my screens look and also my clients too screens with XP looks fantastic bether than vista.-
This skin theme contains Aero, so effect like transparences all fully accesible.-
If you or anybody want to install it go to:
http://www.crystalxp.net/galerie/en.id. ... -packs.htm
It works with XP (SP3) under 32 bit. no mather how much ram have's your hardware; in my "tests machine" i've only 512 mg ram, and looks and works excellent.-
Hoping these helps you and everybody.-
With regards.
Eduardo
Pepe Ruano
Re: HMG 3.4.1 Status Bar Keyboard Blinking
Post by Pepe Ruano »
Hola maestros.
He descargado la versión 3.4.1. y el parche 2. He compilado todas las librerias.
Pero tengo un problema:
Cuando defino un status bar con keyboard date y clock, el keyboard y el clock están parpadeando constantemente y resulta muy molesto.
Si utilizo HMG 3.3.1 todo funciona bien.
Pueden ayudarme.
Muchas gracias.
Google Translator :?
Hello teachers.
I downloaded version 3.4.1. and patch 2. I compiled all libraries.
But I have a problem:
When I define a status bar with date keyboard and clock , the keyboard and the clock are constantly blinking and is very annoying.
If I use HMG 3.3.1 everything works fine.
Can you help me.
Thank you.
Saludos - Regards
Pepe Ruano
hmg.ruano.org
